Home/Support/
Forums
13541 Views 42 Replies Latest reply: Jan 17, 2011 12:46 PM by CZorn RSS
User 2 posts since
Aug 11, 2002
Nov 8, 2008 10:56 PM
CANNOT EXPORT MEDIA from Premiere CS4
Tried everything...
I'm on a mac. When I go to "export/media", a popup comes up, I choose my settings (in my case 960x540 PhotoJPEG @ 23.976) Click export...
It slowly opens up Adobe Media Encoder... I see the entry in the queue. I click "Start Queue".. and nothing. It just sits there saying "Loading/Waiting".
Anyone else have these problems?
I can't understand why its so difficult just to export a simple quicktime file from Premiere, unless I'm doing it wrong.
  • Jim Simon Star 17,954 posts since
    Apr 16, 2007
    2. Nov 9, 2008 7:49 PM (in response to (Wes_Ball))
    Re: CANNOT EXPORT MEDIA from Premiere CS4
    Is it possible in this case the 'source' means the original media?
  • Wade S Zimmerman User 3,166 posts since
    Apr 30, 2006
    3. Nov 10, 2008 12:07 AM (in response to (Wes_Ball))
    I just hit start queue and after a few seconds it starts the encoding.
    If this is helpful.
  • User 24 posts since
    Aug 11, 2002
    4. Nov 10, 2008 4:35 PM (in response to (Wes_Ball))
    To me, the location for your source file seems wonky. It seems strange to be in a cache or temporary item folder. Have you checked to see if those items still reside in the source folder?
  • Bill Gehrke Participant 2,028 posts since
    Nov 7, 2006
    5. Nov 10, 2008 7:59 PM (in response to (Wes_Ball))
    Sorry, I entered the PC info until I reread your post
  • Deemac1965 User 28 posts since
    Sep 23, 2004
    6. Nov 11, 2008 5:19 AM (in response to (Wes_Ball))
    I have the same problem. The source file cannot be found!! I can't find the location of this file either. THIS IS A SERIOUS BACKWARDS STEP ADOBE!!!!!!!!!!
    I am unable to render any movie files from a movie editing program!! WHAT IS THE PURPOSE OF THIS?
    VERY, VERY UNHAPPY WITH ADOBE (and it cost me £615 to upgarde to a product that no longer functions!!!!!!)
  • User 17 posts since
    Nov 19, 2003
    7. Nov 11, 2008 5:36 AM (in response to (Wes_Ball))
    Do you have CS3 and CS4 on your mac or did you removed CS3 after you installed CS4?
    If that's the case on a PC you get that error message. My solution is to remove CS3 (if you not already done) and reinstall CS4. After I did that the error message disappeared. Don't know if it works for the Mac.
    Sep 23, 2004
    8. Nov 11, 2008 6:38 AM (in response to (Wes_Ball))
    I am on a PC not a Mac.
    Yes I do have CS3 still installed. As it happens when I went back to open the file in CS3 (and re-did all the edits!!) It would still not render via media encoder!!!!! I have rendered an uncompressed version tho.
    I see were all doing Adobe's beta testing for them!!! This will be my last upgrade from Adobe unless there is a die-for facility (which there wasn't in CS4 - or CS3 or CS2 for that matter!!)
    If I can face the CS3 & 4 unistall then re-install CS4 I may try it!! (but not today - I'm completely sickened - hey must be a program upgrade free entitlement!!!!!!)
    Nov 19, 2003
    9. Nov 11, 2008 7:00 AM (in response to (Wes_Ball))
    Here the same solution: http://www.adobeforums.com/webx/.59b6f403/3
    I know Premiere can be really frustrating :). Hope they bring a update soon that will fix some annoying bugs.
    Sep 23, 2004
    10. Nov 11, 2008 7:53 AM (in response to (Wes_Ball))
    Thanks for this link. I'll look at this when I've calmed down.
    I did discover that if I rendered the movie via CS3 uncompressed, then opened CS4 Media encoder and added this file, it would then create the compressed version. Before this I moved the uncompressed file to the C drive (I usually have all my movies on external USB drives) Bit of a pain but it works.
