Home/Support/
Forums
1 2 3 Previous Next 36988 Views 119 Replies Latest reply: Oct 19, 2010 5:24 PM by korin unka RSS Go to original post
  • User 15 posts since
    Oct 13, 2003
    Getting very frustrated with this - after a host of different tests with various codecs I can't get the result to play smoothly - its ok on static shots (camera locked but with movement within the frame) but any pan or tilt introduces slight (or not so slight) jerks (and this has nothing to do with the camera operator as the files play back smoothly when played from the camera through an HDMI cable to a monitor.
    The other issue is the colour. This seems to be a bit of an elephant in the room around here, but as I understand it there is a problem with the H264 codec as quicktime and software that uses the quicktime codec (like CS4 and Vegas, but not FCP) reverts to sRGB which does not use the complete 8-bit colour range (0-255). The QT decoder only uses 16-235. You can see this easily if you take a MOV file shot on the 5D and change the file extension to (say) MPG - play it along side the original file playing in the quick time player - the colour difference is startling - as are the blacks/shadows. Unfortunately while players such as Media Player are completely taken in by this (the change in file extension) - Premiere isn't and won't allow the import of the "corrupted" file (damn!)
    So as I understand things, to get around that issue we cannot (at the moment) use any Adobe product to compress/change the format of the original file without unacceptable loss of picture quality. We would need a third party solution to do this (one that did not revert to using the faulty QT codec)... then import the result into CS4 ... then try to edit and export a smoothly playing, high quality result (that the Mac equipped, are showing the camera is capable of producing!)
    Either that or we wait for Apple, Adobe or Canon to provide a workable solution ...
    Anyone got a cheap Mac they aren't using? (he says through gritted teeth! - I gave them up about 10 years ago)
  • Bill Hunt All-Star 44,743 posts since
    Oct 10, 2002
    Malcom,
    I just received 5 .MOV's from a Canon 5D MKII. As I only have PP2 to work with, I Imported these into an HD 16:9 Project. UnRendered, they were a tad choppy, but after Render, they played very smoothly. There did not appear to be any Audio sync issues (mentioned in some other 5D threads), but then I didn't have a slate, or any closeups of speech, so maybe I missed something there.
    Judging from some other threads, I expected there to be problems, but found none. The Render time (Core2 Quad 2.6GHz w/ 3x 200GB SATA II's) was longer than for equal SD footage, but not that bad. I'd estimate that it was about 1:2 taking 5mins. to Render a 2:04:00 Clip).
    I only had hummingbirds with natural background, and the lighting was early AM, so fairly harsh, but colors looked "decent" on the laptop's 17" monitor - no NTSC calibrated monitor here.
    I know that this does not address many of the issues, that you are finding, and is not a complete test, by any means. Just wanted to throw out a few limited observations.
    Hunt
  • charleshull User 11 posts since
    Dec 4, 2008
    Malcom,
    The issue of proper color has been solved by Apple with the release of QuickTime 7.6.
    Note that FCP had the same issue.
    Bill, I agree that rendering the MOV clips works. I still tend to transcode to mpeg-2 and like this better. Right or wrong I feel I can do more precise color work with transcoding than with rendering.
    Oct 10, 2002
    Charles,
    One major correction that I need to make to my above comments, re: Render times is that I had tested in an SD Project (just happened to have it handy). I created a full HD Project and then the Render times went up fairly dramatically, but still within reason. I had not even considered that difference, when I first posted - DUH!
    As for QT, I still have 7.5.5 installed. Had been about ready to go with 7.6, then saw that some Premiere users were having problems with it. I'll wait to see how that one sorts out. I still recall the 7.4.x problems from not that long ago.
    I have not gotten to them point of Exporting anything from the Canon. Do not have Blu-ray, so I would be Exporting to an SD delivery format.
    I was just happy to get some of these files to experiment with, as others seem to be having problems and I had no test footage to explore. Now, I just need to get some of the MJPEG files from the Nikon D-90.
