>In 10.5 Apple has pulled back support for "No CM"
Not when using PSCS3 or LR1.4.1. Or, just the "Print Setting" one time in LR2. Or any other app. Only in LR2 and PSCS4 is there no support? With some printer driver? That is the big question.
>But for most current drivers Printer Manages
color should provide identical results as No CM; with the appropriate
driver settings.
This is my test with the Canon driver.
DYP, "LR2 Print bug now in PSCS4" #68, 11 Nov 2008 3:00 pm
>You can either use Let Printer Manage color, or better I think, select Adobe RGB (1998) as the working (printer) space when using Let Photoshop Manage color. Then use ABW.
Yes you could build a profile on top of that, then assign it in ABW.
But the problem still arises because Adobe has chosen to control some aspects of the printer drivers. This may work for some printer/driver/OS combinations but not all.
