I'm considering buying a new Panasonic still camera which also records & saves video in "AVCHD lite" format and records audio using the "Dolby digital stereo creator". I'm probably being naive to ask but does Premiere Elements 7 accept these formats ? If not, does anyone know of a cheap & cheerful workaround until it does?
PE7 does work with AVCHD files. The one thing to consider is the power of your computer, as it takes a lot of horsepower to process these files. Your enjoyment will be directly proportional to the processing power and to your hard disk setup.
You might want to do a Search on this forum for AVCHD and also look on the fora in Muvipix. There are many articles on editing these files.
Hunt
As Hunt says, PE7 supports AVCHD, however AVCHD Lite is somewhat different than AVCHD in that it is a 720p resolution. The lower resolution allows longer files to be captured and therefore it is finding it's way into stills cameras and in some cases replacing the MJPEG codec. The only issue is that PE7 does not have a 720p project preset for AVCHD only 1080i. Therefore your best bet would be to use it in a HDV 720p project.
I tried several examples of video from the web taken with a TZ7(ACHD lite) and none worked properly in PE7 nor did they convert succesfully with VoltaicHD. I think it's too early to expect this format to be fully supported( I eventually bought a Panasonic FZ28 which does 720p video in *.mov format).
Thanks again for the response,
Mick
Good News,
Despite what Sony support says !!?!!!
Try the last version of Sony Vegas 9, it works wonderfully with Panasonic 720/50p (Panasonic codec seems to come from Sony...)
You can even render the file in 720/25p or even 720/50p (by typing 50 in the combo box)
Use File Advanced New personalized Template, Format:AVC, Size 1280x720
Binary Kbits Base Line
Profil CAVLS
Imlmage 25 or 50(type it)
Encoding 20000
Audio 192000
And you get an mp4 file with the same characteristics that your original and the same quality
It is not packed in an MPEG-2 envelope but who cares
You can even pack it after in an MPEG2-PS with VLS and get a completely comform m2ts.
Best Regards
Dominique
Good News,
Profil CAVLS
Encoding 20000
Audio 192000
Best Regards
Dominique
Copyright © 2012 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
