Home/Support/
Forums
14186 Views 24 Replies Latest reply: Feb 20, 2011 7:41 PM by tdbartley RSS
Calculating status... 4 posts since
Dec 21, 2006
Dec 21, 2006 9:16 AM
Adobe Reader CPU Usage
Hello All,
The problem i'm having is that "acroread" process after being open for some time (many hours or even days) starts to use all the CPU without anyone touch the application. This causes lots of trouble because i'm using all the time simulation software and "acroread" starts to share CPU with my mission critical applications and I cannot be always checking if acroread has crashed.
I've tried with more than one Linux distribution and have read in some web forums that other linux distributions have the same problem.
Currently i'm using CentOS 4.4 (Linux 2.6.9-34.0.2.ELsmp #1 SMP Fri Jul 7 19:52:49 CDT 2006 i686 i686 i386 GNU/Linux)
Even in CentOS 4.3 , 4.2 , 3.4 they all had the same problem.
I'm using acroread 7.0.8 but older versions of 7.x did the same.
Please share some ideas about this issue.
  • User 59 posts since
    Jan 24, 2006
    1. Dec 22, 2006 3:30 AM (in response to (Hugo_Valadas))
    Re: Adobe Reader CPU Usage
    Hi Hugo,
    This is a known issue and we will be working on this for the next release.
    Ashutosh
  • Calculating status... 1 posts since
    Aug 11, 2002
    3. Apr 25, 2007 9:27 AM (in response to (Hugo_Valadas))
    This still occurs in Reader 7.0.9. Did the above fix make it into this version?
    The specific issue I seem to have is that opening a PDF from within Firefox and then closing the browser tab leaves acroread running in the background. This process will eventually consume 100% of the CPU.
  • User 53 posts since
    Aug 11, 2002
    4. May 7, 2007 4:10 AM (in response to (Hugo_Valadas))
    The fix did not make it into Reader 7.0.9 It shall be available in the 8.x version.
    -vc
    May 25, 2007
    5. May 25, 2007 1:22 PM (in response to (Hugo_Valadas))
    The cpu utilization has been killing us, so we came up with a temporary band-aid to hold us over until version 8 comes out. Just run this command every minute or so via crontab, and if there are any acroread jobs using 80%+ cpu that have used a full minute of processing time, it will kill it.
    kill `top -b -n1 | grep acroread | awk '{ print $1 " " $9 " " $11 }' | egrep "(1[0-9][0-9]|[8-9][0-9]) [0-9]*[1-9]:" | awk '{ print $1 }'` 2>/dev/null
    It's definitely not pretty, but it does work. I'd be interested to see if anyone else has found any creative workarounds for this issue...
    May 28, 2007
    6. May 28, 2007 5:35 AM (in response to (Hugo_Valadas))
    Hi Toby,
    The pre-release of 8.x version is now available, which has the fix. I would suggest you to try that out and confirm to us. Your input is valuable to us.
    If you are interested to be part of the 8.x pre-release program, please post your email address. I would get you enrolled.
    Anupam Garg
    Jun 14, 2007
    7. Jun 14, 2007 1:50 AM (in response to (Hugo_Valadas))
    Is it still possible to try the 8.x pre-release for Linux ?
    As I am seeing the CPU problem often every day, I would be happy to test this new version and provide feedback.
    Rui
    Aug 11, 2002
    8. Jun 14, 2007 1:56 AM (in response to (Hugo_Valadas))
    Please send your email-id to agarg at adobe dot com, and Anupam shall make sure you are a part of the pre-release program.
  • User 131 posts since
    May 16, 2006
    10. Jul 7, 2007 8:37 AM (in response to (Hugo_Valadas))
    Hi Hugo,
    Could you please let us know in what state you left Adobe Reader opened in the background?
    1 - Did you have one or more documents opened?
    2 - Was the Adobe Reader window in minimized (iconified) state?
    That will help us identify the causes of high CPU usage even when idle.
    Gaurav
    Sep 23, 2008
    12. Sep 23, 2008 1:56 PM (in response to (Hugo_Valadas))
    Hello,
    Essentially every time we use acrobat reader version 8.1.2_SU1 we have the problem of 100% cpu usage as described in earlier messages. This is very undesirable, can you please fix it? Do you need any further information for debugging. Information about a host on which the problem is experienced is below.
    % uname -a
    Linux usplmwd500342 2.6.18-92.1.10.el5 #1 SMP Wed Jul 23 03:56:11 EDT 2008 x86_64 x86_64 x86_64 GNU/Linux
    % cat /etc/redhat-release
    Red Hat Enterprise Linux Client release 5.2 (Tikanga)
    % acroread -v
    8.1.2_SU1
    Peter
    Oct 2, 2008
    13. Oct 2, 2008 4:56 AM (in response to (Hugo_Valadas))
    Same problem with 100% CPU usage when using the acroread as browser plugin.
    The first opening of an PDF is ok. After few minutes (even if the PDF has been closed, that means, an other web page is opened) the acroread process flips to 100% cpu usage and every further click on PDFs is significant slower.
    openSUSE 10.2 (X86-64)
    Linux virto 2.6.18.8-0.10-xen #1 SMP Wed Jun 4 15:46:34 UTC 2008 x86_64 x86_64 x86_64 GNU/Linux
    acroread-8.1.2_SU1-0.1
    seamonkey-1.1.12-1.1
    The home directories are mounted via nfs and automounter.
