Error in ReaderExtension WatchFolder Concept
May 29, 2008 6:57 AM
I installed the AdobeLiveCycle ES for ReaderExtensions. I used the ReaderExtensions through watchfolder concept. But the file found in failure folder with "failure.log". So please kindly see the below error in .log file and give solution.
Failure Time----Thu May 29 20:06:42 IST 2008
source location ---- Reason of failure is-----Failure to invoke the job DynamicallyApplyRights
Invocation error.
javax.jms.JMSException: Could not create a session: javax.resource.spi.CommException: javax.naming.CommunicationException: Could not obtain connection to any of these urls: 0.0.0.0:1100 [Root exception is javax.naming.CommunicationException: Failed to connect to server 0.0.0.0:1100 [Root exception is javax.naming.ServiceUnavailableException: Failed to connect to server 0.0.0.0:1100 [Root exception is java.net.ConnectException: Connection refused: connect]]]
ALC-DSC-600-000: com.adobe.idp.dsc.provider.service.scheduler.impl.SchedulerRuntimeExc eption: Failure to invoke the job DynamicallyApplyRights
at com.adobe.idp.dsc.provider.service.file.scan.impl.FileScanJobImpl.inv okeJob(FileScanJobImpl.java:302)
at com.adobe.idp.dsc.provider.service.file.scan.impl.FileScanJobImpl.pro cessInputs(FileScanJobImpl.java:119)
at com.adobe.idp.dsc.provider.service.scheduler.scan.impl.AbstractScanJo b.execute(AbstractScanJob.java:56)
Thanks in advance,
Prabudass
    Jun 10, 2008 11:30 AM   in reply to (Prabudass)
    Make sure that you configure invocation permissions for your watch folder endpoint.
    Log to adminui: Home > Services > Archive Administration > Service Management > process name. Click on security tab, click on Add principal and add an appropriate group for INVOKE_PERM permissions.
    Jun 18, 2008 11:42 AM   in reply to (Prabudass)
    Can you export orchestration to an lca and pass it to me?
    Jun 20, 2008 7:49 AM   in reply to (Prabudass)
    I have a sample for you:
    ftp://es-guest-user:V9bibSrasW@ftp-sj.adobe.com/sample
    Jun 22, 2008 7:49 PM   in reply to (Prabudass)
    The link already has user name and password (es-guest-user/V9bibSrasW). When you click on the link it should bring you to a folder on FTP.
    Aug 4, 2011 2:17 AM   in reply to (Prabudass)
    Hello,
    I do have the same error as mentioned above in a livecycle process using output services to generate a pdf for print.
    The process uses:
    1. WatchedFolder endpoin
    ...some steps, not relevant..
    4. Output.OutputService.generatePdfOutput to generate a pdf based on a template and input xml.
    5. Common.ConvertPdfService.toPS to prepare a document for postscript printing.
    6. Output.OutputService.SendToPrinter to print the damn thing...
    When i run the process on a jboss turnkey installation on a windows 2003 server the document gets printed fine!
    When i look in the failure folder of the watchedFolder it is filled with a folder named 'unsaved_results'.
    In that folder i find my generated pdf, which opens fine.
    The failure.log file contains a message: 'Failure Time----Thu Aug 04 10:54:46 CEST 2011
    Results for output parameter ----pdfDocare saved in unsaved_results/pdfDoc folder due to
    The filename, directory name, or volume label syntax is incorrect'
    The jboss system logfile does not produce more info than the failure log produces.
    I am looking into troubleshooting documents online, but this is the only developer forum thread related to my problem.
    Thanks for any help!!!
    Aug 4, 2011 3:24 AM   in reply to MvGemert
    Solved:
    The pdfDoc variable for labelled as output parameter which was not correct.
    The process then tries to store the variable somewhere (don't know where the default variable storage is located) where it has no rights (i presume).
    The errormessage was somewhat cryptic which made me think something was wrong in the adobe livecycle internal storage configuration.
