Home/Support/
Forums
531 Views 17 Replies Latest reply: Sep 17, 2008 11:42 AM by (EvertJan_van_Loon) RSS
Calculating status... 17 posts since
Feb 26, 2007
Jul 14, 2008 3:19 AM
Nikon D700 NEF support
any news about D700 NEF support? When will it happen?
Got a test cam and can't use NEFs in LR.
Thx, regards,
Mat
  • bob frost User 311 posts since
    Aug 11, 2002
    1. Jul 14, 2008 3:48 AM (in response to (Matic_Kos))
    Re: Nikon D700 NEF support
    Yes you can - just turn them into dngs. I think!
    Bob Frost.
  • michael shaffer User 441 posts since
    Aug 11, 2002
    2. Jul 14, 2008 4:19 AM (in response to (Matic_Kos))
    Lr v1.x apparently wasn't elegible for the most recent Olympus dCam (E-520), so imagine Lr v2 will be the target for D700 NEF support as well. The D700 is new enough I wonder if it is currently supported by the current DNG converter, which was only just released.
    I might question why you'd use 3rd party software to evaluate a new camera(?) Wouldn't it be better to trust Nikon to develop its own raw data from this new sensor? And then, and only then, to believe Adobe would deliver its excellent development tools in good time(?)
  • don solomon User 1,475 posts since
    Oct 27, 2006
    3. Jul 14, 2008 7:05 AM (in response to (Matic_Kos))
    Exactly, if you want to see just what your camera does. use NX2 (presuming it will read the proprietary format of a D700--or would that require an upgrade to it? Hmmmm) and then compare the results with LR2 when it ships.
    I'm shooting D200s and 300s now, but will be picking up a D700 as soon as the review dust settles and the price drops after the first 90 days or so.My experience has been that NX produces the best conversions of NEFs of anything out there--but until NX2 came out, it was so clunky and slow that I only used it on about 2-4 percent of my work. Now I am up to about 10% and climbing, as I establish a new workflow to accommodate it.
    One thing NX does do, however slow, is first rate conversions and editing of NEFS. And the feature set of NX2 with its improved workspace choice is in my opinion better than LR2 beta (which is not fully fleshed out yet)--that is, if compare NX2 to the LR2 Develop module, NX2 is non destructive as well, given that you can save work back to NEF and open and change edits any number of times before using the file as a tif or jpeg.
    Yes, you can achieve close to NX results with LR, but to do so can sometimes make for slow workflow as well. I will be interested to see how LR2 does myself--hopefully in a month or so :)
  • Ian Lyons Community Professional 6,065 posts since
    Jan 9, 2006
    5. Jul 14, 2008 8:54 AM (in response to (Matic_Kos))
    >Getting Oly E520 on Wednesday, so that won't work either in LR1..
    Download the release candidate of DNG Converter 4.5 and convert the files to DNG, Lr 1.4.1 and Lr2.0 will then be able to edit E520 files.
    http://labs.adobe.com/wiki/index.php?title=Camera_Raw_4.5
    Edit:
    DNG and ACR 4.5RC do support the Nikon D700.
  • Calculating status... 2 posts since
    Jul 27, 2008
    6. Jul 27, 2008 6:51 AM (in response to (Matic_Kos))
    Dear All,
    I have also had problems with the D700 NEF files but have now worked out how to open them in lightroom/CS3.
    Use the supplied Nikon NX2 software to download the images from your camera. Use 'Save as' to save them to a folder on your computer as NEF files. Then select all the images in the folder and right click to view the 'Properties'. In properties there should be 3 tabs - one of which is details. You should them be able to change the 'Camera model' from D700 to D3. Press OK to apply the changed property. Then open Lightroom and import the images as you usually would.
    Note that if you do not get the 'details' tab in the image properties then you will probably need to download the nikon software that allows D700 NEF files to be viewed in Windows - this is available here: http://www.nikonimglib.com/nefcodec/index.html.en
    There are some other postings on the web about installing a program to do this change automatically but it was too complicated for me - if someone could provide step by step instructions I'd be very grateful!
    I hope this helps!
  • MethodPhoto User 1,241 posts since
    Jan 9, 2006
    7. Jul 28, 2008 9:22 PM (in response to (Matic_Kos))
    You can go to Adobe Camera Raw 4.5 Release Version, which has unofficial support for the Nikon D700. Unofficial, means it is probably fine, but it hasn't been through rigorous QA yet.
