Error when installing CS4
Oct 20, 2008 6:18 PM
When installing photoshop CS4 for the first time i get an error, I start the setup then i select to install Photoshop with adobe bridge and when i click install the process begins and when it's almost about to finish i get the following error:
Installation Error:
An error has ocurred when installing the following components:
Adobe Photoshop CS4
Then i click the see more information of this error i get:
Adobe Bridge CS4
Error:
Error 1603. Severe error during installation.
Hope someone can help me, Thanks in advance.
Replies 1 2 Previous Next
    Oct 20, 2008 10:50 PM   in reply to (Danilux)
    Hi Danilux
    you might try out the following URL's for the solution of this problem.Seems to be a Miscrosoft Installer Issue.
    http://consumerdocs.installshield.com/selfservice/viewContent.do?exter nalId=Q111019&sliceId=1
    http://kb.adobe.com/selfservice/viewContent.do?externalId=rb_1603
    Oct 21, 2008 2:53 AM   in reply to (Danilux)
    What other Adobe programs are/ were on the system? With what user privileges do you install? The message would indicate that in fact the files were installed, but the licensing system could not be established...
    Mylenium
    Oct 21, 2008 12:22 PM   in reply to (Danilux)
    I had the same error messages as Danilux. I have vista ultimate 64 with Photoshop CS and CS3 upgrade installed. I deleted CS3 and used the CS3 removal software to remove the remaining CS3 in the registry. I went to install CS4 Extended and about 90% finished it stopped loading with the same errors. Rebooted computer and tried again and it gave me a error message of stop loading. It also told me I could not run 2 installs of the software at the same time. Called tech support and spent about 6 hours on the phone with 4 different people. We tried everything and they were at a loss. So after I hung up I looked at my registry and searched Adobe and CS3 and still found left over stuff. Some I could not remove. So I said screw it and re-formatted my hard drive and reinstalled Vista. Did all the vista updates, card drivers and such then I installed CS. Rebooted and defraged. Re-installed CS4 with no problems. Then re-installed my other software. Been running perfect since. My guess is that I borked my system myself trying to fully remove CS3.
    A lot of people don't like to re-format and start fresh. But from past problems I find it a lot easier and faster to start from scratch.
    Oct 22, 2008 4:47 AM   in reply to (Danilux)
    I can't seem to get past the following error when installing photoshop cs4 upgrade on xp.
    Adobe CMaps CS4
    Error:
    Error 1603. Error 1714.The older version of Adobe CMaps CS4 cannot be removed. Contact your technical support group
    I've disabled McAfee, uninstalled Google Desktop, and cleaned my registry. I do have cs2, cs3, LR1, and LR2 installed. I also looked in the knowledge base and faq, but haven't found a solution.
    I the installation log files I see a number of messages like the following related to CMaps
    10:43:1:468 -(Adobe)- -*-*-*-*-*-*-*-*-*-*-*-*- BEGIN - Adobe_9f8d2b5c97c6c0aef753b74334b03987_WP_Symbol -*-*-*-*-*-*-*-*-*-*-*-*-
    10:43:1:468 -(Adobe)- Checking local file: C:\Program Files\Common Files\Adobe\TypeSupport\CMaps\WP-Symbol
    10:43:1:468 -(Adobe)- No local copy available
    10:43:1:468 -(Adobe)- -*-*-*-*-*-*-*-*-*-*-*-*- END - Adobe_9f8d2b5c97c6c0aef753b74334b03987_WP_Symbol -*-*-*-*-*-*-*-*-*-*-*-*-
    Any advice would be appreciated.
    John
    Oct 22, 2008 9:52 AM   in reply to (Danilux)
    @David: sounds like another tool never finished installing. Some programs that require a restart after install will finish their installs using a registry key, but obviously this sometimes fails. could be something as trivial as an Updater for a virus scanner or something. Anyway, since you have nuked your system and could resolve the issue, no need to add more fluff to the discussion from my end... ;-)
    @John: Manually removing registry entries is not advised. It will definitely render your licensing system defunct and in addition may lock up files, which is probably what you are experiencing. You should uninstall your broken install of CS4 via "Add or Remove Programs" again. This should reset all config data and only leave "released" files in place. On a whim, you could try to unregister your installer packages using the CS4 clean utility, then manually remove the CMaps directory. This also applies to the CS3 install, as CMaps is a shared component found in Program Files/Common Files/Adobe. Attempting another install after that should get you up and running.
    @Danilux: Could you provide the last few lines from the install log like John did? this might help. I'm still not feeling this magic tingling in my left toe and have no idea what could cause your error.
    Mylenium
    Oct 22, 2008 10:49 AM   in reply to (Danilux)
    Hi Mylenium,
    Thanks for your suggestions. I ended up uninstalling CS2 and old versions of 1.x LR. I also ran the repair option using the CS3 installation cd.
