Poor quality of all exported media
Apr 22, 2009 2:40 PM
Just started using a brand new Edit PC with PP CS4 and Matrox RTX.2    Imported AVI is very good quality and sharp when viewed on the timeline and on the output monitor, however, when I export any clips, the quality of the video appears flat and lifeless, as if the contrast has been reduced and the brightness increased.  The exported files are played on Windows media player on both this machine and several others - the result is the same.
I want to export to windows media and have used 'PAL widescreen source - high quality download' preset and windows media 9 (and several others) but the result is the same whatever I use and however I tweak the settings.  Also, if export using Microsoft AVI instead, or mpeg1 or mpeg 2, the result is always the same when I play the exported clip in windows media player.
I could convert the avi file through an external encoder to wmv, but a) I want to export direct from the timeline and b) the exported avi file has the same poor quality and c) that would be defeating the object of having CS4.
System is Vista, 4gb ram, 2 x quad core Xeon processors, ATI Radeon card, MAtrox RTX.2 v4.00x/  Prem pro CS4
Any ideas?  would the update to Matrox 4.01 help? What am I missing?  My old prem pro 1.5 exported crisp quality video every time.
Many thanks
    Apr 22, 2009 3:04 PM   in reply to Techshoot
    Sry if this sounds anti Matrox; but they have a ton of bugs running with Pr CS4.
    Fiirst try a new project Not using the Matrox presets; all native Pr presets and see if the results are different.
    Apr 22, 2009 11:15 PM   in reply to Techshoot
    Hello Techshoot,
    What is the input file and project dimensions ? Also is this issue seen with other AVIs as well ?
    Abhinav
    Apr 23, 2009 2:36 AM   in reply to Techshoot
    AVI is a wrapper, what codec is used and how did you "import" the file. Did you not capture?
    Apr 23, 2009 9:09 AM   in reply to Techshoot
    How can that be??
    Because something else is getting in your way, something you did not yet mention explicitly.
    If you want to get to the bottom of this, provide details. Non-specific remarks like an ATI card in use do not help, saying - for instance - an ATI Radeon HD4870 with driver version 9.04 makes much more sense. You left out far too many details for troubleshooting this issue.
    How to ask a question effectively...
    Apr 23, 2009 9:42 AM   in reply to Techshoot
    Ive heard of soft pal exports from a couple other users.  Sounds to me like you are doing everythig right, assuming you are testing outside the matrox presets.  That just adds another layer of troubleshooting that most of us cant duplicate.
    Try this seemingly crazy experiment:
    Drop a source clip on a pal timeline and using motion; move the clip Down in the frame 1 pixel.   Now do a test export and see if its still fuzzy.
    Apr 24, 2009 7:54 AM   in reply to Techshoot
    Due to lack of details that were requested and not given, this is the mind reader: [edited out unnecessary abusive language]. Your material is not suitable for editing, you are using the wrong codec, your PC is not up to the task, you have all kind of processes running that should not be running, your .... is causing problems. Etc.
    If you don't give details, you can't get good answers. End of story.
    Apr 24, 2009 8:37 AM   in reply to Techshoot
    I can convert the original avi through a third party converter and the result is perfect, so that tends to rule out the machine/card etc
    Actually that somewhat validates the idea that Matrox is your issue.  Try capturing with another program, Scenalyzer or WinDV.  Plug your Firewire into a different port, not the Matrox card.  Then bring that newly captured video into a non-Matrox project.  See what happens.
    Apr 27, 2009 8:19 AM   in reply to Techshoot
    This shows that Matrox may very well be the culprit.
    Apr 27, 2009 4:58 PM   in reply to Techshoot
    Do you know if the update may solve my problem?
    Sorry, I don't know.  I got so tired of Matrox issues I just removed it completely from my system.  In my experience, Premiere just plain works better without Matrox.
    May 5, 2009 2:48 PM   in reply to Techshoot
    I've been having similar issues with mpeg2 encodes in CS4, working in ntsc standard definition -- also on a hot new machine with the RTX2, Vista 64, 12 gigs ram, etc. In my tests I can get a sharper encode either using PP 1.5 on an older machine, or using a freebie stand-alone encoding program called WinFF.
    In my case, I've actually been able to get sharp encodes in the matrox avi format --  those turn out fine for me. But once it goes to the AME for mpeg encoding, then it gets fuzzy. I've tried the 1 pixel offset, but that hasn't really made much of a difference.
    The thing I like about the matrox card is that it gives me video output to an external monitor from the timeline as well as the source window within Premier CS4 ... and I assume it probably speeds up some of the rendering. I just don't feel like I'm getting a really good quality image when I'm using the windows media player or other players on my computer monitors. So I really rely on my external CRT monitor to judge sharpness, density and colors, as well as titles.
    What are you doing for output monitoring, now that you've pulled out the RTX2 card? I've been wondering what other options there might be that would work well with CS4.
    You might check out WinFF -- it seems very fast and so far it's been working well for me. I'm not in PAL. so that might make a difference ...
    On the brightness issue, it might be worth checking to see whether you have the latest video display card drivers -- another user found that made a big difference in image quality. However, I don't think in his case that it was related to his mpeg encodes.
    Bill Matthiesen
    May 5, 2009 10:13 PM   in reply to Bill Matthiesen
    Since I only work with DV, a Firewire pass-through from my camera to my monitor does the trick.
    May 6, 2009 6:44 AM   in reply to Jim Simon
    Thanks, Jim ... I'll try that.
    Bill