    Mac: http://www.adobe.com/support/downloads/detail.jsp?ftpID=3940
    Win: http://www.adobe.com/support/downloads/detail.jsp?ftpID=3941
  • Calculating status... 3 posts since
    Jul 29, 2008
    8. Jul 29, 2008 6:14 AM (in response to (Matic_Kos))
    you can work with nefs from the D700 if you change the model from MODEL D700 to MODEL D3 in the exifdata.
    Than you can use the files with ACR, Lightroom and CS3.
    Get the exiftool made by Phil Harvey and on the console (CMD)
    type in:
    path where your picture are...
    d:\mypics\>exiftool -model="NIKON D3" *.nef
    than you can change pics from nef to dng.
    Another way is,
    renname the exiftool.exe to exiftool(-model='NIKON D3').exe
    and than in the MS-Explorer select all nef's and drag them on the new exitftool. Then it will due the same job as above.
    I have got my D700 on friday and did the expirence ad the weekend.
    best gegards,
    alschim, germany
    http://www.alschim.de
  • Lee Jay-7OQGJF Participant 8,714 posts since
    Jun 26, 2006
    9. Jul 29, 2008 6:17 AM (in response to (Matic_Kos))
    You don't need to do that with LR 2.0.
  • Calculating status... 1 posts since
    Aug 2, 2008
    10. Aug 2, 2008 6:10 PM (in response to (Matic_Kos))
    I have downloaded both Camera Raw 4.5 and the latest DNG converter on my MAC and neither will recognize my D700 NEF files. Is there some magic to get them to work?
    Jerry
    Jan 9, 2006
    11. Aug 3, 2008 12:27 AM (in response to (Matic_Kos))
    D700 NEF files work in Lightroom 2 (release version) and also Camera Raw 4.5 (release version).
    You may not have installed it properly the path is:
    /Library/Application Support/Adobe/Plug-Ins/CS3/File Formats/
    Replace the plugin in that folder and restart Photoshop.
    For more support try the ACR Forum
  • MadManChan2000 Adobe Employee 2,707 posts since
    Apr 4, 2008
    12. Aug 3, 2008 3:15 AM (in response to (Matic_Kos))
    Jerry, when you run the DNG Converter, there is an "About DNG Converter..." button in the lower-left corner of the dialog box. Click it. At the top of the splash screen there is a "version string" as a sequence of numbers. What are those numbers?
  • User 296 posts since
    Apr 26, 2003
    13. Aug 3, 2008 9:44 AM (in response to (Matic_Kos))
    Let's turn this question around in the days of film. Why use third party lab to develop your film? Wouldn't it be better to trust Fuji or Kodak to develop its own image from this film?
    The answer to this is that there were many pro labs kept in business by their clients concerns.
    Matic Kos - 8:48am Jul 14, 08 PST (#4) wrote:
    > True, NX is best for Nikon NEFs, no doubt about that.
    If there were no doubt about that -- people wouldn't be turning to Aperture or Lightroom. NC, NX (and I'm assuming NX2 as well) does a really good job of following a recipe and baking a cake. However where it's weakest is that it lacks the precision controls needed to override the standard recipe. I would argue that makes it better for troubling cases, not necessarily so good for others.
    The NC/NX family is simply another tool in the digital toolbox. Using "Best" to describe it is really pushing the meaning of that term. JMO.
    Sep 16, 2008
    14. Sep 16, 2008 11:40 PM (in response to (Matic_Kos))
    Please help!!
    I have a Nikon d700 and MacBook running Leopard 10.5.4, and am unable to see NEF thumbnails in folders. I can open NEF's in CS3 without a problem, but I need to be able to see the thumbnails when look into folders.
    Any thoughts?
    Thank you very much
  • Calculating status... 24 posts since
    Aug 2, 2008
    15. Sep 17, 2008 1:57 AM (in response to (Matic_Kos))
    apple (up to 10.5.5) has not adapted D700 NEF's yet
    so you will only see them in apps like NX2 or LR2
    Sep 17, 2008
    16. Sep 17, 2008 4:15 AM (in response to (Matic_Kos))
    Apple released RAW support for the D700 late yesterday via software update as well as support for a few other cameras. You can get the camera raw update via the Mac's software update feature in the finder.
    Cheers!
    p.s. this was a separate update, not included with the OS update.
  • User 24 posts since
    Aug 2, 2008
    17. Sep 17, 2008 11:42 AM (in response to (Matic_Kos))
    thank you for the tip!