    After that I was able to install CS4.
    John
    Oct 22, 2008 8:11 PM   in reply to (Danilux)
    Hi Mylenium,
    Thanks for the info. I did shut everything off like defender, fire wall and such before the install. However, I did not check Task Manager to ensure they were not running behind the scenes. But life is good once again and CS4 runs perfect. Thanks for responding.
    Oct 29, 2008 6:09 PM   in reply to (Danilux)
    can't beat that for troubleshooting! when things get weird, the busy get formatting! :)
    Oct 29, 2008 11:57 PM   in reply to (Danilux)
    Going on day 8 since I nuked my hard drive and CS4 is still running great. Can't blame those poor tech support people. They are just reading off of cards. My problem was not on their cards. 6 hours with them on the phone was enough for me.
    Mylenium was correct about the registry restart. I shut my computer down 2 times to try and stop the install box from coming up. However, the box still kept telling me I was trying to install the software while another install was in progress.
    I deleted the registry keys in HKEY Current. However, there were several other duplicate entries in LOCAL, USERS and CURRENT that refused to be deleted. This was even with me logged in REGEDIT as ADMIN.
    System restore was useless too. The regestry entry were still there.
    CS3 had a regestry cleaner to clean up. CS4 didn't.
    I didn't have the time to mess around so I reformatted.
    Everything is still good for me.
    Nov 3, 2008 10:13 PM   in reply to (Danilux)
    nice! fingers crossed!
    Nov 28, 2008 1:11 PM   in reply to (Danilux)
    I just got this also.
    I do not intend to uninstall CS3 as this is a trial, so if I remove the cmaps directory, this will impact Cs3 ops?
    Nov 28, 2008 2:16 PM   in reply to (Danilux)
    This is the most outrageous installation package I have ever worked with! I can install a National Instruments VI program which is far larger than PS with absolutely no problems and no problems running it. This NI program will allow me to instrument highly sophisticated instrumentation packages, configure everything with aplomb. What do I get here? First, Downloading problems. I finally get past that and along comes error 1603, 1714. Checking here, I find that I actually have to uninstall a partially installed package, which is now date stamped and time stamped, so that whatever time I now take to fix installation will most likely cost me at the other end. And the other end is not in sight!
    Then I have to look forward to possible operational problems as I progress, if I can progress.
    I started at 9 AM. It is now 2 PM. 60% of a working day blown with trying to install this stuff.
    I'm not at all convinced that I will ever need anything beyond CS3 at this point. With all it's warts, it install and runs.
    Oh, and by the way, the CS4 cleanup script link doesn't work.
    I do this sort of work for a living (validating software)and if this would be the best results I could expect from my efforts, I would run like hell away from my job.
    Nov 28, 2008 3:54 PM   in reply to (Danilux)
    if your cs3 is working larry, and you NEED it to do work (and i know YOU do, unlike me), i'd let the trial alone until adobe works some of these "gotchas" out of the system. personally, i'm not upgrading until something definite comes out of adobe and i start seeing reversals of some of these horror stories...
    i've been tempted to do the trial, sorely tempted, yes sir, but every day reading here sees more and more of this stuff. this is the 1st time i haven't upgraded on day 1 of the release in a long long time. actually, 1st time for me ever as i started my full version with version 6 and upgraded on release day for every release since then.
    Nov 28, 2008 5:49 PM   in reply to (Danilux)
    Larry, what Dave said. Stay away! CS4 is not ready for prime time.
    Nov 28, 2008 6:16 PM   in reply to dave milbut
    But...if you have any intention at all of upgrading then why wait? Will <br />you have problems? Maybe, but there's no assurance of it and what if <br />Adobe issues a dot release in the next couple of months and people are <br />still having problems?<br /><br />Will you still wait? Will you skip it completely and wait for CS5?<br /><br />All I'm saying here is that you could well be missing out on a great <br />release. You above all should know that this forum is always filled with <br />issued. Many of them legit, some of them user error.<br /><br />But downloading and checking out the demo isn't going to hurt anything <br />especially since I know you're just itching to blow out the XP box and <br />install Vista 64. <g><br /><br />Bob
    Nov 28, 2008 8:15 PM   in reply to (Danilux)
    You can't miss out on something that doesn't install, Bob. 64 bit will enhance the speed of certain filters, but checking out what I would really find useful should also be obvious at 32 bit.
    I've copied it to a thumb drive and I may try it on an i7 system Vista 64 I have access to. Also, I have access to a Core 2 system albeit 32 bit. Dual boot so we can try a download the owner has done and mine, to see if there are d/l issues getting in the way.
