Thumbnails disappear in Grid
Apr 14, 2009 4:49 AM
I have used LR since v1.0 with every single update in between and never had any major issues with LR including out-of-memory erros, upside-down red text on pics, adj. brush performance, now ahve run into this problem.
Thumbnails disappear just before the final high-quality pass. Scrolling out and into view make them redraw, just to disappear again together with the three dots. The neweste thread on the topic I was able to find was dated Sep, 2007: Grid thumbnails disappear after 1/2 second . It didn't solve my problem.
Some observations:
  1. The problem only affects JPEG images, all other work fine.
  2. Filmstrip is not affected, only grid view.
  3. It's only when the thumbnail info includes the file extension, both in compact and extended mode. (see screenshot 1 and 2)
  4. Metadata panel info is not shown for affected images. Keywording panel is fine.
  5. Synchronize folder fails (does nothing) if the folder has at least one JPEG.
  6. Exporting to a new catalog doesn't cure the problem.
  7. Importing images into a fresh catalog does solve the problem.
  8. Trashing prefs, TranslatedStrings.txt doesn't help.
Since the only thing that helps is a fresh catalog, my conclusion is catalog corruption. Unfortunately this is not an option for me: too many collections, VCs, flags and stacks lost. I need to cure the catalog. Binary, the catalog seems to be fine — it's been optimized and it passes the integrity test. Also I have opened it with 3rd party utilities (SQLiteSpy).
I attached a small catalog (change extension from .txt to .zip, sorry) with 1 image that exhibits the problem. It was exported form my main catalog.
    Apr 14, 2009 5:42 AM
    Did you change your screen profile in the mean time?
    Try to revert back to a standard one just to check.
    Community Member
    Apr 14, 2009 6:09 AM
    Dorin,
    I downloaded your catalogue, and yep, it does the same thing on my machine. XP SP3, LR 2.3. Cycling through the Grid modes with 'J' causes the thumbnail to appear briefly and then disappear. I'd agree with you and say it's a catalogue configuration that is badly handled by LR. Beyond that, I can't offer a suggestion other than talking to Adobe support. If I were a Lightroom developer, I'd be overjoyed to get that zip file.
    Hal
    Community Member
    Apr 14, 2009 10:37 AM
    dorin_nicolaescu wrote:
    Good idea. Sent to Julie Kmoch. I think it's her who collects broken catalogs.
    Actually, though she will likely pass them on it is Daniel Tull at Adobe that has been investigating and repairing Catalogs. He can be contacted at dantull at gmail.com to see if he will still take one and how to send it.
    Don
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
