Cannot change default page format
Aug 12, 2008 4:10 AM
I am using adobe reader 8.1.2 with Linux, and when printing a document I would like to print it in A4 (the default paper size used by the printer). I would like to set A4 as default in Adobe reader, but cannot find any button etc for doing that. So I always have to go to the printer, acknowledge that the document can be printed on A4, return to my desk, and go to the printer again to pick up the printed document.
It would be really nice if I the document can be printed as A4 in the first place. Any ideas how to do that?
Cheers
Alexander
    Aug 13, 2008 1:33 AM   in reply to (alex28376)
    Hi Alexander,
    Have you tried setting up the defaults in the CUPS for that particular printer.
    Rishi
    Aug 13, 2008 3:11 AM   in reply to (alex28376)
    Hi Alexander,
    To set the printer properties within reader, following steps woud be helpful:
    1) Open the document in reader.
    2) Go to the print dialog.
    3) Choose the desired printer form the dropdown.
    4) Click the Properties button.
    5) Choose the page size that you need to. Click OK.
    6) Print the document.
    I hope this helps.
    Please write back if you still find some issues.
    Rishi
    Aug 13, 2008 4:41 AM   in reply to (alex28376)
    Hi Alex,
    Please see whether the CUPS daemon is running on your machine.
    Before launching the reader through commandline, try this :
    Set ACRO_PRINT_DEBUG=1 and then launch reader.
    Then follow the first 4 steps I had told you earlier.
    You would get some error messages on the console.
    Please let me know those error messages.
    Rishi
    Aug 18, 2008 9:28 PM   in reply to (alex28376)
    Hello Alex,
    Do you find your printer listed here - http://www.linuxprinting.org/printer_list.cgi? If so, you might be able to download the ppd file and re-configure your printer. That should help with your issue.
    If it doesn't please do mail back.
    Sincerely,
    Neha
    Aug 19, 2008 1:07 AM   in reply to (alex28376)
    Hi Alex,
    Did you download the ppd file in /etc/cups/ppd/ and then restart the cups daemon (using /etc/init.d/cups restart)?
    Sincerely,
    Neha
    Aug 27, 2008 1:10 AM   in reply to (alex28376)
    Alex,<br />Since you are unable to get around the issue by downloading the printer's ppdf file, could you try using custom printing instead? It has an option of providing PageSize that would also be remembered by the Reader.<br /><br />Please try the following:<br />Open the print dialog and choose "Custom..." in the printers list dropdown. It will give you a textbox to type the command and a dropdown for specifying PageSize. Try giving a command like "lp -d <your_printer_name>" or "lpr -P <your_printer_name". Choose A4 in the pagesize dropdown.<br />I hope this would help you with the issue.<br /><br />Sincerely,<br />Neha
    Feb 20, 2009 12:24 PM   in reply to (alex28376)
    To set the default page size in adobe acrobat do the following:
    Go to "Start", "Printers and Faxes". Right click "Adobe PDF". Select "Properties". Click "Device Settings". Under "Form To Tray Assignment" select "A4". Click on "General". Click "Printing Preferences" and under "Adobe PDF Settings" select "Standard" as the Default Settings and "A4" as the "Adobe PDF Page Size". Click "Apply" followed by "OK" and "OK". However the page size will revert to that of your default printer so make sure that the page size of your default printer is also A4 or that Adobe is the default printer.
