I've got this 4 page pdf file, and I need to save just one page from it. I know that there's the option of using the select tool and doing a copy/paste to an image file, but I'm trying to keep it as a .pdf and I can't seem to figure it out. Any help would be much appreciated.
It can't be done if you re only using the free Reader application. It requires a version of Acrobat.
If you have Acrobat, you would use Document>Extract pages to do it.
I was afraid of that. Thanks for the quick response!
Perhaps this solutions workability will depend a lot on what type and generation of PDF you got and the tech built into the program suggested....
But ! (never-the-less)
You could try to see if the "Free PDF to Word Doc Converter version 1.1" will work for you....
I know it will not get you a single page .PDF but if the program works you could get a .Doc of which you might have the possibility to save a single page after editing it !(?)
I tried nitro and the one the users above me mentioned but I'm not very much happy with the file formatting of the output file. Then i found this utility to convert a pdf to word and i got some decent results from this.Now im planning to purchase a full version . But im still bit confused. Do anybody here have any idea about this tool?
http://www.convertapdftoword.com
Regards
Martha
