_It happened to me and I decided as follows:
Hi, there.
I'm using After Effects CS5.5 on a college computer for class. I got this error message when I loaded a project from another computer, so decided to redo the whole thing over again on the computer I'm using now. I was almost through this new project and I wanted to see how it looked, but I got the same blasted error. I don't know anything about the output module or how to properly change it, so I'm afraid I'd make it worse by tampering. It's now overdue, so I beg somebody to reply ASAP.
Rogerio, you are a lifesaver! I also found that unchecking the "render" checkbox next to any above works, too. Thanks for posting this. You saved me hours of frustration!
Bob
It worked for me. Thanks Rogerio was freaked for a second there.
K
Thank you so much...it worked out.
Thank you for making the video, it was so annoying
Well that's great. Followed along and after effects is rendering fine again. Thanks.
You're the best!! Thank you
This is goated! Thank you!🙏🏼
Thank you!
literally thank you so freaking much I was losing my mind
Double-check and make sure all your assets are linked.
For me all the tipps from the other nice helping people didn't work.
However what worked was exporting the Composition I was trying to render into a new Project.
I made a mess overloading the project, importing other existing After Effects projects, somewhere along the line there was probably a buggy dependency.
Exporting your composition is well explained here:
https://davidlindgren89.medium.com/how-to-copy-animation-to-another-project-in-after-effects-ea361dc...
