Is Adobe Gamma not installed with CS3?
Apr 17, 2007 Apr 17, 2007
It is not in the control panel on a clean CS3 install. Has Adobe stopped including Adobe Gamma in the CS3 installations?
35.5K
Adobe
Guest
yikes! i hope it's there!
Remember that you have to view CP in Classic Mode. Also (wild guess) you may need to have administrative rights.
Rob
Control Panel is in Classic Mode already, it just isn't there anymore.
It was there when I had CS2 installed and worked normally. Uninstalled CS2 for clean CS3 install - now there is no Adobe Gamma?
I don't know. My copy of Ps CS3 will be in the local store here by April the 30th.
Apart from that, I switched to a hardware calibrator (GMB Eye-1) long ago, and they'll have to pull it from my cold, dead hand.
Rob
I use Eye-One Display 2 at my office for calibrating and profiling LCD monitors, but I use Adobe Gamma on the road to 'ballpark' the projectors I use for speaking events.
I really need my Adobe Gamma!
Try to find a way to use the one from the previous version. Maybe install that again.
Versions of Ps install in separate folders, and up to now, could all be launched at will.
Rob
Give a look see in Programs-->Common Files--> Calibration-->Adobe Gamma. Maybe it's there and for some reason didn't make it to Control Panel.
Andrew
Good point, Andrew!
No, it is not there either.
Of course on my CS2 computer, it is there and in the Control Panel.
I'm guessing that Adobe is finished with Adobe Gamma and this is how we all find out.
If I manually add the Calibration files to the CS3 computer, Adobe gamma will load and work, but it will not install the loader for the startup menu. ?
Guest
It would make some sense to have removed AdobeGamma as it isn't suitable
for LCD Monitors which are by far the most common now.
Apr 24, 2007 Apr 24, 2007
If you are running Vista look in here:
c: \ program files \ common files \ control panels
there you will find *adobe gamma.cpl*
copy this to your windows \ system32 folder and it will appear in you control panels list.
Not there on my Vista Ultimate machine with CS3. It *was* there when I had CS2
installed, though.
Charlie...
http://www.chocphoto.com
No question, I can (and did) manually add Adobe Gamma, but my question was - has Adobe stopped installing Adobe Gamma with the release of Photoshop CS3?
Guest
> It would make some sense to have removed Adobe Gamma as it isn't suitable for LCD Monitors which are by far the most common now.
Well that doesn't make sense to me.
Firstly there are still CRTs out there, and secondly Adobe Gamma does work on some LCDs.
Having said that, it is pretty ancient but, if that were the reason to remove it, it should be replaced.
Maybe a bit more Adobe cost cutting, to go in line with their price increases. :(
Guest
surely not collusion with the calibration manufacturers... :)
Contributor ,
Adobe Gamma is no longer distributed with Photoshop. Many experts argue that visual 'calibration' doesnt really exist and give a false sense of security (every person sees slightly different etc), plus the fact that it is not suitable for LCD monitors.
You are expected to buy a hardware calibrator. Like it or not.
Personally, I'd have to say that Adobe Gamma was better than nothing. Hardware calibrators are not cheap.
If you are an amateur, use a CRT monitor, and dont want to spend money on a hardware calibrator, try QuickGamma (I have no experience with this, but it comes recommended by others).
Enthusiast ,
Mathias,
Though 100-200 euros can pay more than a pair of beers anywhere, I don't think that's way too expensive for a professional tool like Photoshop.
Contributor ,
I dont think so either, but factor in the number of Photoshop users, and how many of them are actually going to buy a hardware calibrator. Are we better or worse off as a whole?
I dont know.
Enthusiast ,
I understand what you mean: Better Adobe Gamma than nothing. But, if I follow your reasoning (and I think I do), I'd hope that we would be better off in a general sense if general users would start thinking more appropriatedly about what is colour reproduction. That means no eyeball, use a calibration device, use a proper illumination, etc...
Hyperoptimistic, I know ;)
Guest
so not only are they charging us more (even for the standard version, don't get me started about the extortion edition!) but now we don't have imageready (buy flash!) and we don't have a calibrator (buy external). jeez louise!
maybe they're developing adobe gamma into a for pay application... wouldn't suprise me.
Contributor ,
Dave,
I think you are missing the point. Software calibration is not calibration. Really, it isn't. Now we just need to educate the whole user base save for the top pros on this.
Enthusiast ,
Microsoft rulez the World
Adobe sees it for you
X-Rite calibrates that vision.
Surrender, Dave. Resistence is futile!
well in answer to the original quesion: NO, Adobe still distributes AdobeGamma with CS3. I told you how to find it. It's just not installed (for whatever reason, I thought it mught be due to Vista)
And whats this crap about gamma correction NOT working on LCD's? what rock have you been living under?. I bounce from office to office doing temp contracts, and first thing I do is calibrate everyone's monitors using Adobe Gamma, you wouldnt believe the results. If you can more closely match the colour onscreen to the printed output then there's bugger-all guess work involved.
Sure most LCD's dont have the rich black of a CRT, but every monitor can benefit from some gamma correction and colour adjustment. Maybe you just have no idea how to use the program...
That's really strange - I did a fresh install of Vista (formatted too) and only installed CS3. the file was there.