    Thanks for the comments. I also just recommended FCP to the photographer shooting the Canon, especially as he's on Mac for everything.
    Sorry about the bogus Render times,
    Hunt
  • User 13 posts since
    Dec 27, 2008
    Any of you try this guy's method?
    http://www.vimeo.com/2641870
    I have and it seems to work just fine for me.
    Dec 4, 2008
    BrantG,
    Yes, I've tried the method - it works fine. But I've found just rendering the clips is much easier. Usually CS4 doesn't want to render these MOV clips but if you add one transition this is enough to make it want to render everything, and then you are all set.
  • Calculating status... 1 posts since
    Apr 13, 2009
    Has anyone talked about GPU assisted transcoding on this thread? I've been looking into Cuda supported apps and see that TMPGEnc 4.0 Xpress will use most of the current graphic cards to really push things along in the transcoding side of things. Also why does CS4 only support cuda acceleration on the quadro CX card? A cheaper games card has everything that is needed for help us all with these h.264 files, why won't Adobe make this tech more easily available so that people don't have to migrate over to Final Cut pro? I know I'm considering it..
  • AndyUrtu User 178 posts since
    Feb 18, 2007
    Cineform has an fairly new product called NeoScene.  It is only $125.  It does a GREAT job with Canon 5D footage.
    There is also a blog about the 5D and Cineform by the head tech guy at Cineform.
    http://cineform.blogspot.com/
  • Calculating status... 2 posts since
    Apr 17, 2009
    Hi Guys.
    I found somewhat of a solution to getting smooth video working with un re-transcoded 5d2 videos, so you don't have to transcode them at all and original file size and quality will be maintained.
    What you do have to do is convert them from a .mov container into an .mp4 container, but you dont re-encode them or change codecs. You do have to process the video independently from the audio to get the converter program to successfully complete the task.
    Download "Super" file converter (freeware) http://www.erightsoft.com/S6Kg1.html
    - Drag and drop original 5d video onto Super
    - Select MP4 as container type
    - Select Direct Stream Copy for the video option (no re-encoding)
    - Select Disable Audio for the audio option
    - Pick your output folder by right clicking anywhere on super's interface
    then hit Encode. (process is quite fast of course)
    Now you'll need to do the audio on it's own.
    - Select WAV as your ouput container (if you want wav?)
    then manually sync up the wav file with the mp4 file in premiere
    Has been working great for me. It is a mystery as to why premiere is ok with Canon's H264 codec in a .mp4 container, but not in a .mov or .avi container.
    Note - During the container change you will lose the  pixel aspect flag that tells premiere how to display the vid, so you'll have to manually interpret the vid as square pixels (right click in bin on the vid clip and select interpret)
    Premiere reports the resolution as 1920 x 1088, but upon further investigation it is infact still 1080
    Good luck
    Cheers
    HC
  • Joe Chott Calculating status... 9 posts since
    Apr 15, 2009
    As it turns out, Cineform Neo Scene doesn't actually work.  It makes things worse.
    If you already have choppy video when you import 5D Mk II .mov files, expect them to be two to three times worse when using Cineform Neo Scene.
    -Joe Chott
  • Joe Chott User 9 posts since
    Apr 15, 2009
    I tried SUPER out as well, using the exact steps as provided.  No dice there either.
    I am EXTREMELY frustrated with Premiere.  I've never really used it before, but was assured by Adobe Sales prior to purchasing it that it fully supported the 5D Mk II's output format.  I can't do ANYTHING with it in Premiere.  Considering what Premiere cost, I would have expected some functionality of some kind, but no dice.
    Loading my video into a freeware app called VLC runs absolute circles around Premiere, which cannot even play the files without dropping five to ten frames for every frame played.
