Saving Fillable Form as non-fillable PDF
Apr 8, 2008 10:41 AM
  Latest reply: Hunny Kaushal, Mar 25, 2013 7:37 PM
Replies 1 2 3 4 5 ... 10 Previous Next
    Mar 26, 2009 6:16 AM   in reply to (Tricia_B)
    I'm interested in the script you're proposing. Can you post it to me ?
    My email address nanfymele@yahoo.fr
    Eric
    Mar 26, 2009 6:31 AM   in reply to (Tricia_B)
    Just sent it
    Mar 26, 2009 7:52 AM   in reply to (Tricia_B)
    Might be a noob question again:
    Is it possible to save a half filled out PDF as still fillable?
    Do you need special rights to do so?
    Mar 26, 2009 9:02 AM   in reply to (Tricia_B)
    Yes you can .... if you are using Reader you need to Reader extend it to allow for local saving.
    Mar 27, 2009 1:47 AM   in reply to (Tricia_B)
    This may be of some help, it is possible to add some of the reader extended functionality by opening and saving the LiveCycle form in Acrobat, all reader extended functionality is not added but it does allow a user with only Reader to save a half filled form
    See JasonCPs reply to "Can live cycle create a PDF form that is saved on a desktop and filled out simply to be attached to "
    Apr 9, 2009 12:39 PM   in reply to (Tricia_B)
    Hi Paul, I was looking all over the Internet for the script. Can you please send me the script? Thank you!
    My email address is joshmok@gmail.com
    Apr 10, 2009 11:06 AM   in reply to (Tricia_B)
    Another option you can try is that if the document has been Reader Extended and the user saves the document, force them to save it as a Static pdf. Then they should not be able to change the form.
    Apr 14, 2009 11:07 AM   in reply to (Tricia_B)
    Paul:
    I am interested in your script.
    C. Corwin
    Cheryl.Corwin@bcbsks.com
    Also, could you tell me if your script would work with a fillable form that uses pagination.  We have a fillable form that the pages fillable are dependent on one of the radio buttons selected at the beginning of the form.   Once a selection is made the form is refreshed and the pages are chosen based on that radio button selection.  After the form has been filled out we would like to save the completed form as a non-fillable form.   However, everything we've tried so far to save the form as non-fillable continues to break the pagination.   When we open the saved form it continues to display all the pages of that form regardless of the selection made at the time the form was fillable.  Perhaps this is altogether another issue.  Any thoughts would be appreciated.
    Apr 17, 2009 8:23 AM   in reply to (Tricia_B)
    Paul, This script would be a very valuable tool for my company, could you please send this script to me.
    Thank you in advance!
    Jay
    sydewinder99@yahoo.com
    Apr 20, 2009 6:31 AM   in reply to sydewinder
    Here you go
    Apr 20, 2009 12:53 PM   in reply to pguerett
    Paul, It may be Yahoo, but I don't see the attachment, Could you try again to send script.
    Thanks, sorry for the problem. Jay
    Apr 20, 2009 1:31 PM   in reply to sydewinder
    Just sent it to your email.
    Apr 21, 2009 3:34 PM   in reply to pguerett
    Paul:
    I am interested in your script as well.
    C. Corwin
    Apr 22, 2009 5:17 AM   in reply to C. Corwin
    Just sent it
    Paul
    Apr 27, 2009 9:29 AM   in reply to pguerett
    Mr. Guerrette -
    I saw your post about a script you have that locks "fields" within a form.  Is it possible for you to send me your example?  Second, can your script be modified so that it only "locks" certain fields and not others?  I am trying to send out a pdf with some "prefilled" information that I don't want changed, but allow the end user to fill out the remaining fields.  But my prefilled information would change case-by-case. Also, will this script run with adobe reader?  Or just Acrobat? or Acrobat pro?
    Your response would be greatly appreciated.
    e-mail libycal@yahoo.com
    Apr 27, 2009 10:32 AM   in reply to chadliby
    The script expects you to pass a subform and it will lock everything inside of that subform. In most cases people will pass the root node of the form and then everything gets locked down. If it makes sense to put all the fields you want to lock into a subform then this sample will be useful; otherwise, you may end up having to lock then one by one.
    It looks like the attachment issue have been fixed on the forum so I will attach it here.
    Paul
    Apr 27, 2009 11:03 AM   in reply to ibwaheemi
    Please send one to me too, thank you!  --Elaine
    amalelaine@gmail.com
    Apr 27, 2009 11:20 AM   in reply to Elaine Schmitz
    I posted it in the previous reply ....is it not there for you?
