Home/Support/
Forums
1223 Views 13 Replies Latest reply: Jan 4, 2012 7:10 AM by ArtifexEt RSS
msabljic Calculating status... 91 posts since
Jul 15, 2006
Jul 2, 2007 7:56 AM
"Unrecognized Windows Sockets error" message
I have the following problem with Flex Builder 3, when i run application (i get the same error for various applications) in debug mode most of the time i get the following error:
"Unrecognized Windows Sockets error: 0: JVM_BIND"
Why is this happening, can someone help me solve this problem?
thanks
  • kazcoling Calculating status... 2 posts since
    Mar 2, 2007
    What is the version of the flash player(plugin) you are using?
    Could you also let us know if you are using the standalone or the plugin version of Flex Builder? If it's plugin, could you let us know what is your JVM version is?
    Kazue
    Flex Builder QE
    Adobe Systems
  • August_Gresens Calculating status... 7 posts since
    Jul 11, 2007
    Hello
    I'm having the exact same problem with Flex Build 2.0.1 on Vista.
    I get this message only after running the debugger once. The first time it works, the second time I attempt to run in debug mode, I get the error message.
    It seems that the flash player is holding onto the socket. I upgraded the debug version of Flash Player from r28 to r45 and the same problem happpens.
    This also prevents the debugger in the Flash CD3 IDE from working - I get a similar message that the socket needed to debug is not open.
    I uninstalled Java 6 and the problem also happens if Eclipse is running under Java 5 (1.5.12).
    This is a REALLY annoying problem as I have to keep restarting Eclipse if I want to use the debugger.
    August
  • George Comninos Adobe Employee 21 posts since
    Jul 11, 2007
    Hi August,
    Can you try running TCPView and give us a dump of the output before and after the first debugging session?
    You can download TCPView here:
    http://downloads.sysinternals.com/Files/TCPView.zip
    thanks!
    George Comninos
    Computer Scientist
    Adobe Systems Inc.
  • August_Gresens User 7 posts since
    Jul 11, 2007
    George
    Here's my dumps!
    Here's a synopsis of what I see running it in real time:
    When I start debugging, these connections are opened:
    TCP August-Notebook:7935 August-Notebook:0 LISTENING
    TCP August-Notebook:7935 localhost:49346 ESTABLISHED
    TCP August-Notebook:49346 localhost:7935 ESTABLISHED
    Right after I stop debugging, these connections go into various states
    TCP August-Notebook:7935 localhost:49346 CLOSE_WAIT
    TCP August-Notebook:49346 localhost:7935 FIN_WAIT2
    After about 30 seconds, the connections change to this state:
    TCP August-Notebook:49346 localhost:7935 TIME_WAIT
    Subsequent attempts to debug result in the JVM_BIND Error.
    -------------- FULL LOGS --------------------------------
    Before Debugging:
    TCP August-Notebook:http August-Notebook:0 LISTENING
    TCP August-Notebook:epmap August-Notebook:0 LISTENING
    TCP August-Notebook:8080 August-Notebook:0 LISTENING
    TCP August-Notebook:49152 August-Notebook:0 LISTENING
    TCP August-Notebook:49153 August-Notebook:0 LISTENING
    TCP August-Notebook:49154 August-Notebook:0 LISTENING
    TCP August-Notebook:49155 August-Notebook:0 LISTENING
    TCP August-Notebook:49156 August-Notebook:0 LISTENING
    TCP August-Notebook:49157 August-Notebook:0 LISTENING
    TCP August-Notebook:4664 August-Notebook:0 LISTENING
    TCP August-Notebook:5354 August-Notebook:0 LISTENING
    TCP August-Notebook:49158 localhost:49159 ESTABLISHED
    TCP August-Notebook:49159 localhost:49158 ESTABLISHED
    TCP August-Notebook:49201 localhost:49202 ESTABLISHED
    TCP August-Notebook:49202 localhost:49201 ESTABLISHED
    TCP August-Notebook:49203 localhost:49204 ESTABLISHED
    TCP August-Notebook:49204 localhost:49203 ESTABLISHED
    TCP august-notebook:netbios-ssn August-Notebook:0 LISTENING
    TCP august-notebook.nycap.rr.com:netbios-ssn August-Notebook:0 LISTENING
    TCP august-notebook.nycap.rr.com:49168 el-in-f125.google.com:5222 ESTABLISHED
    TCP august-notebook.nycap.rr.com:49250 ag-in-f19.google.com:http ESTABLISHED
    TCP august-notebook.nycap.rr.com:49344 el-in-f91.google.com:http ESTABLISHED
    UDP August-Notebook:ntp *:*
    UDP August-Notebook:isakmp *:*
    UDP August-Notebook:3702 *:*
    UDP August-Notebook:ipsec-msft *:*
    UDP August-Notebook:llmnr *:*
    UDP August-Notebook:49160 *:*
    UDP August-Notebook:49162 *:*
    UDP August-Notebook:49195 *:*
    UDP August-Notebook:49196 *:*
    UDP August-Notebook:ssdp *:*
    UDP August-Notebook:49721 *:*
    UDP august-notebook:netbios-ns *:*
    UDP august-notebook:netbios-dgm *:*
    UDP august-notebook:ssdp *:*
    UDP august-notebook:5353 *:*
    UDP august-notebook:49719 *:*
    UDP august-notebook.nycap.rr.com:netbios-ns *:*
    UDP august-notebook.nycap.rr.com:netbios-dgm *:*
    UDP august-notebook.nycap.rr.com:ssdp *:*
    UDP august-notebook.nycap.rr.com:5353 *:*
    UDP august-notebook.nycap.rr.com:49720 *:*
    During Debugging:
    Right After Debugging
    30 Seconds After Debugging
    August
    Jul 11, 2007
    Hello? Any clue as to what's causing this? Anything to try? Still a BIG problem for me.. Thanks, A
    Jul 11, 2007
    Ok, let me know if there is any other information I can provide for you. Thanks, August
  • Spirala Calculating status... 1 posts since
    Jul 5, 2007
    So, nothing?!?
    My story is something like this: I installed NOD32 because I had problems with a virus attaking my Yahoo Messenger and after doing a full scan of my hard drives I get same pb as you guys. First it's working to do my debugging. When I close the debugging session and start it again the error occurs. I have to mention another thing that I just remembered: when I started first time Flex after all the scanning, Windows asked me if I want to unblock the connection! - maybe this is it. I hope someone will see this and post here the solution!
    Jul 11, 2007
    The problem is with NOD32. If I remove NOD32, then the debugger works - so this is not an issue with Flex. A
  • Shtong Calculating status... 1 posts since
    Nov 5, 2005
    For those how are having this problem, it seems that the beta version of the next release of NOD32 fixes this issue. You can download it at http://www.eset.eu/download/beta
  • fzhu@avoka.com Calculating status... 1 posts since
    Jul 21, 2010
    I am having the same problem. I reinstalled flash debugger a few times. Not sure what's happening.
  • ArtifexEt Calculating status... 1 posts since
    Oct 6, 2009
    Same problem, flex builder 4,6 windows 7 64 bit
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
