It struck me silly that I've been running tests with v.3.3 when 5.2 is the latest, so I downloaded it. The setup "wizard"...hmm, why is it a "wizard"? It provides no choice of installation path. I didn't realize this because immediately after I'd launched it, I knocked something onto the floor, reached down to pick it up ... and looked back up just in time to see the "wizard" complete the installation...but where, I didn't know. It didn't display any information about where it had installed the app. Adventures In Discoverability. :) I hunted around on the hard drive until I found it (C:\Program Files\Adobe -- well, at least you can launch it if you think to look for it in the 'Start' menu). So ... that needs a bit of work. Anyway, I copied the app into a directory of my choice -- one that's in my system's %PATH%, replacing spaces in the name with underscores. It works fine in that directory -- no problem with the name-change as far as I can tell. Now back to the fun stuff...
This version doesn't seem to require a fully qualified path to the input file or to the output directory when "-d" is used. That's an improvement. IOW, this worked:
converter -p1 -d DNG filename
where "converter" is the program's name, "DNG" is the name of a subdirectory of the directory where I'm running the test, and "filename" is the name of a RAW file in that directory.
The program still doesn't know how to create a directory (or ask about creating one if it doesn't exist). Fails silently if "-d" is used and the specified directory doesn't exist. But at least this version returns an exit code of 1 due to the failure -- better than returning 0.
Still doesn't understand wildcards. Hope done sprang eternal there for a moment, but oh well. Back to "for" loops...
Still fails silently, returning exit code 0 (oops), if a nonsensical command-line is used (e.g., using "-c" as the only argument).
Hey, how about a truly silly command-line error -- a command line including both "-c" and "-u". What happens? It "consumes" the first of the two mutually exclusive switches, ignoring the second -- you get a compressed DNG file. Swap the order of the switches, and you get an uncompressed file. (I'd vote for a syntax-error message in that case, m'self.)
Interestingly strange little program...If I run it from the command line, it drops back to the command line immediately after I press ENTER. That makes it appear to have failed. But it hasn't -- it's running in the background, and a few seconds later the DNG file is created. But, if I run it from within a batch file, it does NOT return control to me until it has completed writing the output file. Wonder what's up with that.
Fun stuff. :)
