Image buttons will not submit forms on ADDT insert/update
Apr 20, 2009 7:40 AM
WORKS:
<tr class="KT_buttons">
      <td > <input type="submit"  name="KT_Update1" id="KT_Update1" value="Update record" />
      </td>
DOES NOT WORK:
      <td > <input type="image" src="images/submit3.jpg" name="KT_Update1" id="KT_Update1" value="Update record" />
      </td>
Any ideas please??
    Apr 20, 2009 12:58 PM   in reply to zzipper7
    Hi Zipper,
    What kind of error are you getting. It works fine in firefox. I am assuming your talking about IE.
    Try this:
          <td > <input type="image" src="images/submit3.jpg" onclick="return onSubmit(this)" name="KT_Update1" id="KT_Update1" value="Update record" />
          </td>
    Apr 20, 2009 1:28 PM   in reply to zzipper7
    That is strange because I tested the code I posted in IE8 before I posted it and it worked fine. Were as the prior to the code change you are correct it did not work. Basically I think it boils down to an IE7 problem. Not that something is wrong with ADDT. You might want to research IE7 image submit button problems. When I get a chance I will run a test on IE7 and let you know my findings.
    Apr 20, 2009 2:17 PM   in reply to zzipper7
    Use a conditional region if IE7 CSS solution else other browsers image button.
    Apr 21, 2009 8:43 PM   in reply to zzipper7
    zzipper7 wrote:
    Thanks for looking into that. I need a solution that work for most browsers. I have a CSS solution for the submit button but my boss prefers custom images.
    Let me know what you find.
    I did a little testing and got it working without javascript. Not sure if you found a solution yet but here is one that worked for me on a simple form.
    Just add this really complex code to the form.
    <input type="hidden" name="KT_Update1" id="KT_Update1" value="Update record" />
    and the image input looked like this:
    <input type="image" src="image.jpg" />