    -Joe Chott
  • User 2 posts since
    Apr 17, 2009
    Yeah, Premiere is very disappointing in the way it handles (or doesn't handle) some files. Have you noticed that when attempting to play the original 5d2 files, premiere is hardly even using 30% of the total cpu usage but it's still choppy, and scrubbing through the timeline is almost buttery smooth? So it doesn't appear to be a cpu horsepower related issue, but rather the way premiere/quicktime interract with eachother.
  • User 20 posts since
    Apr 10, 2009
    -Joe Chott
    Try this: import the cineform files into Premiere, save the project, quite Premiere, reopen the project.  Worked for me.  Although when I uninstalled Neo Scene after my trial ended, it messed up my computer in some way I've yet to figure out, possibly a gamma flag or codec thing.  Do NOT uninstall the trial using their uninstaller!!!
    Apr 15, 2009
    Right now, when I run video through Cineform Neo Scene, it just crashes Premiere the moment I import it.  Every time.
    After the crash, oddly, I can still save the project, but if I then load Premiere again and try to load that project, instant crash.
    So ANYTHING I do with files exported from CineForm Neo Scene causes Premiere to crash.
    I honestly don't see how the heck CineForm thought Neo Scene was remotely ready to alpha test, let alone beta test or charge money for...
    -Joe Chott
  • frostedGSXR Calculating status... 1 posts since
    May 7, 2009
    Hey everyone, here is a link to my blog going over the FREE workflow that I use[:
    http://www.frosted.ca/2009/03/26/canon-5d-mark-ii-premier-pro-cs4-1080 p-workflow/
    Cheers,
    Justin
  • capt3450 Calculating status... 1 posts since
    Jun 5, 2009
    Catmandog,
      Good find, thanks
    -capt3450
  • Bob Dix User 75 posts since
    Jun 6, 2009
    Well, you can take it onto the timeline and render the lot and go to sleep for 5 hours. in Premiere Pro 1.5.1 , you can alter the speed of the clips on the timeline if it appears too unsmooth ?
    Some if not all of the clips on a 35 min project was simply stunning. But, you need sometimes to watch the speed of say a car or tram and alter it to 85% as the Mark II canon 5D travels at 30fps and taking off the timeline unaltered can be unsmooth for a Canon HV 20 running at 25fps..
    I believe  some smart tech at Adobe can fix this simply , but, most techs on the phone verge on the incompetent.
    I am getting there with the help of a top Aussie tech working on Edius they do work with CS3 sometimes , there is an answer out there. We work in Full high definition which does not come with the trial version of CS4 , how useless is that. The techs in melboune tell me there is an issue with mov. files in CS4 and they are working to fix that ??????????????????????
    Let me know when it happens, because CS4 does not match the stunning video coming out of the Canon D Mark II  ################
    Jun 6, 2009
    Mate,
    You sure have a problem. Adobe Aussie tech says there is a problem with CS4 handling mov files from the 5d and a patch will be issued.
    But, when?
    I use a Pentium 4 3.2 GHZ running Premiere Pro 1.5.1 and the out put exported file to tape is stunning. But, I place all mov. clips on the timeline and render, it then runs smoothly, but, it takes 5 hours for 35 minutes of clips overnight.
    I do need a quad core computer.
    Ps. For any 1.5.1 uses still out there, if you have a c drive crash make sure the 1.5.1 upgrade is installed correctly otherwise it will not export to tape ???????
    Jun 6, 2009
    I agreee the video clips are stunning but, we use only PC. To render the clips for smooth running and editing is a pain but, it does work and makes the 5D look magic.
    Any other ideas ?
    Jun 6, 2009
    Yes, well you are right, Premiere Pro 1.5.1  will run smoothly after rendering but, it is slow and needs a quad computer. Pity about CS4 it has the same problem and Adobe Melbourne tech says patch on the way ????????????????????????????????
    This 1.5.1 even after five years old will produce very good high definition video on a Sony Bravia 46" but, the rendering is slow.
