--Only tried on Windows Vista - For those who upgraded from Photoshop CS3 to CS4 and lost the ability to associate Photoshop with specific file extensions (like .jpg) because it didn't show up in the "Openwith" list. You might want to try this fix:
Because the upgrade install did not update the following registry entry;
[HKEY_CLASSES_ROOT\Applications\Photoshop.exe\shell\open\command]
Mine was still set to
@="\"C:\\Program Files\\Adobe\\Adobe Photoshop CS3\\Photoshop.exe\" \"%1\""
Windows doesn't see the new CS4 version as an application and if you have uninstalled CS3 it doesn't see Photoshop as an application period.
Type the following in a text file and save it with a '.reg' extension. Make sure that the path is correct in the last line and uses the exact syntax shown (cut and paste should work but make sure you check that the Photoshop.exe file path is correct for your machine.) Save it to your desktop and double clicking it should automagically update your registry.
This is much safer than mucking about in regedit but still be careful not to make any typos, they can have unexpected results.
========= start file at next line
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\Applications\Photoshop.exe]
[HKEY_CLASSES_ROOT\Applications\Photoshop.exe\shell]
[HKEY_CLASSES_ROOT\Applications\Photoshop.exe\shell\open]
@="\"C:\\Program Files\\Adobe\\Adobe Photoshop CS4\\Photoshop.exe\" \"%1\""
========== end of file at line before this
Why Adobe didn't do this in the install is beyond my simple mind to ascertain.
You must be writing about 32 bit?
Your showing a lot more slashes too. Maybe that is correct using that software you mentioned?
My 64 bit version works fine, with no edits, and this is what I have showing in the Hive in command box section since install:
Value name:
(Default)
Value date:
"C:\Program Files\Adobe\Adobe Photoshop CS4 (64 Bit)\Photoshop.exe" "%1"
Thanks tonyperry1951
I was having trouble in Windows 7 with CS5 and Windows Photo Viewer. Photoshop was not shown in the "open with" list of programs and would not load from the browse button.
I followed your registry instructions and found that I had an old line with CS4 in it. I changed the 4 to a 5 and that fixed the problem. This is what my registery looks like now.
"C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\Photoshop.exe" "%1"
Thanks for your help with this fix.
Dwayne
The problem is not the upgrade. The problem is you installed a newer version and THEN deleted the older version.
It is quite common for the flie associations to then revert to the old (uninstalled) version.
Best advice is to leave all versions on your hard drive. If you need the space then uninstall old version BEFORE installing new version.
If you uninstalled the old version and have file association problems you can uninstall the new version, run Adobe Script Cleaner to get rid of a pieces left behind, and then re-install the new version.
I have the problem of similar type with PNG files not being seen or recognized by CS6 in Win 7. I went to Bridge file association and PNG is not even listed there! It worked until a few days ago... uninstall and reinstall CS6 is a pain for all the plugs and actions I have in it... any suggestions from anyone is welcomed!! Thanks!
I managed to have a discussion (chat) with Adobe today and we reduced the problem to plugins. Holding down the "shift" key (not control) and double clinking the CS6 icon brings up the window to alow CS6 without plugins support and then the PNG worked... so then it was a matter of letting the plugins back one by one. So he suggested to rename the plug-ins folder to plug-insold. and create a new plug-ins folder and copy them one-by one and open and close CS6 and the PNG file for each and see what happens. So far I opened all my plug-ins back except for OnOne7--which I just instaled a couple of days ago.. that may be the one causing the trouble.
Yes, you are right. I will send them a support note of what happened. Albeit lately I had some issues even with their responsiveness: They suggest that a TIFF file is a "flatened" file in Photoshop.. I can't help but wonder if they are REALLY keeping up with the times.. I cannot recal the last time a TIFF did not keep layers... someone's head at OnOne is definitely in the sand.. not sure why!
