Need to Remove Auto-generated Batch File
Apr 8, 2009 10:56 AM
I inherited a RoboHelp 7 project. When I generate the primary layout of this project, it automatically generates a folder called !SSL! with another folder inside it called franksTest. Needless to say, it doesn't look v. professional to have a folder called franksTest as part of the final project that goes with the software product. I have no use for either of these folders, but I don't know how to permanently remove them, particularly franksTest, from the generated project.
Anyone have any ideas for me? Thanks!
    Apr 8, 2009 11:09 AM   in reply to CaroMe1
    Hi there
    When you generate a layout, as you have seen, the layout follows suit with what the Single Source Layout name is. So you may see a different response by creating a new layout and naming it appropriately.
    Additionally, all the files inside the folder should work independently of the actual folder name. So even if you didn't know you could rename the layout, you could rename the folder without issues.
    Cheers... Rick
    Apr 16, 2009 9:27 AM   in reply to CaroMe1
    There's no reason for the franksTest folder to be a "part of the final project that goes with the software product."
    Whether this is WebHelp or HtmlHelp (you didn't say), it's what is [i]inside[/i] that output folder that gets shipped.
    In addition, you can change the folder location to anything you want, in the first field of the first page of the Generate wizard.
    Finally, your Release Engineering peeps are in charge of naming the folder in which the help will reside (ours is cleverly called docs), whether it's distributed on a CD or hosted on your own web server.
    Good luck,
    Leon
