>>> I'd love to have them on my PPC (Cingular 8125; Moblie 2005 on the phone). I have a 2GB SmartCard in the phone, and that's where I'd put at least the manuals. <<
The pdf content can always be placed on the storage card... not sure about protected ebook contents since I don't do drm.
>> Does anyone know if I can install to the Card and have it work, and will I be able to read books I place on the card even if it turns out I have to install Reader on the phone proper? <<
I have had no problems installing reader on the card... see http://BevHoward.com/bhhpj.htm#Cabs for more information including cabinstal for some tips...
...of course, ppc reader is the exception... it needs to be installed via activesync since a "tagger" is installed on the pc which will _attempt_ to tag untagged pdf files.
However, you can run the pc install with the ppc disconnect, then search and find the cab file on the pc, manually copy it to the ppc and use cabinstal to put it where you want it.
Finally, the tagger only tags the files synced to the ppc (the originals are not modified) so, if you use the tagger, sync, then copy the tagged files to the memory card after the sync.
Beverly Howard [MS MVP-Mobile Devices]
