WORKS:
<tr class="KT_buttons">
<td > <input type="submit" name="KT_Update1" id="KT_Update1" value="Update record" />
</td>
DOES NOT WORK:
<td > <input type="image" src="images/submit3.jpg" name="KT_Update1" id="KT_Update1" value="Update record" />
</td>
Any ideas please??
Hi Zipper,
What kind of error are you getting. It works fine in firefox. I am assuming your talking about IE.
Try this:
<td > <input type="image" src="images/submit3.jpg" onclick="return onSubmit(this)" name="KT_Update1" id="KT_Update1" value="Update record" />
</td>
It is IE7....thank you for the suggestion, inserting your code unfortunately did not work.
The same code works on a regular form...it only fails on forms that are ADDT specific with no error, it just returns to the same page all fields blank....Mysql is not updated.
If I simply remove type="image", for type="submit" it works fine.
Zzipper
That is strange because I tested the code I posted in IE8 before I posted it and it worked fine. Were as the prior to the code change you are correct it did not work. Basically I think it boils down to an IE7 problem. Not that something is wrong with ADDT. You might want to research IE7 image submit button problems. When I get a chance I will run a test on IE7 and let you know my findings.
zzipper7 wrote:
Thanks for looking into that. I need a solution that work for most browsers. I have a CSS solution for the submit button but my boss prefers custom images.
Let me know what you find.
I did a little testing and got it working without javascript. Not sure if you found a solution yet but here is one that worked for me on a simple form.
Just add this really complex code to the form. ![]()
<input type="hidden" name="KT_Update1" id="KT_Update1" value="Update record" />
and the image input looked like this:
<input type="image" src="image.jpg" />