    There is a minor issue with this camera running at 30fps for smooth running on the timeline but, can be reduced by reducing clip speed by 84%
  • geohsia Calculating status... 5 posts since
    Jun 30, 2008
    I hope they release a patch soon.
    George
    Jun 6, 2009
    Yes, otherwise you need a bigger computer or plenty of time.
  • geohsia User 5 posts since
    Jun 30, 2008
    Unfortunately I do most my work on the road on a laptop so don't have a lot of time nor can I get a bigger computer.  My laptop already runs 8 GB of RAM with Vista 64 and has two internal HDD's and one is solid state.
  • Rainydaiz User 116 posts since
    Jul 26, 2009
    I'm not sure if this would work but i read a thread a while back where the using Mpeg streamclip (free) to convert the files into the Apple intermediate codec worked.
    Oct 10, 2002
    - I have no clue why PremierePro can't handle any Quicktime, could be that you have to install some additional plug-ins from MainConcept.
    Angleo,
    This is not quite the case. I'm working on a Project with over 100 .MOV files w/ the Animation CODEC, right from FCP. Not one problem on my PrPro PC. I have QT Pro 7.5.5.
    Now, I have not tried to handle any H.264's, but have not had a reason to do so.
    Just wanted to clear things up a bit.
    Hunt
  • fuaho User 326 posts since
    Nov 1, 2008
    I don't know what others are experiencing, but I just imported an mov file from my new 5D Mark II, dragged it to the timeline (where I got a yellow bar above it, clicked on Sequence\Render entire work area, and once the bar was green, the timeline played perfectly.
    I used an AVCHD preset of 1080p, 30fps for the sequence.
    The metadata for the clip shows Movie, 1920 x 1080(1.0), Alpha, 30.000 fps and 44100 Hz - 16-bit - Stereo.
    The sequence shows 29.97 fps, 1920 x 1080(1.0) 48000 Hz - Stereo.
    I didn't transcode, convert or in any way modify the original file. it is just as it came from the camera.
    8-GB DDR3 RAM, Core duo Quad Q9550, DX48BT2 MoBo, 1 TB eSATA RAID 10, 100GB scratch disk, nVidia GTX260XXX, WIN XP Pro 64-bit, dual 21-in Viewsonics on DVI.
  • PaulieDC User 315 posts since
    Feb 28, 2009
    Good setup, that has a big part in it.
    I don't have RAID yet (just an eSata LaCie external for a media drive), but I convert my 5D2 files to AVIs with NeoScene, and that helps tremendously. If I pile on some effects it gets a bit choppy, so I'm hoping the future RAID setup will help there. I may use my eSata drive just for scratch at that point (experimenting...).
  • Jeff Bellune Community Professional 7,518 posts since
    Sep 18, 2006
    I apologize if I missed it earlier in this thread, but does anyone have any links to sample 5D MK II footage?
    -Jeff
    Feb 28, 2009
    Jeff, on this page, scroll down to the comments, and the third comment has three links for original .MOV files that Vincent Laforet shot when he did his original Reverie short (that shot the 5D2 to stardom):
    http://www.slashgear.com/canon-5d-mark-iis-raw-video-footages-from-rev erie-one-word-stunning-2717551/
    You can also right-click on the images on this page to download some original footage (just scroll down):
    http://www.dpreview.com/reviews/canoneos5dmarkii/page19.asp
    It's easy to find 5D2 video on the web already processed... getting raw .mov files is a bit harder. I can fill up a DVD and send it to you if you like. I can send some outdoor footage and some interior low-light clips as well... you can see how it gives the Red a run for its money in low-light. Shooting at f1.4 is wild too... one-inch depth of field for video! BTW, all 5D2 footage prior to June 1st (roughly) is shot on autmatic exposure, so pumping occurs in luminance changes. Then Canon released the manual exposure firmware so we could actually CONTROL the exposure and aperture (how 'bout that), but raw footage on the web after manual exposure was released is pretty rare I think.
