Apr 27, 2009 11:08 AM
Using Photos to Create a Header
Like (0)
Currently have PE 5 and would like to know the easiest and quickest way to create a blog or web site header using only photos.
If there is a video, text or combo thereof that walks a person through this process, it would greatly appreciated.
Scielement
Can you point us to an example of what you are trying to acheive?
Hi Bob,
Thanks for your follow up.
Please go to the following web address
http://paulasambel.point2agent.com/
and look at the photos of the couples at the top.
I would like to create the same/similar effect using different photos.
Please advise.
Paul
Well, I don't know of a tutorial, but it's fairly straighforward:
I just made this example:
Pick your six photos and open them in the PSE Editor
Use the Crop tool to crop them to the right Aspect Ratio. Your example uses 10x8 (Set the Crop Tool Aspect Ratio to 8x10 and then click the little double arrows to get it to be Width 10in Height 8in)
Then, resize them all to 130 pixels Wide x 104 pixels High
Use Image>Resize>ImageSize... make sure Resample Images is checked, and then set the pixels (130Wx104H) in the Pixel Dimensions box.
Now, open the attached Banner.psd file [Note: This site won't let me upload a .psd, so I changed the extension to .txt. After downloading it, change it back to .psd]
Drag each of your images into this file to create a new Layer for each image. (Use the Move Tool to drag and drop)
You can do this by simply having the two image windows side by side, and litterly dragging from the image window onto the banner.psd window.
Drag all six, and arrange them in the order you want. Positioning does not have to be exact, except for the one all the way on the left and the one all the way on the right.
You should now have the layer from the origional Banner.psd file, and six new layers.
Select all six of the new layers by holding the CRTL key down and clicking on each layer in the Layers pallette.
Then, select Align>Vertical Centers in the Tool Options Bar near the top of the window
The select Distribute>Horizontal Centers from up there as well.
Now, add an outside Stroke (black border) to each image
In the Effects pallete, select the Layer Styles filter, and then select Strokes from the pulldown.
Drag and drop the Black Stroke 0.5 Px onto each of your images.
Now, arrainge the layers so that you have one of the included Photo Filter layers on top of each of your photos by simply dragging the layers up and down to get them in the right order.
And, for the faded Color Left B&W Right effect, drag the Hue/Saturation layer up to the top.
You should end up with something like:
Hue/Saturation 1
Photo Filter 6
Layer 6
Photo Filter 5
Layer 5
Photo Filter 4
Layer 4
Photo Filter 3
Layer 3
Photo Filter 2
Layer 2
Photo Filter 1
Layer 1
Where Layer 1 is that layer with your Photo 1, Layer 2 = your photo 2, and so on.
You can play around with the effect of each Photo Filter layer by double clicking on the little circle that's half black and half white.
Once you have it all as you'd like, save it for your web banner using File>Save for Web.
There you go.
Not too tough.
Cheers
Bob
Hi Bob,
Thanks for your reply.
Read through your instructions and wondered if you wouldn't mind including some screen shots fo what your talking about.
If you decide not to, I'll understand.
Paul
Sure. I'll go edit my origional post with some screen shots.
If there are any particular steps you like to see first, let me know.
I'm using PSE7, so my screen shots are a little different than PSE5
Hue/Saturation 1
Photo Filter 6
Layer 6
Photo Filter 5
Layer 5
Photo Filter 4
Layer 4
Photo Filter 3
Layer 3
Photo Filter 2
Layer 2
Photo Filter 1
Layer 1
There you go.
Not too tough.
Cheers
Bob
Hi Bob,
I did not receive the attached Banner file that was converted to txt.
Please email this to me.
Paul
So everyone can enjoy it, it's attached again to this response.
Just click on banner.txt below, save it to your hard drive, and then rename it to banner.psd.
Cheers
Bob
[EDIT: The banner.txt line below is currently showing Queued. Just scroll up to my origional long tutorial without the screenshots to get it.]
Hi Bob,
Thanks for all your help.
I was able to get what I was looking for regarding the photo header.
Thanks again.
Paul
Copyright © 2011 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
