Strange system log error from Photoshop CS4
Apr 7, 2009 7:18 AM
Hi.
I keep getting this strange system log error from Photoshop CS4.
It comes after a wile when using PS CS4.
I tried to chance the memory settings and scratch disc to see if that helped. It didn't.
I also checked all my ram for anything bad. 16GB in my Mac Pro Intel OS X 10.5.6
Everything is updated to latest included Adobe apps.
This is the system log error
Apr  7 16:04:03 mugge [0x0-0x28028].com.adobe.Photoshop[305]: *** error: can't allocate region
Apr  7 16:04:03 mugge [0x0-0x28028].com.adobe.Photoshop[305]: *** set a breakpoint in malloc_error_break to debug
Apr  7 16:04:03 mugge [0x0-0x28028].com.adobe.Photoshop[305]: Adobe Photoshop CS4(305,0x6a73720) malloc: *** mmap(size=132911104) failed (error code=12)
And it keeps on until i close Photoshop.
Please anybody ?? i cant figure out what this means.
Thx for help.
Erik S
Replies 1 2 Previous Next
  • PECourtejoie
    Jan 11, 2006
    Apr 7, 2009 7:56 AM   in reply to MuggeGHQ
    "malloc" does sound like a contracted form of Memory Allocation.
    What are your current memory settings? Cache levels?
    How did you test the RAM? is it Apple RAM?
    did you use any of the extensions, like disable scratch compression, or Bigger Tiles?
    Take a look at these documents:
    Optimize performance in Photoshop CS4 on Mac OS
    Troubleshoot system errors or freezes in Photoshop CS4 (Mac OS)
    Apr 8, 2009 2:10 AM   in reply to MuggeGHQ
    Have you monitored the temperature inside the machine?  An intermittently failing fan could be causing heat problems.  Just a hunch.
    Apr 8, 2009 9:32 AM   in reply to MuggeGHQ
    Hmm, I'm not sure what in Photoshop would keep allocating 128 Meg buffers.
    Sometimes that error shows when you're low on RAM, and Photoshop fails to allocate something - but then we try again with smaller buffers.
    My first guess is that the OS is trying to allocate something when called by Photoshop, and doesn't have a graceful recovery strategy.
    Next guess is a plugin misbehaving (third party, scripting or ACR).
    Apr 8, 2009 9:33 AM   in reply to PECourtejoie
    Doesn't look like a hardware problem, just software.
    Apr 8, 2009 10:41 AM   in reply to MuggeGHQ
    I also can't figure out what would be using an mmap (Photoshop itself doesn't use them).
    If you removed or disabled all the third party plugins, that should rule them out as the cause - but do double check the "about plugins" list to make sure they were disabled.
    Apr 16, 2009 5:08 AM   in reply to MuggeGHQ
    try photoshop in a new user.
    Apr 16, 2009 4:30 PM   in reply to MuggeGHQ
    At this point I would do an Archive and install of the OS and see if that fixes it.
    Apr 17, 2009 11:52 AM   in reply to MuggeGHQ
    MuggeGHQ wrote:
    But i even tried a full clone of a 100% working HD from one of my other Mac Pro.
    Same thing ???  Its like this specific Mac Pro dosent like when there is 16GB of memory installed.
    Perhaps a bad or mismatched RAM module or two?  I'd start testing it with only two sticks at a time to ferret out the possibly problem one(s).
    Apr 17, 2009 6:00 PM   in reply to MuggeGHQ
    MuggeGHQ wrote:
    Hi Ramón
    All memory blocks have been tested by me and the shop where i bought them.
    Mugge,
    The ultimate RAM test is Photoshop itself.
    All software RAM testers, like memtest, rember, etc., miss some problem RAM occasionally.
    Photoshop addresses even parts of the RAM module that software tests miss.  Even the tests used by engineers are not always definitive.
    The only way to make sure is to take all RAM sticks out, then put two back at a time and run Photoshop.  If you have actually done that, then fine, I must have missed that in your earlier posts.  But if you haven't done exactly what I've described, you simply cannot rule out bad or mismatched RAM.  It's that simple.
    I'll go back and re-read the entire thread now.
    Apr 17, 2009 6:04 PM   in reply to MuggeGHQ
    This is what I found:
    MuggeGHQ wrote:
    I used the memtest for the memory testing and i had it running all night in 6 loops. Nothing.
    Pfffft!
    Apr 17, 2009 9:43 PM   in reply to MuggeGHQ
    That's very wise, Mugge.
    Apr 27, 2009 1:11 PM   in reply to MuggeGHQ
    That sounds like  you're running a plugin that uses the Qt framework for their user interface.  (Photoshop does not use Qt, or natively generate any warnings like that)
    You need to identify which plugin you are running when the error occurs, and report the problem to the plugin authors.
    Apr 28, 2009 2:33 PM   in reply to MuggeGHQ
    The mmap error is either a third party plugin, or some system driver.
    Photoshop does not use mmap.
    Chris
    Apr 29, 2009 3:50 PM   in reply to MuggeGHQ
    A system driver is part of the system: the operating system.
    Yes, you've posted the mmap error several times now, you can stop posting that now.
    I don't know about the Bridge error, but you might want to ask in the Bridge forum.
    Apr 30, 2009 12:27 PM   in reply to MuggeGHQ
    I doubt it.
    But a poorly written plugin might run into trouble when memory got tight.
    Again, the mmap errors are probably coming from a third party plugin, or some part of the OS.
    Jul 20, 2009 5:45 PM   in reply to MuggeGHQ
    As a FYI. I have this same problem with two brand new Mac Pro's (10.5.7) Both Running new CS4 installs. Both came with 3 GB of RAM problem started immediatly, I replaced all ram on both systems, bumping them up to 8GB each. Problem persists. These are pretty much vanilla setups. I am sure it is a software setting or driver issue, I just thought I would let you know it is not isolated.
    Jul 20, 2009 9:11 PM   in reply to mark-e-r
    I would say try a setting of 80% maximum.
    And perhaps this is hardware related and that the RAM that is defective could be that on your video card.
1 2 Previous Next
Actions
