mogur2
Update to 11.01 failed twice
Feb 26, 2009 2:01 AM
I just tried to update to 11.01. PS was open the first time, but was closed after the download started the second time. Only my email app-Eudora was open both times.
What now?
    Feb 26, 2009 2:46 AM   in reply to mogur2
    Did you use the updater in PS?
    Go to adobe.com > downloads > updates and pick up the .zip file. Save it and unzip it, and in the resulting folder is, among other things, a Setup.exe. Run that.
    Feb 26, 2009 2:50 AM   in reply to mogur2
    I've been having the same problem, tried it via the CS4 updater and via download then install. Each time I just get the mesaage "update failed to install"
    this is the sum of 6 attempts, yesterday evening and today, fresh installs each time (after wiping the previous attempt)
    My CS4 updater no longer shows an update available but is also still showing that I still have v11.0
    Feb 26, 2009 3:38 AM   in reply to mogur2
    Mogur203 - What error message are you observing and on which operating system ? Close Photoshop while downloading and then try to install again.
    Also confirm if updates posted on Adobe.com > downloads > updates work for you.
    Feb 26, 2009 3:53 AM   in reply to mogur2
    Hi Brian,
    Your both attempts of installing via updates and downloading from adobe.com failed ?
    Please send the logs from following location
    C:\Documents and Settings\"User name"\Local Settings\Application Data\Adobe\Updater6\aum
    and
    C:\Program Files\Common Files\Adobe\Installers\Adobe Photoshop CS4 log file.
    Feb 26, 2009 5:58 AM   in reply to mogur2
    Brian , send the logs at anshum@adobe.com
    Feb 26, 2009 6:12 AM   in reply to mogur2
    Win Vista Home Premium, CS4 + all other progs were closed when trying either via Adobe updater or via download and manual install.
    Previous updates have worked.
    System info:
    Adobe Photoshop Version: 11.0 (11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch])
    Operating System: Windows Vista 32-bit
    Version: 6.0 Service Pack 1
    System architecture: Intel CPU Family:6, Model:15, Stepping:13 with MMX, SSE Integer, SSE FP, SSE2
    Physical processor count: 2
    Processor speed: 2200 MHz
    Video Card: ATI Radeon HD 2400
    Video Mode: 1680 x 1050 x 4294967296 colors
    Video Card Driver: atidxx32.dll,atidxx64,atiumdag.dll,atiumdva.cap,atiumd64,atiumd6a,ati tmm64
    Driver Version: 7.01.01.821
    Built-in memory: 3070 MB
    Free memory: 2032 MB
    Memory available to Photoshop: 1659 MB
    Memory used by Photoshop: 59 %
    Image cache levels: 6
    Serial number: [deleted by forum host]
    Application folder: C:\Program Files\Adobe\Adobe Photoshop CS4\
    Temporary file path: C:\Users\Brian\AppData\Local\Temp\
    Photoshop scratch has async I/O enabled
    Scratch volume(s):
    C:\, 290.6G, 179.6G free
    Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS4\Plug-ins\
    Additional Plug-ins folder: not set
    The only error message I am seeing is "installation failed"
    Feb 26, 2009 6:37 AM   in reply to mogur2
    Somebody kill his serial number!
    Feb 26, 2009 6:49 AM   in reply to mogur2
    At your service!
    Bob
    Feb 26, 2009 6:52 AM   in reply to mogur2
    Que! ?
    Ahh - got it now - hadn't spotted that was included in the data set, sorry (still struggling with CS4 update and getting in a right pother)
    Feb 26, 2009 8:05 AM   in reply to mogur2
    Que sera sera
    [link deleted by forum host]
    Hopefully you've got that thing in use on two computers already.
    Mar 2, 2009 6:31 AM   in reply to mogur2
    An update to my problems:
    following some good assistance from Anshum trying to untangle the problem I finally cracked it the hard way #
    - removed AVG8 from my system (it was treating the Adobe installer as if it were a Trojan and sequestered it away in its vaults somewhere)
    - then re-installed CS4 on top of my original (but corrupted) install.
    A long and boring hassle but problem solved
    Thanks Anshum for you patience and guidance
    Mar 9, 2009 10:46 AM   in reply to mogur2
    Mogur203 - Have you checked your anti-virus/firewall apps?
    How about downloading the update directly from Adobe and try running it. ACR can be downloaded from Adobe and that plug-in changed manually.
    Mar 25, 2009 1:31 PM   in reply to mogur2
    You might be experiencing this issue which has been causing CS4 updates that patch files (instead of replacing them) to fail on some Windows machines. This issue, cause, and solution are documented here:
    http://www.adobe.com/go/kb408524
    Please note that the ACR 5.2 update was susceptible to this issue. We believe the ACR 5.3 is not. However, if a previous update of ACR failed due to the root cause, then it can leave your files in a state which will prevent future update from working, simply because they don't find the files in the expected state. In which case, you need to do the complete solution, which involves a clean re-install (sorrry :-(
    Sincerely,
    Matthew
    Mar 25, 2009 2:09 PM   in reply to mogur2
    > (sorrry :( )
    that means a lot to people affected. thanks matthew.
    Mar 25, 2009 3:06 PM   in reply to mogur2
    They forgot to put in de-activate product before un-install in the KB.
    Mar 26, 2009 9:50 AM   in reply to mogur2
    There is no need to deactivate the product if you are going to re-install it on the same machine. The activation server has a unique ID for the machine, so if it gets an activation request from a machine that's already one of the two allowed activations, it doesn't take another activation slot.
    Cheers!