    OK, just yappin, back to work I go. Let me know if you'd like a DVD, I'd be happy (just takes burning a disc and mailing it, easy stuff). If not, you can at least get some idea of the file format with the download links above. I'd like to hear your take on it.
    Paul
    Sep 18, 2006
    Hi Paul,
    Thanks for the links.  That should be enough to get me started.  If I run into any issues and none of the 6 clips can break the tie, then I may ask again.  I appreciate the offer of a DVD full of clips, but I'm set for now.  Thanks.
    -Jeff
  • Maarten-HD Calculating status... 8 posts since
    Oct 4, 2009
    I had the same problem, Adobe CS3 (or 4) is not capable of editing of Canon 5D HD footage!
    Everytime the program crashed instantly....
    I'm not going to waste my precious time and money on this software anymore!
    today I have bought a eight core powermac with Final Cut Pro !
    Adobe I want my money back! CS3 is NOT working as it should be!
    By the way .....Pro's work with Mac's!
    Oct 10, 2002
    Welcome to the forum.
    This is most likely an issue with your system, how it's set up, and other programs, etc., that are running.
    Good luck with the Mac and FCP.
    Hunt
  • Maarten-HD User 8 posts since
    Oct 4, 2009
    Thank you,I'm using Adobe software since a long time,
    First Premiere 6.5, then CS2, and now CS3
    My system is a brand new Pentium Quad Core with 8 Gig memory PC with onlyPremiere installed on it.I never had problems with editing before, till I changed to HD footage, A lot of other people on the forum are complaining about this same issue, so do they also have bad PC's ?I don't think so, I have installed my pc over and over again, everytime the same thingAdobe CS3 doesn't like the footage of the Canon 5D mark 2.... period.It's Adobe problem now, on my Arts Academy were I study
    we are changing our workstations to Apple with FCP.Why? because Apple makes software that does the job, Premiere can't deliver whatit should do....good luck with trying to save your companies reputation, for me
    Adobe has made a very big mistake with their upgrade policy and bad software.....
     Adobe Encore can't even author DTS-HD files......Good luck!Best regards Maarten van Druten
  • Harm Millaard Star 16,726 posts since
    Aug 11, 2002
    Nonsense, Pro's don't use still camera's unless they are photographers. Then they use PS, not PR.
    Oct 10, 2002
    I do not recall if it was during this thread, or another Canon 5D MK II thread, but Jeff Bellune was able to edit these files on CS4.1 on a PC, with no issues. Might want to look back, and also at other similar threads for Jeff's comments and possibly exactly how he did the editing with the test files provided.
    Good luck,
    Hunt
    Feb 28, 2009
    Maarten, with all due respect, you're about 4 months late with the "no 5D2" support. I smoothly edit my 5D2 files with a simple conversion. Here's how:
    • Open your 5D2 .mov file in Cineform's NeoScene. It's a $99 program, gripe if you want to, it works.
    • With NeoScene, convert the 5D2 .mov file (which is 4:2:0) to an .AVI (it'll interpolate it to 4:2:2).
    • Import your .AVI into Premiere and edit to your heart's content. Pretty straightforward. Use a 30fps HDV sequence. Works great.
    Or use FCP and totally miss out on the seamless integration between Photoshop and Soundbooth and After Effects and Encore and Audition and Media Encoder and Fla.... shall I go on?
    And you may write back and say that forums are griping that NeoScene messes up the audio so you have to re-time it, but that's been fixed as of August 12th. Your PC shouldn't crash, that's not an Adobe issue. If you do stay on Windows, get Windows 7, I can't stress that enough.
    Hope this helps.
    Oct 4, 2009
    By the way It's Maarten (not Martin)I'm not going to pay another 99 euro's for another program only so I finally can edit HD footage in CS3.Adobe is NOT capable to make a software program now that works with HD footage, period.I rather pay 4000 dollars for a solution that really works without all the conversion rubbishTime is money.....Best regards,
    Maarten
    Oct 4, 2009
    the first feature-length film shot entirely on a DSLR camera.
    http://searchingforsonny.com/about.htm
    Welcome in the new age of photographing or is it movie making?
