Timecode from .m2t not visible in Premiere Pro CS3
Nov 28, 2007 10:39 AM
I've done a couple of HDV test captures using OnLocation to create an .m2t file. The DVR in OnLocation correctly displays timecode from the camera (Canon XH-A1) while recording and playing back clips. However, when I import the file into Premiere Pro CS3 I don't see the start time code in the file properties or when bringing up the "Timecode" window (off the file menu). In order to sync multi-camera clips I end up having to manually enter the time code using the info displayed by the OnLocation DVR for that clip.
What am I doing wrong here - I thought that I read somewhere that Premiere Pro would be able to directly read the timecode stamp from the .m2t file?
/BILLW
    Nov 28, 2007 12:35 PM   in reply to (Bill_Warshaw)
    As far as I remember, OL only supports timecode on HDV from Sony cameras - I think it's in the manual.
    /Ulf
    Nov 28, 2007 8:57 PM   in reply to (Bill_Warshaw)
    Strange Bill, I just got an XH-A1 - will test it very soon and let you know how it is here.
    /Ulf
    Nov 28, 2007 9:02 PM   in reply to (Bill_Warshaw)
    Bill,
    If you go to the manual page 17
    http://help.adobe.com/en_US/OnLocation/3.0/onlocation_cs3_help.pdf
    under HDV fileformat, you get this:
    M2T: Preserves the tape timecode (Sony cameras only) and other metadata from the camera
    So I think it for some reason is shown but not saved :-(
    /Ulf
    Nov 29, 2007 9:46 PM   in reply to (Bill_Warshaw)
    Thanks for this additional info, Bill - we can just hope, and yes I love to get started with my XH-A1. ;-)
    /Ulf
    Feb 11, 2008 1:27 PM   in reply to (Bill_Warshaw)
    Obviously CS3 does not support timecode import with m2t HDV files. We have the same issues with files from our JVC DTE recorder. The same files in Avid imported with timecode. Hopefully Adobe will get this worked out soon as it is a real PITA.
    Mar 20, 2008 7:54 AM   in reply to (Bill_Warshaw)
    I know this is off topic and I apologize, but it's just really important for me. How are you guys recording timecode with the xh-a1? I thought only higher models like the xh-g1 had timecode.
    Jun 20, 2008 12:59 PM   in reply to (Bill_Warshaw)
    Sony has a plug-in for FC Studio 6 or higher to use M2T files. If you happen to have that you can download the plugin and import them to FC. Then you can use Premiere to import the now QT files from the FC folder and the Time Code is there
    Jul 2, 2008 8:04 AM   in reply to (Bill_Warshaw)
    Hello,
    I have not been able to import the M2T file that I captured in On- location into PremierCS3. It hangs up the computer. Any thoughts on how I can make this work???
    Aug 27, 2008 4:23 PM   in reply to (Bill_Warshaw)
    I had same issue with trying to read the Console generated files, MPEG2TS I tried to generate MPEG2ES and they seemed to hang up the Console program.
    I cant get On Location program or any other program to recognize the XH A1 camera when in any on of its record modes.
    Is there a way to get a Firewire signal out of the camera to any program other than Console?
    Mark
    Dec 12, 2009 5:41 PM   in reply to (MarkScottFL)
    Sorry to dredge up an old thread, guys, but as I'm just starting my transition to tapeless I'm having the same issue.  I'm recording to both tape and to the MRC1k on my Z5s; the TC comes in fine when I capture the tape, but all the transferred/imported m2t files from the MRC1k all start at zero.  Normally I wouldn't care, but the main reason I dumped all my old cams and bought four Z5s with MRC1ks was for the ability to do real time of day free run timecode and sync the four cams together via TC LINK, while still going tapeless, for supposedly easy multicam sync by timecode on the timeline.
    Using DVMP Pro I was able to confirm that the clips do in fact have the correct timecode on them (but no values in Properties for Prem Start and such).
    Anyhow, anyone figured this out yet?
    Dec 27, 2009 7:41 AM   in reply to acgold777
    I think PPro relies on timecode in the m2t header which DVMP Pro says is absent. What did you use to capture from tape?
    Dec 27, 2009 11:41 AM   in reply to Colin-B
    The tape capture, which I did from within Premiere, is fine.  It's the direct transfer from the MRC1k that's missing the header.  I used the Sony Utility to stitch the files together, then imported into the project, just as recommended by both Sony and Adobe.
    I got a completely useless response from Adobe Tech Support directing me to the page that tells you how to add timecode manually.  But it takes longer and is more complicated to do that than it is to synch the clips using audio waveforms, the way I used to do it, and which I was hoping to avoid by using cams that could be synched together and use the MRC1k.  Oh, well.
    Has anyone done this successfully in either CS3 or CS4?  Maybe it's not an issue with CS4?
    Dec 27, 2009 4:02 PM   in reply to adam gold
    DVMP Pro has a tool which adds a Premiere timecode header to DV AVI files using the embedded timecode as the source, but not for HDV m2t files - it sounds like that might be a useful addition if there's no solution in PPro.
    Dec 27, 2009 6:02 PM   in reply to Colin-B
    Interesting.  But as this is specifically a problem with HDV m2t files, sounds like it isn't a solution.  Thanks anyway, though.
    Sep 3, 2010 2:04 PM   in reply to adam gold
    Sorry to be repetitive, but just to cap off the last remaining thread on this issue, it's now fixed in 5.0.2.
    Jun 25, 2012 4:06 AM   in reply to adam gold
    no it isn't!
