Removing Echo
Nov 2, 2007 2:43 AM
Hi all,
I'm new with Soundbooth and generally with audio software.
I have work on a recorded file that has "echo" on some part.
I've played with effects and preset actions but I haven't found the solution... You can add echo but no way to remove it!!
Is there somenone that has solved this kind of problem?
Thanks in advance.
Michael
    Nov 2, 2007 9:04 AM   in reply to (MichaelZ)
    Hi Michael,
    There was a recent post about this issue on the forum, although I no longer see it. Perhaps it was a victim of the recent forum upgrade.
    Removing echo from a recording is not a simple task, and the results are rarely perfect. You can make an attempt at minimizing echo in Soundbooth by opening the REMOVE A SOUND task in the Tasks panel. This will open the Spectral Frequency view of your file, which may show echo in frequency ranges that are above the fundamental audio you wish to keep. You can use the Lasso tool to select the echoing audio, and reduce it's volume, or delete it altogether.
    If you use Windows, you may want to download the trial version of Audition and use some of the higher end tools there. The Center Channel Extractor can be useful in isolating desired audio and removing unwanted sounds. There are other tools that can help as well, but the results will definitely depend on the quality of the source, and the amount and type of echo.
    Good luck!
    Durin
    Nov 4, 2007 2:20 AM   in reply to (MichaelZ)
    The advice in an Audition FAQ might help too - http://www.adobeforums.com/webx/.2ccd7f6a is the thread.
    Nov 5, 2007 3:56 PM   in reply to (MichaelZ)
    Soundbooth is intended to provide the kind of audio functions and working environment that people primarily working with video and flash will feel comfortable with. Audition is intended more for audio specialists (some of whom might have some involvement with video).