  • User 1 posts since
    Nov 12, 2008
    11. Nov 12, 2008 9:08 AM (in response to (Wes_Ball))
    Had the same problem (re:first post above). But a re-install made it work fine. Wondering if there's a quicker command to render to bypass hitting "start queue" in Encoder.
  • GiantSimon User 7 posts since
    Aug 31, 2007
    12. Dec 1, 2008 9:13 AM (in response to (Wes_Ball))
    Hello,
    I'm on a Mac running a clean install of Adobe CS4 Master Collection - and I have the same behaviour from Adobe Media Encoder CS4 refusing to render/compress any clips from Adobe Premiere Pro CS4.
    It puts the "source file" in a temp folder -and the error log says "Could not read from the source. Please check if it has moved or been deleted."
    During my troubleshooting I've restarted the machine, moved the cache file, output files and changed caching preferences. I've fixed "permissions" on the Start up disk (a Mac-only phenomenon)
    No luck.
    I don't have and have never installed CS3 on this system - so it doesn't have that "uninstall CS3 issue."
    I DID, however, run an update from Adobe that seems to correspond with this issue. The Encoder worked before anyhow. My current version of Premiere is 4.0.1, Media Encoder is 4.0.0 from the OS, but shows 4.0.1.078 in the "About" dialog box.
    The Adobe Updater claimed that this 4.0.1 update would fix issues with the Media Encoder - I didn't give it much thought until now.
    -- WORK AROUND ANSWER --
    Since I don't have a lot of time to beta test the Adobe Software, here's what I did to work around the stubborn issue today. Open up your Premiere Sequence in Adobe After Effects CS4 and use it's Render Que instead. -- For the most part, it looks like this will solve my issue for today. Be sure to check your work. Audio levels, transitions, Title/CG effects might get all whopper-jawed from this backdoor approach.
    Fortunately, the project I have to output today is a simple video edit.
    Dec 3, 2008
    13. Dec 3, 2008 11:01 PM (in response to (Wes_Ball))
    Thanks Jamiehurt that worked for now!!!
  • User 7 posts since
    Dec 8, 2008
    14. Dec 8, 2008 1:36 PM (in response to (Wes_Ball))
    I have the same issues with After Effects CS4 on Vista x64. It started with AE CS3 where I had to render a sequence. It failed (won't start).
    After that EA CS3 AND CS4 won't render anything anymore. Even a simple timeline with a tiff sequence. The media encoder window will come up, but when choosing "quicktime" or "windows media" AE CS4 locks up.
    Currently unstalled CS4 and CS3 and reinstalling both... hope it helps.
  • Jeff Bellune Community Professional 7,517 posts since
    Sep 18, 2006
    15. Dec 8, 2008 2:13 PM (in response to (Wes_Ball))
    Perhaps you want the AE forum?
    Dec 8, 2008
    16. Dec 8, 2008 2:37 PM (in response to (Wes_Ball))
    He he I noticed later that this was the premiere forum.
    BUT the issues are the same.. No export from premiere eighter!
    The media encoder will hang Premiere.
    I reinstalled CS3 and still not working!
    WTF? It seems that I have to reinstall my whole system??
    I dont have time for this. :-(((
    Dec 8, 2008
    17. Dec 8, 2008 3:02 PM (in response to (Wes_Ball))
    ok after some speed digging i found a solution :-)
    here is is and I hop it helps for you too Wes..
    http://kb.adobe.com/selfservice/viewContent.do?externalId=kb404804&sli ceId=1
  • User 2 posts since
    Dec 12, 2008
    18. Dec 12, 2008 11:22 AM (in response to (Wes_Ball))
    This CS4 issue with media encoder seems indeed caused by files/preferences of earlier versions. But just re-install CS4 did not work for me:
    first try: Remove all CS3, install CS4 >> media encoder failed.
    second try: Remove all CS3 with preference folders, registry; install CS4 >> media encoder failed.
    third try: Make a new user account in Vista and run under this account >> worked!!!
    So, in my case media encoder still tries to use some old settings/preferences and cannot run a new timeline. (It basically cannot handle the prempro project file.) I now kept the new user account and threw away the old one; I couldn't find which settings confused the encoder.... It works now. (thanks for pointing into that direction Menno)
    I am again very surprised how unstable Adobe made this product. I had similar issues in the past; esp. with Vista. Maybe Microsoft is to blame too, but other video products seem to be tested better or are far less fragile. Luckily I had just a trial version which I will remove again; not worth spending so much money on.