    We have about 50 users, which are regulary complaining about the bad performance of opening and printing PDFs some few minutes after opening the first PDF with acroread plugin in the browser.
    Rupert
    Nov 5, 2008
    14. Nov 5, 2008 4:39 PM (in response to (Hugo_Valadas))
    I have the same problem with acroread-8.1.2_SU1-0.1, openSUSE 10.3 (Opteron 175). Firefox 3.03.
    The problem can be recreated very easily. I just need to open any pdf file on the web. I can then run the top command and within a few minutes the acroread process will be up to around 50% CPU. If I leave the process then it will soon become 100%. The acroread process keeps on going even after I closed firefox.
  • scopsm User 12 posts since
    Feb 10, 2009
    15. Feb 20, 2009 2:38 AM (in response to (Hugo_Valadas))
    I have this with 100% CPU usage with Adobe Reader 9 when just opening the Reader. Adobe weren't much help.
  • Atanu Dhar Adobe Employee 71 posts since
    May 2, 2007
    16. Feb 24, 2009 11:38 PM (in response to (Hugo_Valadas))
    Dear Mr. McGeoghan,
    Could you please give us the steps of reproducing this condition, were you running Reader standalone or trying to open a PDF inside a browser (which browser also would be a great input)
    Atanu
    adharATadobeDOTcom
  • kallu_be Calculating status... 1 posts since
    Jul 19, 2009
    17. Jul 19, 2009 1:40 AM (in response to (Hugo_Valadas))
    Attached file is using 100% cpu on 64 bit Jaunty.
    Steps to reproduce.
    1) Open attached pdf in adobe reader.
    2) There wont be cpu usage initially.
    3) Wait for 5 min to see the surge in cpu usage.
    system info:
    Linux hercules-linux 2.6.28-14-generic #46-Ubuntu SMP Wed Jul 8 07:41:18 UTC 2009 x86_64 GNU/Linux
    Acrobat reader info:
    acroread:
      Installed: 9.1.2-3jaunty1
      Candidate: 9.1.2-3jaunty1
      Version table:
    *** 9.1.2-3jaunty1 0
            100 /var/lib/dpkg/status
  • CAM_WERDNA Calculating status... 1 posts since
    Aug 3, 2009
    18. Aug 3, 2009 7:32 AM (in response to kallu_be)
    Not sure whether this is the same problem or a different one.
    For us acroread consumes all the memory and the CPU is maxed out swapping
    until the oom manager kills acroread and the machine recov
    Our machines are 2GB RAM with 2GB swap, running the x86_64 version of
    Scientific Linux 5.3 (a recompilation of Red Hat Enterprise Linux 5.3)
    - we don't really need a 64bit OS but some local apps run faster in 64 bit.
    We first saw this with, I think, acroread 8.1.4 and continues through to 8.1.6.
    (I am reluctant to switch to v9 since we are using it as a pdf viewer
    not a flash viewer - adding javascript was bad enough - we would be
    more likely to move to evince or another open source pdf viewer).
    Typically acroread chews memory for users who run firefox 32bit
    and the nppdf.so Adobe plugin, but I cannot confirm that it never
    happens for users whose firefox opens a separate acroread process.
    What extra imformation would help to debug this ?
  • sanika Kulshreshtha Adobe Employee 266 posts since
    Apr 6, 2009
    19. Aug 6, 2009 11:36 PM (in response to CAM_WERDNA)
    The high CPU usage problem when acroread is used inside browser on 64-bit systems has been fixed in AR 9.x. You could download the latest Adobe Reader 9.1.3 Security Update directly using the FTP link, or use YUM to install the update. Please use it and let us know if you still see 100% CPU usage.
    Sincerely,
    Sanika
  • pkeller63 Calculating status... 2 posts since
    Aug 13, 2009
    20. Aug 13, 2009 5:25 AM (in response to sanika Kulshreshtha)
    Dear Sanika,
    The nppdf.so shared library that is provided in the download for linux is an ELF32 object, so is completely unusable with 64-bit browsers.
    If you can make a 64-bit build available, I would be happy to try it out and report back on how well it performs.
    Peter.
  • pkeller63 User 2 posts since
    Aug 13, 2009
    21. Aug 13, 2009 6:09 AM (in response to pkeller63)
    Sorry - forget I wrote that. I've just figured out now to use nspluginwrapper.
    I'll see how the plugin behaves. Initial indications are good: it loads very fast.
    Regards,.
    Peter.
    Apr 6, 2009
    22. Aug 13, 2009 6:31 AM (in response to pkeller63)
    Glad to hear that Peter. Let us know how it goes.
    Sanika
  • Agent_Nappi_007 User 10 posts since
    May 19, 2009
    23. Feb 15, 2011 5:55 AM (in response to sanika Kulshreshtha)
    Looks like that some people that might be able to help are subcribed to this thread.
    It would be nice if you can take a look to the problem that I´ve reported in this post:
    http://forums.adobe.com/thread/791216?tstart=0
    I´m glad to provide additional information there if required to not spam this thread with my problem.
    Your help is very much appreciated.
    Thanks in advance
    Agent
  • tdbartley Calculating status... 1 posts since
    Feb 20, 2011
    24. Feb 20, 2011 7:41 PM (in response to (Hugo_Valadas))
    Problem persists in Adobe Reader 9.4 in CentOS 4.8. Running the stand-alone executable without even loading a PDF, the process immediately consumes nearly 100% of core.
