ik1hsr
Casting Cf struct in Hashtable Java
May 30, 2007 1:00 AM
Hi;
i need to convert a Coldfusion Struct in a Java Hashtable (as th CFMX manual tell);
I have this java class:
public class Pratica {
private java.util.Hashtable my;
public Pratica(){
my=null;
public Pratica(java.util.Hashtable dbprop){
my=dbprop;
public void set(java.util.Hashtable dbprop){
my=dbprop;
and in the CF page i have this code:
<cfset ma = createObject("java","java.util.Hashtable")>
<cfset ma.init(glb)> // glb is a struct
<cfobject action="CREATE" type="JAVA" class="Pratica" name="pra">
<cfset pra.init(ma)>
but when i run...:
"Unable to find a constructor for class Pratica that accepts parameters of type ( java.util.Hashtable )."
I'm waiting your suggestions!!!
thanks to all
Andrea
ps:sorry for my english.
    May 30, 2007 6:28 AM   in reply to ik1hsr
    There does not seem to be a constructur for Hashtable that accepts a CF structure as a parameter. Take a look at the java documentation:
    http://java.sun.com/j2se/1.4.2/docs/api/java/util/Hashtable.html#Hasht able(int,%20float)
    Given, I haven't tried to go from CF struct to hashtable before - could you do something like this?
    1) Initialize an empty Hashtable
    <cfset myHashTable= createObject("java","java.util.Hashtable")>
    <cfset myHashTable.init()>
    2) loop over the CF structure collection and call the Hashtable's put() method to populate the hashtable
    <cfloop collection="#glb#" item="key">
    <cfset myHashTable.put(key, glb[key])>
    </cfloop>
    Jun 6, 2007 4:44 PM   in reply to ik1hsr
    ik1hsr,
    In MX6/7 a ColdFusion Struct is a Hashtable. So you don't need to create a new one. Just pass in the CF Struct object.
    Java Class:
    public Pratica(){
    my=null;
    my=dbprop;
    my=dbprop;
    public String getKeyValue(Object key) {
    if (my != null) {
    return my.get(key).toString();
    return "";
    ColdFusion Code:
    <cfset theKey = "abc" />
    <cfset cfStruct = structNew()>
    <cfset cfStruct[theKey] = "abc" />
    <cfset pra = createObject("java", "Pratica").init(cfStruct) />
    <cfoutput>#theKey# value = #pra.getKeyValue(theKey)#</cfoutput>
    Apr 3, 2012 6:10 AM   in reply to cf_dev2
    cf_dev2, Thanks for that!  Picky syntax was holding me up 'till I found your specific example, so thanks!