    Also surprising to see that Adobe has no official fix although this issue has been on the internet for months. And it's a serious issue. It basically makes prempro useless.
    (and it's a pity, because I really like the product, when it works....)
    Dec 8, 2008
    19. Dec 13, 2008 2:38 AM (in response to (Wes_Ball))
    I made a shortcut on my desktop to the preference folders.
    If one of the Applications don't export, I can easely access the preference files and delete them.
    The bad side of doiing this is you lose all export presets.
  • User 5 posts since
    Apr 6, 2007
    20. Jan 18, 2009 1:58 PM (in response to (Wes_Ball))
    Seems to bea vista problem ???
    Can't get it working on my Vista PC (not even by installing a new user ...)
    But it works on my XP SP3 machine.
  • User 3 posts since
    Jan 17, 2009
    21. Jan 19, 2009 7:35 AM (in response to (Wes_Ball))
    I'm working on a trial version of Premiere Pro CS4 and it's been great till I got to exporting the project! The encoder opens, no problem but it only encodes one clip. Any suggestions?
  • (Arri_Reschke) User 5 posts since
    Feb 25, 2009
    22. Feb 25, 2009 6:45 AM (in response to (Wes_Ball))
    OK so i read the whole thread and there is no real solution, only some work arounds that didn't work for me at all.
    My issue id the same, Encoder won't Encode and write my Premiere files.
    - is there a way to export not using AME
    - i have tried but does anyone know if you can get CS4 files into CS3... i liked CS3 ... it could render out my files...
    please any help would be great..
    and yes i've uninstalled reinstalled etc etc etc
    running windows xp64 on mac pro bootcamp
    thanks
    later
  • egrogg011 User 24 posts since
    Oct 16, 2008
    23. Feb 25, 2009 7:38 AM (in response to (Wes_Ball))
    Hello,
    I had the same issue...what I did was change the file name to something in all lower case: test.whateveryouencodeto
    I kept getting that failed and tried and worked for me. Hope that helps.
    Apr 16, 2007
    24. Feb 25, 2009 9:06 AM (in response to (Wes_Ball))
    No.
    >can [you] get CS4 files into CS3
    No.
    Feb 25, 2009
    25. Feb 25, 2009 11:07 AM (in response to (Wes_Ball))
    awesome, i'll give the lower case a try
    if there is anyone from adobe reading... when could we expect a fix for this?
    thanks
  • Harm Millaard Star 16,716 posts since
    Aug 11, 2002
    26. Feb 25, 2009 12:04 PM (in response to (Wes_Ball))
    NEVER.
    Feb 25, 2009
    27. Feb 26, 2009 12:01 AM (in response to (Wes_Ball))
    So i tried a few other things that i read in the forums, coping a premiere shortcut to the dynamiclink directry... didn't work. Now AME won't even launch...
    but i have found a work around, which might be obvious to some/all but i didn't know about it and i'm stoked i found it.
    You can import your project into After Effects ( File--Import--Adobe Premiere...) and render out from there...
    hope it helps a bit
    if anyone finds a proper fix please post
    thanks later
    Mar 4, 2009
    28. Mar 4, 2009 10:15 AM (in response to (Wes_Ball))
    hi! I have installed CS4 master pack and it worked just fine. Today when I used Premiere at File->Export->Media... Premiere remain blocked and encoder don't start. Any Ideea ??Thanks a lot!
  • CZorn User 39 posts since
    Apr 13, 2009
    29. Apr 16, 2009 11:19 AM (in response to (Arri_Reschke))
    Hi there:
    I'm having the same problems and its frustrating me to pieces.  I'm on a really tight deadline and am a fairly new Priemiere user.  I tried importing the project into After Effects.  I do get an error, but everything seems to load in.  The timelines are not AVI's so how does AE read them and how did you encode from there?  I don't know how to use AFter Effects yet.