    Thanks Nick, dave, for the support. I deal with somewhat similar issues at work, but I have a coterie of software guys who actually come up with fixes. Well, most of the time! :D
    Nov 28, 2008 9:35 PM   in reply to (Danilux)
    Oh, and another thing. Adobe Support Advisor? It popped up when I tried to check out the error. However, it would not install. Said I needed Flash 9 Active X . Guess what I have on this computer?
    But wait! There's more! In the pdf that comes with CS4, it also refers to this Support advisor, and the link works. The damn thing installed!
    Nov 29, 2008 5:39 AM   in reply to Hudechrome-sd9sPI
    That's absolutely correct, but you won't know unless you try. And it
    would be great if someone like Dave did.
    It's one thing to have people who don't know a CPU from a video card
    screaming "Photoshop Sucks!" and another to have well informed people
    that can calmly help in the troubleshooting.
    Bob
    Nov 29, 2008 8:01 AM   in reply to (Danilux)
    >And it would be great if someone like Dave did.
    :) things being what they are, i'm sticking with cs3 for a bit. i'm wondering if my system might be under-powered. xp32, core2duo e6600, 2 gig ram, nvidia 7600gtx. but i don't really have any plans to go to vista 64 and according to chris, seems that's where the better ps4 experience is. i'm still on the fence. i probably WILL do cs4 soon, but probably not vista. and i'm more concerned about this update than i've ever been before.
    > and another to have well informed people that can calmly help in the troubleshooting.
    on the off chance that i do install it and don't have problems, i don't know how much help i could be except to be another voice in the wilderness going "works for me". or if it does fail, what would be the point of subjecting myself to the screaming mee-mees if a patch is going to be what it takes to fix it?
    most likely once the christmas shopping for the kids is done and paid for, i'll take a chance. (there's also the "locked into extended edition" issue for me to think about. wasn't that supposed to be corrected according to nack? i wonder if anyone talks to anyone internally anymore sometimes... very sad.)
    Nov 29, 2008 8:25 AM   in reply to (Danilux)
    Weill, I'm not getting any "calm help" here, and I do this kind of work in my job.
    I did an extensive search for Errors 1603 and 1714 and found little to be of any help.
    So, I'm back to this:
    CMAPS exists for CS3 which can be deleted. If this is the culprit and I delete it, what happens to the functionality of CS3? If this isn't the correct cmaps where is the elusive "older version"?
    Nov 29, 2008 8:30 AM   in reply to (Danilux)
    ok. since bob publicly shamed me. i'm downloading the trial. hopefully i'll be in the "working fine" group, but i doubt it.
    bob, if this effs up my system, i'm coming back to jersey this weekend to slap you around!!! :P ;) :)
    Nov 29, 2008 8:37 AM   in reply to (Danilux)
    issue 1. what's with the stupid downloader you apparently HAVE to use to get the trial? <br /><br />I already have a downloader. it's called a web browser (foxy!). you should NOT be forced into downloading and running an exe off the internet in order to download another file when every computer on the internet already has that capability inherent. sounds like someone didn't want to waste their partnership deal with akamai, the download manager supply people.<br /><br />the number 1 rule is "KISS"... we all know what that means right? the fewer moving parts the better. why would you put your product (adobe) at risk of a third party problem (akamai, in this case) unless you ABSOLUTELY have to? there should be an option right next to the download manager option to "download straight" from adobe's ftp servers, or wherever you want to store it. <br /><br />so now i have to download and run this 3rd party app. why? i dunno. but i bet it's also going to want to connect to the inter-tubes and i'm going to have to let it though my firewall. <br /><br /><the red queen>we are not amused!</the red queen><br /><br />47% dl and counting...
    Nov 29, 2008 9:15 AM   in reply to (Danilux)
    so far ~15 minutes to extract, after a hang of about 10 minutes at 34% where the interface on the extractor stopped responding/updating (went blank white and sat there), it started again. it's now been at 35% for the last 3ish minutes. i have a suspision that if i cover it up with another window and move it back, the interface will be frozen again... ;) lets test... :)
    yes. it's back to not updating... :)
    whee! :)
    keep in mind that a full cs3 extended install takes about 15 minutes on my system.
    Nov 29, 2008 9:16 AM   in reply to (Danilux)
    whoa! cooking now... up to 53% extracted...
    Nov 29, 2008 9:21 AM   in reply to (Danilux)
    well, walked away for 5 minutes and it's gone. is it done extracting? i dunno. i'll look in the folder, but a message to that effect would be nice...
    Nov 29, 2008 9:22 AM   in reply to (Danilux)
    I hope you are not writing on the same computer and Internet connection that is accepting the D/L. I wondered about that here, as I was doing exactly that, along with my SO doing her thingy over the Internet at the same time.
    Nov 29, 2008 9:25 AM   in reply to (Danilux)
    looks like it's in the right place. running setup.exe...
