mpvrana
Preserve Local Formatting script and CS4
May 7, 2009 8:41 AM
Unfortunately, Dave Saunders' amazing PreserveLocalFormatting.jsx script (that changes local formatting to character styles) doesn't work under InDesign CS4. I've tried running it both as-is and in the compatibility mode (putting it in a folder marked Version 4.0 scripts), and it seems to star to run, but doesn't actually do anything. Anyone more versed in scripts know what might be the trouble?
http://indesignsecrets.com/downloads/PreserveLocalFormatting.jsx
    Community Member
    May 7, 2009 9:14 AM
    Perhaps even better: my amazing preptext.jsx (http://www.jongware.com/binaries/preptext.zip).
    It runs under CS4 and has a plethora of other formatting combo's that it checks. It also has a progress bar
    Community Member
    May 7, 2009 2:26 PM
    ad a. You got me there. The script forcibly creates new styles with the exact attributes it should -- i.e., if not "Italic" or "Bold", well, then ... it's "Regular". It's a pain to edit these styles afterwards, and in fact the version I use (daily) doesn't do that any more. Remind me to upload that one instead.
    ad b. You got me there. Small scripts can be copied-and-pasted into forum messages, but larger ones cannot be attached to messages. So if I write a larger script, I zip it (to prevent download issues), dump it on my site and post the link here.
    Every now and then I visit Peter Kahrel's scripting pages and think, "When I have the time ..."
    Community Member
    May 8, 2009 4:56 AM
    http://www.jongware.com/binaries/preptext.zip is refreshed to the new version that does not forces every attribute to be set or clear.
    Community Member
    Aug 5, 2009 2:23 AM
    Can you tell me what the script exactly do and how to use it ?
    I suspect i need it but there it lacks some infos…
    Community Member
    Aug 5, 2009 3:38 AM
    The script searches for text formatted with Bold, Italic, Underline, Superscript, Subscript and Small Capitals and replaces it with a character style with an appropriate name. Replacing manual formatting with a character style has significant advantages, the most important ones are that you no longer can accidently remove them (when overriding paragraph attributes), and afterwards, you can change the styles at will.
    There are a few points you must keep in mind:
    1. The script searches for font styles named "Bold" and "Italic". If you happen to use a font where these are called "Semibold", "Black" or "65 Bold" or "Slanted", "Oblique" or "46 Light Italic" it will not find these. If you need styles applied to these attributes, do so by hand.
    2. The script searches for attributes such as "superscript", "subscript", "small capitals". If small caps are faked in the document with capitals in a smaller font, the script will not find them. If superscript or subscript are faked in the document with a smaller font size and some baseline shift, the script will not find them.
    3. Word has a lot of different underline styles; InDesign only has one. It is possible to search specifically for 'double underline', 'dotted underline', etc. but you have to do this by hand. The script picks up any and all kinds of underline as one and the same -- Underline. (See also #5 below.)
    4. The script creates new character styles as needed; these are all independent, not based-upon eachother. If you have 3 styles with 'Bold' in them and you want to change the bold font to semi-bold, you will have to do that for each separate style that contains Bold.
    5. Any formatting other than those mentioned is not preserved or changed by this script. If you suspect your document has other types of formatting you want to preserve, replace these by hand with character styles. The script is hardcoded to ignore text that already has a character style,  something you can use in your advantage (when done properly).
    Read the ID Help or http://indesignsecrets.com/how-to-install-scripts-in-indesign.php for instructions on how to install and use scripts.
    Community Member
    Aug 5, 2009 3:44 AM
    Ok Thanks, it works very well. Now let me ask a dumb question : Why i would want to do that ?
    I mean if i don't so that i will loose the italics for exemple ?
    Community Member
    Aug 5, 2009 3:52 AM
    Ever seen a paragraph style name with a '+' added to it? That's an indication the paragraph contains 'local formatting' somewhere -- a manual override of the formatting in the paragraph style. If you select some text and apply "Italic", well, that's a manual override -- the font in the paragraph style specifies "Regular".
    The problem with manual overrides is that they can disappear without warning. Try this: select some text in your document and underline it -- the paragraph style name will gain a '+'. Alt+click the paragraph style ("Apply Removing Overrides") -- the underline disappears. Or: change the paragraph style, adding 'underlined' to it. Press "OK" (all paragraphs in that style will be underlined), then change the style back, removing the Underline. Your manually applied underline will be gone.
    If you never had any of these problems -- or you don't think of it as a problem -- you don't really need this script...
    Community Member
    Aug 5, 2009 4:26 AM
    I have another question : if i use 2 fonts and they don't use the same name for italics :
    — italic
    — book italic
    It seems the script is lost with it, what can i do about it ?
    Community Member
    Aug 5, 2009 4:27 AM
    That was #1 of my 5-point "Watchit" list.
    Community Member
    Aug 5, 2009 4:35 AM
    Yes sorry…
    So it's not possible to update the script and make it create 2 styles i guess ?
    Community Member
    Aug 5, 2009 4:52 AM
    The main point is that the script cannot know in advance what the italic fonts are called.
    I usually use 'Find Font' on new documents, and if I see quirky bold or italics, I just replace them immediately with a regular "Times New Roman Bold" and "Italic" so I'm sure the script will pick them up.