  • ThornieG User 29 posts since
    Apr 5, 2009
    30. May 1, 2009 12:47 AM (in response to (Wes_Ball))
    I cannot believe this. I waited until there had been patches etc.. Adobe e seminars raved about the product. Used the Clean uninstall tool to completetly remove all other Adobe products, not just CS3. Then did a clean installation. All looks well. Worked for 4 days on my project. Loving it!!! Try to export - not really an unreasonable objective, I would have thought and Media Encoder will not export. What the hell is this?!?
    Now I read in this forum that Adobe have known about this problem for some time and not done anything about it, apparently.
    Apr 13, 2009
    31. May 1, 2009 12:49 PM (in response to ThornieG)
    Hello:
    I have figured out a work around that is not particularily  technical, but
    its working for me.  My project is one and a half hours long.  Its  intended to be
    authored.  So I have many bins full of different media, tons  of titles and
    14 timelines.  Now the timelines and the renders are the issue  I'm finding.
    If your project is big, try this.  Adobe felt I could have corrupted project files,
    but I've discovered but they are not.
    Exit CS4 and create another project  folder.  THen go to open your main
    project. Resave it into the new project  with a different name so you always
    have a copy (Make sure you have a copy  of the original too).  If you don't
    have the ability to delete a number of  timelines from your project folder,
    then I would suggest cut your project  up. Yes, cut it up in parts that you
    can knit back together in Encore.  Also  make sure that your preview folders
    do not collectively exceed 85GYGs.  If  they do, delete some and only render
    out the section you want to export.   Now try going to the encoder.  It works
    for me so far.
    Repeat this for  the remainder of your project.
    We should not have to do this, but what  option do we have.  I have 6 weeks
    into my project and 6 more to go.  Good  luck and let me know how it goes.
    CZorn
  • juve User 1 posts since
    Apr 18, 2010
    32. Apr 18, 2010 4:46 PM (in response to (Wes_Ball))
    i have the same problem, plus, a little windows that opnes an says "The native instruments folder has not been found do you want to..." and a YES button, but it doesnt work. im on a MAC. can anybody help me
  • Bill Hunt All-Star 44,702 posts since
    Oct 10, 2002
    33. Apr 18, 2010 5:52 PM (in response to juve)
    Are you trying to use the Native Instruments VST's in PrPro?
    Hunt
  • Arnold Velasco User 3 posts since
    May 10, 2010
    34. May 10, 2010 5:43 PM (in response to juve)
    ^^ Im having the same problem on my MacPro and im NOT using any Native Instruments VSTs and mine is doing the same thing.... once i try to export adobe premiere cs4 project and Media Encoder opens up, the error message i get is :
    - Source File: /Users/..../Library/Caches/TemporaryItems/TEST.prproj
    - Output File: /Users/..../Desktop/Sequence 01.mov
    - Preset Used: 1280x7200 PhotoJPEG @ 23.976
    - Video:
    - Audio:
    - Bitrate:
    - Encoding Time: 00:46:16
    Sat Nov 8 01:16:24 2008 : Encoding Failed
    then a error box "(!) The native instruments folder has not been found ... when i click OK it doesnt do anything and when i try closing Media Encorder CS4, i have to force quit because its not responding.. but the error Native Instruments is still there and wont go away.
    PLEASE HELP, ive been trying for 3 days moving plug ins etc... and reinstalling and nothing works.. i dont have cs3 and
    Oct 10, 2002
    35. May 10, 2010 5:56 PM (in response to Arnold Velasco)
    Welcome to the forum.
    Besides the cited Native Instruments, what about Soundflower? Baring those two programs, there are tons of VST's, especially the "instruments," that cause issues with loading. Have you tried launching several times? Depending on the # of offending VST's, it could take a dozen re-boots, before the blacklist is fully populated.
    Good luck,
    Hunt
  • gavinpape User 1 posts since
    May 11, 2010
    36. May 11, 2010 3:24 AM (in response to (Wes_Ball))
    I work on PC and have a Premiere CS4 project which has dynamically linked AE compositions in its timeline, with voiceovers on the audio track. When I export, AME will launch and will export when I click start queue. When I play the export file, whatever the format the audio plays all the way through but only a small selection of composition footage will play, the majority of the video is just a dark screen. Very frustrating. I used CS3 up to a few weeks ago, but my new job requires me to use Production Premium CS4, and I'm not impressed with it.