    By the way I'm also a professional photographer
    Oct 4, 2009
    ....I forgot when does Adobe Encore finally can author DTS-HD files? Give me a ring when this is possible
    Aug 11, 2002
    Another nonsense remark. A two year old program may not support all the latest codecs, but 4.1 does. HDV, AVCHD, P2, XDCAM, Red, in short all the common HD VIDEO camera's. That is does not support your still camera that came out after CS3 was introduced shows you are not realistic.
    Hope you have a fat wallet when you go FCP/MAC, because MAC's are like hookers, they look sexy, they are pricey but not better. And $ 4K is not enough...
    Oct 10, 2002
    Though probably a subject best posted to the Encore forum, what is the issue that you are having with DTS audio in Encore.
    First, you must remember that neither the DVD, nor the BD specs allow for DTS as a primary Audio stream. It can be used as a supplemental Audio stream only. I use it all of the time, with no issues, but use it as a supplementary Audio stream. Depending on what you are trying to do, this might be something that you'll need to take up with the various organizations that wrote the DVD and BD specs.
    Can you not use DTS as a supplemental Audio stream? Have you tried with CPT files from the DTS encoder? What happens?
    Good luck,
    Hunt
    Oct 4, 2009
    That right, the Canon 5D mark 2 came out after CS3, but were the free update patch?
    Were is the professional service?
    A lot of people already have paid a lot of money for the CS3 bundle, but it still doesn't do the job right....
    Now we have CS4 and it still can't edit h264 mov files without problems!
    I'm a student of a Art Academy Apple gives discount for students, believe me 4000 euro is enough
    and I like expensive hookers, so long the do their job right
    Aug 11, 2002
    4000 euro is around equal to $ 6K
    Oct 4, 2009
    "Normal" DTS files work in encore but not the DTS-HD encoded files....
    Because DTS-HD is optional doesn't mean that Adobe shouldn't have to support it in their software!
    DTS-HD is one of the best and frequently used audio codec so why not support it?
    Once again Adobe seems to think what is good enough for us customers, instead of listening to
    what we really want.....
    Oct 10, 2002
    What are the specs. on the DTS-HD files? That might answer some of it.
    Good luck,
    Hunt
    Feb 28, 2009
    If you'd rather spend $4000 instead of $99, then the argument is over. Do what's best for you.
    Also, I submitted my comment with your name spelled wrong, then immediately fixed it roughly 30 seconds later. Sorry I offended you.
    I would say that seeing your interest is just complaining and not about what Adobe offers, continuing to post on this thread is pointless, you should go channel your energy into the solution you prefer.
    Take care.
    Oct 4, 2009
    Your right, let's help all the other people on this forum that have trouble with editing their 5D mark 2 HD footage with Adobe software
    That's were a forum is for, right?
    Oct 10, 2002
    Looking at the Minnetonka Audio site, it appears that the output files are either .CPT, .WAV or .DTSHD. Do the .CPT, or the .WAV, not work in Encore as an alternate Audio stream?
    Just curious,
    Hunt
  • Jim Simon Star 17,966 posts since
    Apr 16, 2007
    I'm coming in to this late, so forgive if the topic has been covered.
    Has anyone tried batch converting their 5D files to Lagarith for use in Premiere (using the MPEG hacked version of VirtualDub)?  It works fine for DV.  I don't see any immediate theoretical reason it shouldn't also work in this case.  But I have neither the media nor the interest to test it out myself.
    Oct 10, 2002
    Jim,
    I do not recall anyone exploring this workflow. As there were also several other threads on the Canon 5D MK II files, maybe I missed it in one of them. Just do not recall mention being made.
    Hunt
Actions
