Apprently Afte reffects takes my aduio out when i export it in a AVI. All I did was green screen background and export it and even if i dont green screen it still does it! PLEASE HELP!!!!!!!!!
What is the source format of the stuff? Also, when you say you can hear the audio, is it clear or are there any disturbances? To what specific CoDec do you render? If you render uncompressed, it's well possible that the data rates are simply too high and the system can't keep up. It also is important, where you play the file. Have you tried alternate player software like WinAmp, VLC or VirtualDub even?
Mylenium
Avastjonny: It's very important that you provide more information, as the other forum members are requesting in order to help.
What AE version are you using? What format is your audio? Is it a separate audio file or is it embeded in a video file?
FWIW, in After Effects CS3 and later, MP3 audio is supported (it's actually converted to PCM, ie WAV/AIFF in import). In previous versions, yes, converting to AIFF/WAV would be a good idea? Other compressed formats, like AAC, could be a problem.
AVI is not a codec actually, it's a file type. AVI files can have a numerous different codecs. So when you render, in the output module, when you clic on format option, what is the codec used ?
My guess is you are exporting to uncompressed avi file, which are enormous and thus can barely be played in realtime on a non raid hdd.
Because, if your exported avi, once reimported into AE have the whole waveform and you can preview it al along with sound, then it doesn't come from AE, but from your Media player.
