Locked
Setting Adobe Reader 9 as default PDF reader for IE7
Feb 14, 2009 Feb 14, 2009
I made the mistake of installing Foxit Reader on my new PC and am trying to stop Internet Explorer 7 from using it as the default pdf reader instead of Adobe Reader 9.
By re-installing Adobe Reader 9 the problem with Windows Explorer using it was solved but Internet Explorer still keeps trying to open PDF files using Foxit Reader.
When installing the Foxit Suite the installation was not 100% successfull on Windows Vista 64 bit with the Uninstall.exe file not being created and the program not being listed under add/remove programs.
Does anyone know how to set Adobe Reader 9 as the default PDF reader used by Internet Explorer 7.
Thanks for any advice.
Goggs75
229.2K
You should be able to go Control Panel > Folder options and change the default program to use for files with a pdf extension.
Feb 15, 2009 Feb 15, 2009
Hi David
I do have the default program for pdf files set to Adobe Reader 9 on Windows Vista Home Premium.
The process the computer goes through when trying to open a pdf file using Internet Explorer 7 is initially to try to open it using Foxit Reader with windows security allowing me to block this then automatically opening it using Adobe Reader 9.
Goggs
I am not the most IE savvy person as my main browser is Opera. However, try this: in IE, choose Tools > Manage Add-ons. From there, hopefully you can either delete Foxit Reader as an add-on or else change the default program for pdf helper.
Also, in Adobe Reader make sure you have Edit > Preferences > Internet > "Display PDF in browser" checked.
Hi David,
I cannot see Foxit Reader as an add-on in IE and Adobe Reader 9 is the default for pdf helper.
"Display pdf in brower" is checked in Adobe Reader.
Thanks for your suggestions
Goggs
Apr 22, 2010 Apr 22, 2010
Hi there
you need to do the following to fix up the associations in Vista
1. go to control panel
2. default programs
3. set associations
find  the ".pdf"
4. go to the "change program" button and chose Adobe
hope this helps
Guest
Jul 07, 2011 Jul 07, 2011
I was getting so frustrated and tried sooooo many different "fixes". Yours worked!  Brett, you Rock!
Jul 28, 2014 Jul 28, 2014
WOW Brett thanks so much for the tip it worked a treat!!!!!! Thank you so much
[spam link removed]
Feb 23, 2011 Feb 23, 2011
Try repairing / reinstalling the latest version of Adobe 8 / 9 , if this doesn't solve your problem you need to edit the default adobe reader setting in the registry.
For information on the Windows Registry Editor, see the documentation for Windows or contact Microsoft Technical Support.
  • Go to Start > Run
  • Type regedit and click OK.
  • Browse to the key HKEY_CLASSES_ROOT\Software\Adobe\Acrobat\Exe.
  • Make sure that the (Default) value is set for the path where Acrobat or Reader is installed.
  • The default path for Reader is "C:\Program Files\Adobe\Reader 9.0\Reader\AcroRd32.exe".
    The default path for Acrobat is "C:\Program Files\Adobe\Acrobat 9.0\Acrobat\Acrobat.exe".
    for full details visit: http://kb2.adobe.com/cps/405/kb405461.html
    Guest
    Apr 06, 2011 Apr 06, 2011
    I solved this by going to
    Control Panel\All Control Panel Items\Devices and Printers
    right click on the pdf printer program you want and select make default
    Guest
    Aug 24, 2011 Aug 24, 2011
    BRETT, YOU RULE. THIS WORKEDFANTASTIC!
    This 6½ year old topic is now locked.
    (Ok, 5½ years.)
