This discussion is locked
AFTER EFFECTS WISH LIST (Prior to Sept 09)
Aug 31, 2009 8:40 AM
AFTER EFFECTS WISHLIST
What features would you like to see implemented in After Effects? New ideas for plugins? Interface changes? Post 'em here!
Let's keep bug identification to individual posts, as these will probably be addressed more readily. Let's use this thread for specific ideas about ways that AE can be improved and expanded.
These Forums are for users, not Adobe employees, so don't forget to also fill in an  Adobe feature request form.
To view the Wish List posts prior to 2008, look here.
Replies 1 2 3 ... 6 Previous Next
    Jan 10, 2008 5:12 PM   in reply to Andrew Yoole
    I would like a graph editor that actually does something useful.
    The current one does not have separate X, Y, and Z axes available.
    You cannot adjust curves with any degree of useful control.
    You only have very limited options for easy ease or linear/bezier, though bezier handles don't seem to be available most of the time for some unfathomable and frustrating reason.
    It is a big useless lump of nothing, and needs to be completely redesigned to offer usable features and options.
      Jan 11, 2008 3:45 AM   in reply to Andrew Yoole
      I completely agree that the graph editor needs work. The current "workaround" of using an animation preset (transform) to seperate channels into expression sliders is LAME. Position values need to be seperated into 3 distinct values that can be adjusted independant of each other. I'd also like numerical boxes, where you can type in the angle and length of the bezier curve for both incoming/outgoing. An option to force keys onto actual frames (rather than inbetween frames). A numerical box that specifies what frame that key is on.
      An entire seperate window for the graph editor would be MUCH improved over the dopesheet/graph editor switch icon. I want to be able to see both the dopesheet and the graph editor at the same time! There's way too much clicking back and forth. Anyone know of a shortcut?
      Guano, I think you need to set the keys to ease in order to get bezier handles. Or try clicking/dragging a keyframe with the g key.
      Jan 11, 2008 12:23 PM   in reply to Andrew Yoole
      You can actually already do this. Open the "Choose Graph and Type Options" menu at the bottom of the graph (its icon looks like a little dialogue box) and deselect "Allow Keyframes Between Frames".
      That said, the more I use the graph editor, the more frustrated I become with its limitations. It makes expressions work a real pain. I used to be able to use the individual property graphs to create a sort of dashboard to map expressions variables over time, now that's impossible to do in a readable way. Also, why is the motion graph switch considered a comp switch? This means its status gets included in the undo queue. This in turn means there is no way to make changes in keyframes view, switch to graph view, then undo and see the changes reflected in the graph. Instead, AE switches back to keyframes view, and if you then manually switch back to graph view, you lose the redo queue! This is immensely frustrating when working with marker-driven expressions, since markers can't be seen or manipulated in graph view, and only renders the graph even less useful as far as I'm concerned.
      Also, and this is a bug, so it's slightly off-topic, but when editing expressions in graph view, undos change the underlying expression correctly, but do not change the code in the expression editing box, meaning any further revisions to the expression will end up editing the wrong expression code. Just one more reason to avoid the graph editor.
      Jan 16, 2008 8:43 AM   in reply to Andrew Yoole
      Not sure if anyone has mentioned this, but when using the separate position coordinates preset on a null as camera control, it would be nice to see those keyframes as a motion path so you can adjust the camera's motion better.
      Jan 23, 2008 4:07 PM   in reply to Andrew Yoole
      sort out 3gb ram limit.
      multi-processing for more than 6 processors.
      aforementioned 3d camera interface issues that haven't been sorted in at least 8 years. WTF?
      Intelligent caching of rendered layers.
      Select all render and output settings, file destination in render queue.
      Be able to turn off that thing where you double click on a layer and it opens the footage window. Anyone using that footage window much?
      Ability to precomp 3d layers together and continuously rasterize. And everything work. Adjustment layers,etc not to split up 3d comps in depth order. Specific layer to do this instead.