    1st thing is it wants access to the "trusted zone". didn't check the port. hmm... ok. granted.
    what again? another trusted zone request. localhost to port 4522... ok. granted again. grr...
    oh. can't continue because firefox is running. nice. ... grr... i'll open notepad and record to there...
    Nov 29, 2008 9:26 AM   in reply to (Danilux)
    yes. SEEMED to go ok...
    Nov 29, 2008 9:37 AM   in reply to (Danilux)
    I'm off to try installing on a dual boot system, two separate downloads. One difference: the current Photoshop there is CS2.
    Nov 29, 2008 9:51 AM   in reply to dave milbut
    > i'm coming back to jersey this weekend to slap you around!!! :P ;) :)<br /><br />I've got a big pot of turkey soup on the stove. I'll save you some. <g><br /><br />Bob
    Nov 29, 2008 9:59 AM   in reply to (Danilux)
    >I've got a big pot of turkey soup on the stove. I'll save you some. <g><br /><br /><homer>arrgglllllgghhh...</homer> :)<br /><br /><hr><br /><br />ok continuing the saga:<br /><br />closed firefox. hit retry. <br /><br />select "run as trial".<br /><br />accept the "uncopyable" license agreement. hint: some people actually read these things. it's kinda a nice gesture to the user to allow them to copy the license language so they can paste it into a program like word pad and change the font to something more readable the standard legal dept licensing's 2pt Beelzebub Semi-Bold. ...<br /><br />now the choice... do i choose "easy install" or "custom"? there's a freaking lot of components to install...<br /><br />I select "custom" but leave all options checked. just in case this gives me more control over things like file associations after the install. oddly enough, i can select and deselect anything on the long list INCLUDING photoshop cs4, EXCEPT for bridge cs4 (ok a lot of the sub components are un-de-selectable too). go figure...<br /><br />ok. go go gadget INSTALL! <br /><br />wait! did it ask me what drive? i don't think so...? it's going anyway. most likely to my c: drive. grr... i wanted to (meant to) select G. user error? probably. maybe...<br /><br />ok walk away for 10 minutes to save my blood pressure. come back and it's hung at about 75% done because now "Adobe AIR" app installer want access to 199.7.48.190 on the internet. WTF?!! ok, again.<br /><br />side note while install continues... i let the adobe installer (cs3) do it's thing weekly, so i should have all the latest components for stuff that existed prior to cs4 release. i wonder if this is going to roll any of them back? <br /><br />looks like it's heading for the home stretch. the progress bars are at about 90% (there's no actual percent reading, just bars going across the install window.)<br /><br />ok. cool. cs4 install complete. looks like everything installed good.<br /><br /><a href="http://www.pixentral.com/show.php?picture=1RySssqZLtL4AJEwUkAa3 Kg5r5AZW1"/><img alt="Picture hosted by Pixentral" src="http://www.pixentral.com/hosted/1RySssqZLtL4AJEwUkAa3Kg5r5AZW1_t humb.jpg" border="0"/></a><br /><br />now, let's take er for a spin... as a good friend mine say: "it's time to put your butt in the pudding!" (it's probably best not to ask WHY he says that... )
    Nov 29, 2008 10:01 AM   in reply to (Danilux)
    as far as i can tell, it didn't, except that it lets you select or deselect components. at this stage, i don't think it would be wise to de-select anything there...
    Nov 29, 2008 10:03 AM   in reply to (Danilux)
    > 199.7.48.190
    note to adobe... not sure if it's meant to be, but directory browsing IS ALLOWED at that address... especially since your robots.txt file is telling search engines not to index it... and there's a lot of certificate and verisign stuff out there. might want to lock that down...
    Nov 29, 2008 10:09 AM   in reply to (Danilux)
    It won't be fun till you do some serious video watching dave. All 77 of them on the Help Page.
    BTW on-line Help is the default option now but it's worth it while you're learning.
    Nov 29, 2008 10:11 AM   in reply to (Danilux)
    ok. 1st run. setup screen. select run as 30 day trial... ooh! shiny new splash screen! aaaaaannnnd, it's UP! :)
    Nov 29, 2008 10:21 AM   in reply to (Danilux)
    seems to be choppy zooming in and out... doing it in big square blocks... <br /><br />no rotate view tool... hmm...<br /><br />ah.<br /><a href="http://www.pixentral.com/show.php?picture=1vjOCbuuPjDVLyGRZ0MM7 PBHo8g4X91"/><img style="width:50%;height:50%" alt="Picture hosted by Pixentral" src="http://www.pixentral.com/hosted/1vjOCbuuPjDVLyGRZ0MM7PBHo8g4X91_ thumb.gif" border="0"/></a><br /><br />wow! what a dog! went to copy that error dialog. hit file> new and now it's hanging... 1 minute... ok, it's back. hmm. gonna be a long day i see. guess i'll try my video drivers 1st. <sigh>
1 2 Previous Next
Actions
