Nov 30, 2007 12:10 PM
I'm trying to send multiple attachments using "Send With Map of Attachments" Service. I've setup a map variable (attachments_map) of sub-type string to hold the path and file name for each file (represented as <full_path>/<file_name>.pdf).<br /><br />What I'm confused about is that I don't understand the keys of the map given the following statement in the help file about this specific Email service: "The keys for the map are the attachment file names. The file names should include the file name extension if the email receiver needs to associate the file with software to open it."<br /><br />I have two questions:<br /><br />1) What are the keys for the map needed for the "Send With Map of Attachments" service for Attachments and what is the XPath representation to send this data to the service (e.g., /process_data/attachment_map/@file[0] or /process_data/attachment_map/@file[<file_name>] or what) ? I don't know what the required XML structure looks like. As you can tell, I've not used a map variable before either! :)<br /><br />2) As in the "Send With Document" service, is there a way to define the file name saved in the e-mail that the receiver sees?<br /><br />Example:<br />Receiver sees this in e-mail: "File.pdf"<br />But the path and file are actually this: T:/Files/XXXX_File.pdf<br /><br />Thanks for your help in advance!