      Just don't bother with the node view thing unless it's useful. Imitation Flame thing from years ago. We all asked for it. And got something different. No one uses it. Do they?
      Import 3d models. Actual use of opengl for realtime fx.
      Decent colour grading tool. Not color finesse bundle. Or buying something. Even levels and HSB together would save a little time.
      Really not hard. Channel mixer anyone?
      Import XML file. Instead of buying auto duck. How about adobe buy auto duck instead?
      Silky smooth playback to broadcast monitor.
      Instead of node-based view of project. How about node based view of expressions a la quartz composer /c4d xpresso.
      Import midi files as keyframe data.
      Exponential scale as keyframe setting.
      Mask feathering with separate bezier for feathering. YES.
      Not crashing quite so much on my 8core.
      XYZ position editing as separate channels.
      Jan 23, 2008 4:14 PM   in reply to Andrew Yoole
      Once you learn how to use something like nodes you'll always want them. Combine something like Shake's nodes with AE's timeline and you've got a killer way to composite and do MO graphics in the same app. Gone forever will be my AE compositing projects with 50 to 100 layers.
      Jan 23, 2008 6:47 PM   in reply to Andrew Yoole
      (Replying to Marcus)
      Sorting out 3GB limit means rewrite for 64bit. Not that I'm against that....
      Does anyone use the node/schematic view in AE? I opened it up once to show my boss the end game from our show, but it's so horrible to open/organize that it's just a waste of time..
      "Instead of node-based view of project. How about node based view of expressions a la quartz composer /c4d xpresso." Later this year, you should check out Softimage XSI 7. "Moondust" is awesome!
      And the main reason I was replying... Accessing XML files is already possible, via scripting.. Funny you should mention that, I'm just working on how to write XML files (http://www.adobeforums.com/webx/.3c05dc8f/1).
      There's a chapter on XML in the Javascript Tools Guide CS3 (Open ExtendScript Toolkit 2, then go to Help > SDK > JavaScript Tools Guide CS3. There's also a pdf version somewhere on the adobe site, but I couldn't find it with a quick look.) There's a lot more on reading xml files than creating them...
      Jan 23, 2008 7:14 PM   in reply to Andrew Yoole
      "Does anyone use the node/schematic view in AE? I opened it up once to show my boss the end game from our show, but it's so horrible to open/organize that it's just a waste of time.."
      This has been exactly my experience. For any comp network complex enough to make a network graph useful, the graph itself is so unwieldy as to be completely unusable.
      On an unrelated note, is HTML still hosed on this forum? I tried putting the above quote in italics, and the forum displayed the tags rather than the formatted text.
      Jan 23, 2008 9:01 PM   in reply to Andrew Yoole
      I have to agree with the posts these days on 3D. I wrote about this prior to the current version, and was really surprised and saddened that the 3D situation still sucks in AE. What's the problem? This, in my opinion is the main reason I'd stop using AE and switch to Motion, which at least seems (in my limited experience with it) to have worked out a nice 3D interface.
      At the VERY LEAST:
      XYZ coordinates
      Named windows
      PLEASE! PLEASE! PLEASE!!!!!
      Josh
      Jan 24, 2008 7:41 AM   in reply to Andrew Yoole
      Is this what you're looking for, David?
      http://www.adobe.com/devnet/bridge/pdfs/javascript_tools_guide_cs3.pdf
      Jan 24, 2008 11:15 AM   in reply to Andrew Yoole
      That's it. I've already downloaded, printed it, and am reading it. I originally found the link while searching for "XML After Effects." Without finding it thru the ExtendScript, I think it's very difficult to locate; perhaps you should include a link under the After Effects Scripting Guide, since the two compliment each other. Also, still waiting for the AE Scripting Guide to be upgraded to LiveDocs...
      My XML script is almost done; just a couple of remaining problems. Moving on to UI creation (which is also covered in Javascript Tools Guide)....
