Did you change your user folder's location?
PremiereProPedia (
RSS feed)
- Over 300 frequently answered questions - Over 250 free tutorials - Maintained by editors like you |
| Forum FAQ |
I had this problem too -- I originally had CS3 installed, the installed CS4 and uninstalled CS3. Things started getting strange when I uninstalled CS3 -- lost my file associations, had this encoder problem and a bunch of other things. Finally I completely UN-installed both CS3 and CS4, deleted everything out of c:\program files\adobe (the uninstaller left lots of DLLs there), and reinstalled CS4 from scratch. Now everything works great, including the encoder.
Hi Mark,
if you launch AME and then from File>Add Premiere Pro sequence, you choose the Premiere Pro CS4 sequence and add it to AME batch and try to encode, does it work?
Aurobinda.
I am having the same problem (when I click ctrl-M to open AME for render, then click "start queue" AME goes into hang and eventually states "Not Responding"). I just tried the method above, and when I got the window for selecting the project file to import, the same thing happened (unrecoverable hang). I am running Win 7 64 bit (edit: just remembered this is a Vista machine, all current service packs and updates though), and my machine is 8 core with 12GB Ram and a dedicated vid card, so plenty of power and speed.
Edit: running Premiere CS4.2.1 (AME is CS4, but I can't tell you which one, but it is currently hanging... like most of the time)
