Convert autocad to PDF in black and white
May 15, 2008 7:28 AM
I am using CreatePDF service to convert autocad drawing to PDF. Is there anyway to make PDF in black and white, instead of color?
    May 19, 2008 3:51 PM   in reply to (Joanna_Gao)
    I don't think so, but if you can find a PDFMaker option for it then you can probably set the same option in the PDF/G configuration file. You might get more authoritative answers in the PDFGenerator forum (but I don't see a forum for LC ES, just 7.x)
    Don
    Sep 13, 2008 12:17 AM   in reply to (Joanna_Gao)
    Use the plot color styles "monochrome.ctb or monochrome.stb
    Mike
    Mar 22, 2013 1:19 PM   in reply to (Joanna_Gao)
    Georgeshm wrote very sharp solution but forgot to write you can do it with Autocad then convert it..
    If you have Autocad,
    Way1: Open the file as Georgeshm told go layout.. right click, layout settings, change pen assigntment (at the top of right) to monochrome or grayscale...
    Way2: Faster and easy open the file with Autocad. give "la" (Layer properties command) open the layers..
    Select all click the attached colour box and change all to white. Then save as so don t lose original one..Convert it.. Issue is when you wanna do convert Pdf to Cad.. I couldn t find any safety way to do that. And I gave my Pdf to Autocad  conversion job to company..
    I hope you have Autocad and you can use one of method for your file.