      Speaking of ExtendScript. It bugs me that my script will debug/run but not function properly. I then copy the section of my script that creates the xml file into a new document. Only then does debugging the new doc reveal my error, undeclared (mistyped) variable. Why wouldn't it catch that in the larger script? Frustrating.
      Jan 25, 2008 7:16 AM   in reply to Andrew Yoole
      Will do.
      Me, too. I won't trouble you with the details of why that's not trivial, but I will assure you that the wheels are in motion.
      I bet that you'd get some help with this if you started a new thread with this issue in the scripting forum.
      Feb 8, 2008 8:58 AM   in reply to Andrew Yoole
      Option for setting mode of self collision of masks. I always run into have to cross the splines and thus, getting a difference effect on it. I'd like to set that to Add as well, if I want to. Sounds easy.
      Thanks.
      Feb 13, 2008 8:05 AM   in reply to Andrew Yoole
      Another Graph Editor request....
      Ability to vertically zoom in the graph editor (after disabling autozoom). You can zoom horizontal via - and =. I need something for vertical.....
      Feb 13, 2008 8:27 AM   in reply to Andrew Yoole
      David, you can Alt-drag with the Zoom tool to zoom vertically in the Graph Editor.
      See "Pan and zoom in the Graph Editor".
      Feb 13, 2008 10:56 AM   in reply to Andrew Yoole
      I see.. Spacebar+Alt and drag with mouse (depending on movement, it will zoom in or out, even though the zoom tool only shows - (neg) sign).
      Scratchin' that off the list...
      Feb 23, 2008 10:52 PM   in reply to Andrew Yoole
      I would like to see XDCam EX import capabilities.
      Right now, even with the $449 MainConcept MPEG PRo HD3, AE cannot work on any footage from this camera.
      XDCam EX import at the top of my list!
      Feb 27, 2008 9:24 AM   in reply to Andrew Yoole
      I got a simple one. Can AE have Spell Check.
      Also Can there be more integration between AE and Apple FCP. Automatic Duck only works so well.
      Thanks =)
      Feb 27, 2008 9:58 AM   in reply to Andrew Yoole
      1)Seperate XYZ for position
      2)much more intuitive control of the curves as in maya/max.
      3)individual mask point keyframes and individual blur per point in masks also.
      4)a working node-based environment would be fantastic. (i believe DV garage have made a version of conduit for AE which does this?)
      5)I love the puppet pin tool, but I'd love it even more if there were parenting controls per pin to allow making a pseudo IK rig without lots of expressions.
      6)would love colour finesse to be more integrated into AE's interface.
      7) all effects in 32 bit or float
      8) ability to clone/paint in the comp window
      9) drop down option for precomps to see the layers inside, maybe indented or highlighted .. whatever
      10) realtime playback always no matter what! (well, it is a wishlist)
      Feb 27, 2008 2:39 PM   in reply to Andrew Yoole
      I second the individual mask point keyframes. I'd also like the option to change the size of a solid without scaling the masks.
      Feb 28, 2008 7:12 AM   in reply to Andrew Yoole
      Regarding the spelling checker, check out the script here:
      http://michaelcardeiro.com/aeScripts/
      Mar 3, 2008 8:25 AM   in reply to Andrew Yoole
      Tools/manipulators to either rotate or scale selected puppet points would be positively *******'.
      Mar 4, 2008 9:26 AM   in reply to Andrew Yoole
      another one that bugs me (but maybe there is a way of doing this i haven't yet found) is i can't see curves in my graph editor for attributes controlled by expressions. eg if i have 3 keyframes and an expression to loop these I'd like to be able to see my curve looping also, perhaps faded or broken line to show the difference.
      Mar 4, 2008 9:41 AM   in reply to Andrew Yoole
      You can do this already. There are three switches and a menu arrow next to the expression. The second of these, between the = and the pickwhip sends the result of the expression to the graph editor.
      Mar 5, 2008 7:15 AM   in reply to Andrew Yoole
      See "Show expressions and the expression graph".
