ESC::
ifWinExist, ahk_class Photoshop
IfWinActive ahk_class Photoshop
SendInput {ESC}
} else {
SendInput +{ESC}
return
Wow, two years since I posted this bug and since then it still sits inside the very heart of Photoshop. Damn, Adobe what about actually doing something about this problem?
I can confirm that:
IT IS NOT RELATED TO ATI CATALYST DRIVER
IT IS SOLELY BASED ON WHETHER ANYTHING EXISTS INSIDE THE PLUG-INS FOLDER
So, if the Plug-ins folder has any of these preinstalled folders inside them, the ESC problem appears.
3D Engines
ADM
Automate
Digimarc
Effects
Extensions
File Formats
Filters
Image Stacks
Import-Export
Measurements
Panels
Chris Cox: It is DEFINELTY A PROBLEM, SO DO SOMETHING ABOUT IT! And please create the bug report for us, based on this thread. You know, we are the - angry - customers and you are the one, who gives the service. So, be quick about it. Thanks!
I'm having the same problem and what I can't understand is the callous attitude of the last two responses on the forum and Adobe's additude of indifference toward the issue.
I tried calling support at one point and was not so politely told that because I was running 64-bit Windows, my issue wasn't supported in CS3 and that I should upgrade to CS4. It takes an impressive level of chutzpah to tell a customer to spend more upgrading to a version that won't fix their problems, especially when the issue has been reported for both 32-bit and 64-bit versions of Photoshop.
Will I be ridiculed here on the forums for pointing this out like the last poster? Is it really that crazy to ask Adobe Support to, you know, support their products?
Not all 32 bit software will run (or correctly run) on a 64 bit system. The software may be pointing to a x86 folder to find something to run with but if the needed item is in Syswow64 folder it will either not run or it will have issues. Also the dll in the Syswow64 folder may match by name but it is written differently thus won't run when called up. Simple example but that is just the way it is.
Have you even read this post and the issue it's regarding? People with both 32-bit and 64-bit are having the problem where their escape key doesn't work anywhere else in the O.S. when Photoshop is running. And people with both Photoshop CS3 and CS4 are having the problem. And of course it was first reported nearly 2 years ago... Not that this apparently matters to anyone at Adobe.
