I have the same problem using InDesign and Photoshop together. When I place a .psd-file in Indesign and option + click on it the image opens in Photoshop. When I try to save it, from time to time I get the message: "could not save ... because the file is already in use or was left open". When I close the Indesign-document I can save the PSD-file.That's not normal.
I get such messsages since CS2. I'm on a mac OSX 10.5.8
Folks, you've identified that some OTHER application has the file open. That's why Photoshop reports the error message.
Now please tell the folks working on that OTHER application to fix the problem that has them keeping the file open unnecessarily.
Photoshop can't fix code in other applications.
Sigh.
Photoshop is showing you that message because SOME OTHER APPLICATION has the file open. (the message wouldn't make any sense at all if Photoshop itself had the file open, even if you ignore the fact that Photoshop does not leave files open)
You identified InDesign as being the culprit -- for some reason InDesign keeps the file open when it has been placed.
Now you need to ask in the InDesign forum if there is some way to avoid that, or if the InDesign team can fix the bug.
Again, this is not a Photoshop problem in any way.
Photoshop is just reporting an external problem to you - caused by some application other than Photoshop.
Now that you have identified which other application is causing the problem for you, you need to let the folks working on that application know about it and see if they have a fix, or can fix it in an upcoming release.
Hello i have similiar problem.... I tried to save the file with other nam. in other directory...but not success...whenever i am trying to save it will pop up a message displaying could not save because the files is reade or in use..... and will create a file named something like this. ~psBB72.tmp... Please any solution... thanks
Updated to Snow Leopard. Have never seen this problem, but now it happends all the time. I have deactivated Spotlight on my documents and scratch disks, but it still have the same error.
This is when i create a new file (after saving one time of course), not an old file. It seems like a 10.6 bug. But it's darn annoying.
There is a problem with both Photoshop and InDesign, then we can blame wich ever it is.
1. I open a .psd file in Photoshop CS4 by double clicking it in Bridge
2. This image is placed on a page in a open InDesign document.
3. Doing some changes in Photoshop on the image.
4. Trying to save and get this error message (this topics subject)
5. Deleting the image from the page in ID doc, it is the only one in the document.
6. Can't still save file.
7. Closing ID completely and now I am able to save the file.
I tried turning of Live preflight in Indegisn but that didn't help.
So probably the fault is InDesign or the MacOS. I didn't have this problem with CS3. It is a stupid problem because this type of workflow is pretty common and one would expect it to be solved by now.
Jan Suhr
Stockholm, Sweden
Ooops...looks like Apple recreated the psiicon.dll and the aiicon.dll problem that plagued Windows users for years and that will still bite them in Windows 7 if they have the thumbnail view turned on for their folders...
Mac users...try using list view instead of cover flow, check to make sure you don't have something open in Expose or Spaces (you might and you just don't remember it)...at least Mac users can do a Save As...Windows users are just screwed as there is no way to do a Save or Save As once you hit the Microsoft bug...
It's an annoying Photoshop/Lightroom 2.5 bug for me. From LR, I edit an image in Photoshop and save it. A .tif is automatically created. I can jump back into Lightroom where the new Tif file shows up beside the RAW file. Now if I go to edit the Tif file in Photoshop again, I get the message when I try to save it a second time. I must shut down LR first and then I can save it. Very annoying. I'm on OSX 10.5.8
Could not save (file name) because the file is already in use or left open."
Hi Chris Cox and Folks,
In regards to this saving problem which I have as well:
I don't have any other programs open and no other programs are using these files that I am having problems with.
I also am not using Quark or Indesign. I don't have bridge open.
Only have Photoshop 11.0.1 open on a Mac Pro Tower, 2x2.8 GHz Quad-Core Intel with 10 GB 800 MHz DDR2 F8-DIMM running OSX 10.6.1.
This problem started for me when I upgraded to Snow from Leopard.Could not save (file name) because the file is already in use or left open."
Any suggestions would be very appreciated. Thanks
Marc
My first guess is that Snow Leopard is holding the file open while (or after) gathering metadata or creating a thumbnail.
This has happened in previous MacOS releases, and Apple has fixed it soon after being notified.
Is the folder containing the file open in the Finder?
Chris
I haven't been aware if the folder containing the file has been open on the desktop but I just opened a folder containing a new document I made and will be working on it tonight and let you know if I can repeat the error.
Also I will check next time the error happen is that file is open on the desktop.
Marc
Chris
Been working on a 334.1 meg file for the last 2 hours and have been able to save until now. I didn't change anything. I do have the folder where the file is, open in the background on the desktop but it's been that way since I started.
Being that I need this file for a job, I renamed it and saved it to the same folder.
I have Mail, Itunes, Safari, Address Book, Photoshop, Bridge, Lightroom, Spamsieve, quickkeys, preview open in the background.
Marc
Chris and all,
The problem still exists. I am running a brand new mac tower with snow leopard and all the updates, Photoshop CS4 and it still
gives that error message. I can do a file save as for a workaround and eliminate the original file, however when saving a jpg the
file is degraded each time you save it out. Hopefully whoever need to fix this bug does so. It is really annoying. Period!
Thanks for your posts. I would love to hear of a solution if one ever comes.
best regards
marc
I'm having this problem as well. In addition to that, I'm also getting a "File has changed since last save" errors (don't have the error in front me so don't know the exact message). Not at the same time of course... I'm just pointing out I'm getting two strange file related errors. This is all happening since moving to Snow Leopard.
And, to make clear, the file is NOT open anywhere else when getting the "open" error and the file had NOT been changed when getting the "changed" error.
Chris,
I noticed that this problem has been around though several versions of Photoshop and several versions MacOS. You responded to my last inquiry November 2nd and I was wondering if your QE had time to look at this problem yet?
I only have this problem with Photoshop files and no other applications or programs.
Looking forward to your response!
Marc
We have looked into it, and reported the issue to Apple (when it is their problem).
We have also reported the issue to the Bridge team (who fixed their problem), and a few other product teams.
This has never been a bug in Photoshop.
Photoshop actually tells you about the problem instead of failing or screwing up your files.
And some other applications (and OS components) aren't good about cleaning up after themselves...
