I am converting a word document (office 2007) which has text similar to:
when the document is converted to pdf (tried both acrobat 6 and 8.1 standard), and viewed in reader (tried both 8 and 9) the pop-up box when i hold the cursor over it looks correct, but when i click on it it tries to go to:
http://www.aaa%E2%80%90bbb%E2%80%90.com
Any ideas why this is?
M
File attached.
It seems that if i open a .txt file which has this url in it in word and pdf that, then it works fine, but if i start a new document and type this in and pdf it, it corrupts the url regardless of whether i save it as .doc or .docx.
Thanks for all of your help on this!
Message was edited by: Marsam_p - Turns out this forum will not let me upload a .doc file, so i have renamed it with .text on the end, just remove this
Hmm . . . try this one, but please note that you have to rename the file to just document3.doc as this forum will not let me upload the file if it ends with .doc
I saved the file to the desktop and deleted ".text". I printed to the Adobe PDF printer and used create PDF button, as well as the WORD conversion to PDF. All three methods worked like a charm. I had no issues with the character changes. It almost looks like you are doiing something with a WEB format, since the %x type use is for special characters in HTML. All I can imagine is that you may have some feature turned off. In Acrobat, I use the IEEE settings file (a publisher). It embeds all of the fonts and as I indicated before, you may have a font issue.
OK - I think you have hit on what is causing it, and you are certainly right that this is some sort of font issue
if i untick the 'rely on systems fonts only; do not use document fonts' option then this issue seems to go away.
Equally, it i leave that option ticked, but do not use the calibri font, then the problem also goes away.
This ties in with the fact that this problem appeared after i started using word 2007 - and thus the calibri font.
Message was edited by: Marsam_p Just beaten to it by Bernd Alheit!
You may want to look at the fonts that actually got used (if you do not embed the font - something you should do anyway for others that do not have your font). It may be that the font that Acrobat is using when the font is not embedded is not the one you think it should be. That is likely the problem. I guess I did not have a problem when I tried it because my job settings embeds all fonts by default.
When it converts correctly it just uses Calibri (Embedded subset) - Type: TrueType - Encoding: Ansi. When it does not encode properly, it also uses Calibri (Embedded subset) - Type: TrueType (CID) - Encoding: Identity-H
Not sure why, but this is clearly the issue - more here:
http://forums.macnn.com/82/applications/167946/indesign-question-what- does-font-identity/
I wonder why the 'rely on system fonts' option is not switched off by default . . .
Copyright © 2012 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
