Lightroom modifies EXIF after import?
Aug 9, 2007 4:36 AM
When I import photos with Lightroom, they seem to loose part of the lens data that DxO uses to process images with. For example, a photo with the lens Nikon 12-24mm f/4 AF-S will just be 12-24mm afterwards, and DxO won't know which lens algorithm to do the processing with.
Is there something I'm missing, or does Lightroom always modify the EXIF like this?
TIA.
    Aug 9, 2007 6:31 AM   in reply to (Weiran_Zhang)
    Lightroom doesn't touch the original files. If you've converted to .DNG during import, DxO misses some data though when you use .DNG as the source. DxO can only process the pure RAW file correctly.
    Sep 8, 2007 8:17 PM   in reply to (Weiran_Zhang)
    I have found this lately, although I found out it has been going on since April. Using the same camera and lenses, one day all the info is there and the next day it is gone and hasn't come back. When did 1.1 come out? Did this change in 1.1?
    Oct 18, 2007 4:05 PM   in reply to (Weiran_Zhang)
    I'm having the same problems with LR1.2 and DxO plugin (using method 2 as described by DxO): imported as DNG and incorrect lens information. The original NEF is OK when read directly by DxO, haven't tried using NEF files in LR yet.