    Oct 10, 2002
    37. May 11, 2010 8:44 AM (in response to gavinpape)
    This would probably be a great topic to post anew, as the people replying might get confused on exactly where this fits into such an old thread, with many other problems.
    When you do, I'd also post as much info, as is possible, to keep the questions to a minimum, and give people material to work with. They will get right to your problem much more quickly. This ARTICLE will give you some tips on the types of info that would be so very useful.
    Now, maybe one of our tireless MOD's can split this out to a separate thread, but you might want to add a bit more detail.
    Good luck,
    Hunt
    May 10, 2010
    38. May 12, 2010 11:18 AM (in response to Bill Hunt)
    this is sooooo frustrating... i have a clean copy of Premiere CS4 and never installed CS3 on my Macbook pro and it wont allow me to encode my videos. Everytime i export the media from premiere to media encoder, it keeps giving me the (!) error
    - Source File: C:Users.....AppDataLocalTempSuperman Spoof 1.3.prproj
    - Output File: C:UsersanthonyDocumentsAdobePremiere Pro3.0Sequence 01.wmv
    - Preset Used: Custom
    - Video:
    - Audio:
    - Bitrate:
    - Encoding Time: 07:47:43
    10/25/2008 2:40:26 AM : Encoding Failed
    - Source File: C:Users......AppDataLocalTempCopy of Superman Spoof 1.3.prproj
    - Output File: C:Users.......DocumentsAdobePremiere Pro3.0Sequence 01.mp4
    - Preset Used: Apple iPod Video Large
    - Video:
    - Audio:
    - Bitrate:
    - Encoding Time: 07:51:40
    10/25/2008 2:44:24 AM : Encoding Failed
    - Source File: C:Users.......AppDataLocalTempCopy of Superman Spoof 1.3_1.prproj
    - Output File: C:Users........DocumentsAdobePremiere Pro3.0Sequence 01.mp4
    - Video:
    - Audio:
    - Bitrate:
    - Encoding Time: 07:52:09
    10/25/2008 2:44:52 AM : Encoding Failed
    - Source File: C:Users.......AppDataLocalTempCopy of Superman Spoof 1.3_2.prproj
    - Output File: C:Users........DocumentsAdobePremiere Pro3.0Superman 1.3.mp4
    - Video:
    - Audio:
    - Bitrate:
    - Encoding Time: 07:54:46
    10/25/2008 2:47:30 AM : Encoding Failed
    Then another error [ The native instruments folder has not been found do you want to..." and a OK button.]
    But when i click OK it doesnt go away.. im not using nor have native instruments installed anymore since i deleted them all in my system
    HELP PLS!!
    Oct 10, 2002
    39. May 12, 2010 11:37 AM (in response to Arnold Velasco)
    Maybe this Adobe KB Article will be helpful.
    Good luck,
    Hunt
    May 10, 2010
    40. May 12, 2010 12:03 PM (in response to Bill Hunt)
    Hi Bill, thanks for the link but ive seen that one but im NOT on PC.. im on a macbook pro thanks for the link tho
  • Ernie Sigmon User 23 posts since
    Jun 10, 2009
    41. Jan 16, 2011 10:29 AM (in response to (Mennovandijk))
    You seem to have the best knowledge of the issues with exporting projects from Adobe Premiere C4 and being forced into using Adobe C4 Media Encoder.
    If you truly have found a solution, please let me know via email or forum.
    I have a 7 min video project, editing in Premiere C4... and everytime I try to export into .avi for any format, Media Encoder sits there.
    I have tried preferences, everything I can think of.  Again, I stuck with video that does work with encore, but I need much larger file
    video project formats, even flv for the internet...IN SHORT HELP.... FYI.. It does work most of the time if I add a complete video file,
    then encode, it works MOST OF THE TIME.
    thanks so much.
    ernie.sigmon@ssvideoconcepts.com
    828-778-4854
    Apr 13, 2009
    42. Jan 17, 2011 12:46 PM (in response to Ernie Sigmon)
    I know this is likely not the solution you want to hear, but all my export problems (PC based) cleared up once I moved on to CS5 on Windows 7.  So far so good and I'm working in HD. Hope you found a solution on your current platform. CZorn