    Paul
    Apr 27, 2009 12:31 PM   in reply to pguerett
    I apologize.  I'm getting used to the new forums... Thanks Paul!
    Apr 28, 2009 6:31 AM   in reply to (Tricia_B)
    Paul,
    Thank you for sending me your script, it worked perfectly!!!. However, I was wondering if the email purchase order button could be excluded from the lock all fields function. My purpose is to lock all fields prior to emailing my purchase order. But, after locking the form, the email purchase order button is also locked.  Is there a way to exclude this button from being locked?
    Thanks again, and look forward to your reply.
    Jay
    Apr 28, 2009 7:01 AM   in reply to sydewinder
    In the case statement that locks the field , you can do a further test for an object by that name and exclude it from being locked.
    Make sense?
    Paul
    Apr 28, 2009 6:17 PM   in reply to pguerett
    Paul,
    Script me too at  iakov_qvaz@hotmail.com Thank you.
    Apr 29, 2009 5:19 AM   in reply to Iakov Qvaz
    The sample form is posted as an attachment in a previous post of this thread.
    Paul
    Apr 29, 2009 3:52 PM   in reply to pguerett
    Hi
    Can you also send me the script, my email is manoj_goel@msn.com
    Thanks in advance.
    manoj
    May 14, 2009 1:48 PM   in reply to pguerett
    Good Afternoon,
         I have been reading all the post pertaining to saving a fillable form once filled in by employee to a standard pdf file. It appears you have written some could which would do this. Is it possible to obtain this code. I designed the form in Designer 7.0 .
    Bob Selff
    email- bselff@cox.net
    May 18, 2009 1:18 PM   in reply to pguerett
    Hi Paul
    The topic of this thread is of interest to me as well. I have a form that we are using to create a document that we want to save as a uneditable pdf that we will send to our customers. What I would like to be able to do is to create the form in lifecycle, with a "button" on it for the person to lock the form with the data in it, and save the document as a new pdf.
    schadt.richard@basco.com
    May 19, 2009 5:12 AM   in reply to RSchadt
    Here is a sample that will lock all of the fields on a form.
    Paul
    May 28, 2009 9:32 AM   in reply to pguerett
    Hi Paul,
    I am a newbie to LifeCycle Designer 8 but have had great success creating fillable forms that can be accessed through our intranet.  Once the form has been completed by people using Adobe Reader I would like them to submit the form by email but I do not want the recipients to be able to change the information submitted on the form. (I have also chosen the Acrobat 8 Pro option "Enable User Rights in Adobe Reader")
    Do you have a script that would help me prevent the recipients from changing the submitted information?  If so please send to: pmiles@cloverdalepaint.com
    thanks, Peter
    Jun 1, 2009 10:40 AM   in reply to Peter_Miles
    The sample was posted in th eprevious post to this one ...you can simply grab it from there.
    Paul
    Jun 1, 2009 2:53 PM   in reply to pguerett
    Thanks very much
    Aug 6, 2009 4:06 PM   in reply to (Tricia_B)
    Aug 6, 2009 4:43 PM   in reply to pguerett
    Aug 10, 2009 4:55 AM   in reply to CharleyRH
    Simply add code to the script to check for the button name and when you get it do not lock it.
    This means that the button will always be available.
    Paul
    Sep 13, 2009 9:35 PM   in reply to (Tricia_B)
    Hi Paul,
    Can you send me your script to norbert_ds@yahoo.co.in.
    Thanks in advance
    Norbert
    Sep 14, 2009 6:04 AM   in reply to nobitto
    The sample form has been included in an earlier post in this thread!
    Paul
    Sep 23, 2009 2:27 PM   in reply to pguerett
    Paul,
    bush12341234@gmail.com
    Sep 24, 2009 5:37 AM   in reply to Bush12341234
    The sample form is included as an attachment earlier in this thread!
    Paul
    Sep 24, 2009 10:52 AM   in reply to Bush12341234
    If you get it, could you forward it to me. I have tried, and somehow can not
    seem to get a copy of it.
                   Bob
    Sep 29, 2009 1:26 AM   in reply to pguerett
    Hello, I'm also interested in the script to locck all the fields. Please can you mail the form at marius@mjm.no?
    Sep 29, 2009 6:00 AM   in reply to mariusm74
    Here it is again .....note that you must connect to the bbs to be able to download the file. It will not show up in your email notification.
    Paul
Actions
Bookmarked By (2)
