See Error:Encoding Failed Could not read from the source
PremiereProPedia
RSS feed)
- Over 350 frequently answered questions - Over 300 free tutorials - Maintained by editors like you |
Forum FAQ |
The knowledgebase article in the link I provided gives you two work arounds. I'm not sure how you missed that.
PremiereProPedia
RSS feed)
Forum FAQ |
Maybe you already found a solution...
I'm on Windows 7 RC1 but had the same problem, deleting the files in c:\users\{user}\AppData\Roaming\Adobe\Adobe Media Encoder\ solved the problem for me.
Make sure to make a backup before. But the files were recreated when I started Encoder again and now everything works as it should.
Yes it happens to me too. I deleted the file "Watch Folder Info.xml" in this folder and it works again
C:\Users\{user}\AppData\Roaming\Adobe\Adobe Media Encoder\4.0
Out of nowhere the AME stopped working. I'm not a computer guy so, to me, many of the requests -by forum regulars- for every little detail about the computer I have, etc, seemed daunting to say the least. Fortunately, I saw the suggested fix by Takyc. When I found that folder I simply renamed it -from 4.0 to F 4.0- and kept the window opened in case it wasn't the answer. I went back to AME, and this time it worked as it always had in the past.
That method is affectionately known as "trashing your preferences".
-Jeff
Jeff
Do you have any suggestions on this "media encoder stopped" ? Do you think it is Windows 7 compatibility?
Just when I thought I was getting the hang of this product....this happens??
I was having the same problem and this worked PERFECTLY! Thanks for the fix!