    Community Member
    Aug 5, 2009 4:56 AM
    Maybe is should try that…
    Another way to do that would be to change the name of the font 'book italic' to 'italic' but i don't know how to do that, should be possible… ?
    Community Member
    Aug 5, 2009 5:46 AM
    Yes, that's exactly what I do with "Find Font".
    Community Member
    Aug 5, 2009 6:08 AM
    No i mean change something in the font file that would change the name of the italics.
    But i don't know where is that code and how to change that…
    Community Member
    Aug 5, 2009 6:10 AM
    + all the Book Italics are used in notes here in my document, and it seems you can't search in notes…
    Community Member
    Aug 5, 2009 6:47 AM
    You lost me there. You don't change the font itself, you change the font used in your document. Then you run the script. It tags all italicized text with one unique character style for "Italics". If you don't have a regular italic in the font used, all you have to do is change the character style.
    It sounds as if the text you work on has already been formatted. Running scripts that mess with texts over "almost finished" texts may have been an invitation to disaster ...
    Community Member
    Aug 5, 2009 7:26 AM
    Let be clear.
    I have a final text, with styles, in a word document.
    In indesign i use one font for the main text, it have a real italic, called italic.
    I use another font for footnotes, the font have italics too but its called 'book italic'.
    So i run you your script, it works for the main text.
    But for the footnotes i doesn't work, tried to apply an 'italic' style when the italic is called 'book italic'…
    I can't fixe that seaching for italics on a specific font and change it for book italic for 1 reason :
    — you can't seach in footnotes (it seems)
    So i thought if i change the name 'book italic' for 'italic' in the OTF file, it would work.
    Community Member
    Aug 5, 2009 7:52 AM
    Aha -- your footnote font differs! Yes -- sometimes I have to mix two fonts that apply different naming schedules, and in that case the script straightens things out that should stay crooked
    You can make a new character style named "Book Italic" (with its style set to the correct italic font). Then do a search and replace; search for "Formatting" -> Character Style "Italic" and Paragraph Style "(your footnote paragraph style). Replace with Character Style "Book Italic".
    Community Member
    Aug 5, 2009 8:07 AM
    Thanks for the tip i'm gonna try that.
    PS. Offtopic but… do you know any word count script for Indesign ?
    Community Member
    Aug 5, 2009 8:45 AM
    That, unfortunately, depends on your definition of a word
    If you click your text cursor in a text frame, InDesign shows you the number of "Words" (and Characters, Lines and Paragraphs as well) in the Info panel.
    This thread http://forums.adobe.com/message/2151036#2151036 shows an alternative way of counting.
    Community Member
    Aug 5, 2009 8:47 AM
    I made the search thing and it worked very well, thanks a lot for your help !
    Community Member
    Aug 6, 2009 2:46 AM
    It only occurred to me this morning -- there is no problem at all with 'other italics'!
    Simply first replace "Book Italic" with a custom character style, and then run the script. The script is smart enough to leave existing character styles alone.
    Community Member
    Aug 6, 2009 2:58 AM
    Sorry but what do you mean by "replace "Book Italic" with a custom character style"
    Community Member
    Aug 6, 2009 4:15 AM
    #5. Any formatting other than those mentioned is not preserved or changed by this script. If you suspect your document has other types of formatting you want to preserve, replace these by hand with character styles. The script is hardcoded to ignore text that already has a character style,  something you can use in your advantage (when done properly).
    So, in a fresh document (that has no character styles!), you can safely apply a custom character style to the text in the "Book Italic" font.
    • Create a new character style for the Book Italic font -- you should not call this style "Italic", obviously!
    • Call up the Find/Change box
    • In Find Formatting, enter the name of your font and "Book Italic" as the font style
    • In Change Formatting, set the character style to the one you created.
    • Check if "Include Footnotes" is on
    • Hit "Replace All"
    Then run my script -- it will not change existing character styles.
    Community Member
    Aug 6, 2009 4:30 AM
    Ok i got it
    But this is the same as doin what i've done for my document, wich is : doing that AFTER running the script…
    Same results, right ?
    Community Member
    Aug 6, 2009 6:45 AM
    Yes, but that's because the script did not pick up the 'book italic' in the first place ...
    Suppose you have a document with Times Italic and Helvetica Italic, and you want both to be preserved in their own font. Then you would have to change at least one of them to another style before you run the script -- to prevent both fonts get tagged as "Italic".
    I have to do this almost every day, so for me it's becoming 2nd nature ...
    Community Member
    Dec 8, 2009 8:03 AM
    A super script. How to use it also in foonotes?
    A good idea is to apply colours to the character styles. With this the document is very fast tested and subject to other exercises.
    Thank you.
    Community Member
    Dec 8, 2009 8:46 AM
    Super-script -- also known as "superior"!
    It needs nothing special, it already should work just fine in footnotes, as well as in tables. The script searches the entire story. (An important note is that anchored objects contain "their own story" -- it does not work through to these as well.)
    Ehm, the 'color' part is not entirely clear. Do you mean you want to see your italics (etc.) also in another color? When the script is finished, you can change the automatically created character styles and add some color to them.
    Community Member
    Jan 6, 2010 3:10 PM
    Jongware's free script is wonderful and a great help to many people. You might also look at the Create Basic Character Styles and Create All Character Styles features in the Blatner Tools plug-in (dtptools.com/bt), along with the Create Paragraph Styles (which can create paragraph styles for you throughout an unstyled document).
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
