how to float an image left of a underlined header?
May 2, 2009 6:12 AM
..well that is the question.
Here is an example of how I would like the result to be (look halfway down the page): http://www.ecstechnics.com/modules/page.phtml?dimensionid=18&pageid=24
I can make a simple header that sits to the right of a left floated picture, but as soon as I make a class with a simple line drawn underneath in it and attach that to the header, the line goes straight thru the picture.
I attached the main css file as text file.
The style applies to the container called "inhoud"; the classes used to draw line are .wide (full container width) and .short (400px wide). It is this last one that I need to work with a floating picture.
Thanks for any suggestions
Erik
ps: the same question was posted here http://forums.adobe.com/thread/427454?tstart=0 and here http://forums.adobe.com/thread/427154?tstart=0, but without the main.css rules attached as text file.
    May 2, 2009 12:19 PM   in reply to Erik Arckens
    Your example page is built with tables.  Images are in <td>.  Descriptions are in adjacent <td>.
    CSS floats do not behave the same as table columns.  You should place your headings above the float.
    See my example here (view page source to see the CSS and HTML code).
    http://alt-web.com/DEMOS/floatRight.html
    Nancy O.
    Alt-Web Design & Publishing
    Web | Graphics |  Print | Media Specialists
    www.alt-web.com/
    May 2, 2009 6:49 PM   in reply to Erik Arckens
    Why are you asking the same question in multiple threads?!
    See my reply in Re: CSS style rule question: positioning of block level next to image where I said:
    See my reply #8 in your other thread Re: css style rule question
    Although you may want a .shortRight and a .shortLeft, now.
    Mark "Daisy Chain" Boyd
    Keep-On-Learnin' :-)