      Mar 5, 2008 8:17 AM   in reply to Andrew Yoole
      ah great! thanks Christian and Todd. If only all my other wishlist items were already addressed like that. that's great. I should have looked that up, but I just don't like the help browser. Cheers.
      Mar 6, 2008 9:41 PM   in reply to Andrew Yoole
      Support loading IFL files.
      Faster start-up would be nice, too (Fusion starts in what, 5 seconds). Load plug-ins only as needed = faster startup.
      Also on my wishlist: teach the Premiere guys how to code properly or make editing video easier in AFX (the latter might be easier)... ;)
      Mar 7, 2008 2:47 AM   in reply to Andrew Yoole
      I used to like that in pre v8 holding opt down would turn your arrow into pen tool rather than having to press G. a little thing but it was one of those things that helps you work at speed...
      maybe i could always work in pen mode & hold cmd when i want to go back to the arrow?!
      Mar 7, 2008 6:33 AM   in reply to Andrew Yoole
      This might seem like a small thing, but it would be nice if when I option-double-click on a locked comp layer AE would open the source comp, rather than behaving as if I am trying to select the locked layer.
      Mar 11, 2008 11:26 AM   in reply to Andrew Yoole
      Independant X,Y,Z coordinate keyframing
      Tracker Data Applyable to Masks (or mask parenting to nulls, etc)
      More options for keyframes without the need for expressions - ie, loop out, extrapolate, etc
      Node view for Parenting
      Lockable Selections of layers (so for example you can't accidentally click off a layer when masking, applying certain composition only effects such as mesh warp, etc.
      Mar 13, 2008 5:43 AM   in reply to Andrew Yoole
      prob a really simple little thing but a 'centre anchor point' button could be handy?
      Mar 17, 2008 5:56 PM   in reply to Andrew Yoole
      XDCam EX import capability.
      Mar 18, 2008 9:15 AM   in reply to Andrew Yoole
      A better management of core processes like a good 3D app do...
      Mar 19, 2008 12:40 AM   in reply to Andrew Yoole
      I want SERIOUS integration between AE and other Adobe products. As this is a wishlist I'm going to be outrageous and say a big giant Flash engine in AE so I can import FLAs as comps (similar to the way you'd import AI or PSD files), but realistically I'd be happy with just being able to edit Illustrator paths (as you can with Combustion) within AE. It's SOOOO annoying having to ctrl + e Illustrator files when an app that adobe don't even make has better integration with adobe products. Grrrrrrr
      Mar 19, 2008 5:37 AM   in reply to Andrew Yoole
      This might have been mentioned before, but in addition to the often-requested labels for the 3D views, I'd like some indicator of which camera layer is being used as the active camera on a given frame.
      Mar 19, 2008 6:48 AM   in reply to Andrew Yoole
      Humanbulk -- can you explain your feature request a little more? It's a bit Dilbert-y meeting speak.
      Mar 27, 2008 2:41 AM   in reply to Andrew Yoole
      Hi Aaron. I have been searching for a solution to changing the setting of multiple Output Modules too and came across your reply here.
      I was just wondering if you could clarify it for me.
      This is what I understand so far and what I have been doing allready...
      If I highlight all the comps in the render queue and change the Render settings, they all change. I have to change the output Module one by one, and the Output to setting is already done if I make a false save to in a blank project before the one I start working on.
      I just wanted to clarify if there is definately no way I can change all the Output Modules in one go, or some way which is quicker than changing them one by one as i have described above.
      I put over 300 clips through after Effects, and as you can imagine, the time saved on this step alone would be brilliant (for both my and my hand)
      Yours,
      Melvyn
      Mar 27, 2008 2:54 AM   in reply to Andrew Yoole
      Melvyn, the quickest way I've found to change all the output modules in one go is:
      Before you add them to the render queue, change the "movie default" setting(if that's what you're looking for) to the output module you require in the "edit/templates/output modules" dialogue box. Unfortunately with this method you have to know BEFOREHAND which output module you want to set the comps to render to, it doesn't leave too much room for experimentation. Quickest way I've come up with though.
    Actions
