Fireworks CS4 updater 10.0.3 is LIVE
Adobe Employee ,
May 05, 2009 May 05, 2009
The Fireworks CS4 application has released the much awaited patch to fix some of the big issues related to text and stability. The update can be downloaded from http://www.adobe.com/support/fireworks/downloads_updaters.html . The automatic update for the application from Adobe Update Manager (AUM) is coming shortly.
After applying the update, please ensure that the version screen now shows as shown below.
Fireworks CS4 update About us
We await your response to this update release.
..Sarthak
http://blogs.adobe.com/sarthak
30.4K
Guide ,
Thanks for the great news, Sarthak!
Guru ,
May 06, 2009 May 06, 2009
Just got the announcement via twitter and was coming to post the message and saw it was already here - thanks !!
PS:  Hopefully this also addresses the issue of CS4 being such a resource hog!  had to switch back to CS3 for this very reason.. we'll soon see, going to update shortly  🙂
Guest
Hi
I downloaded the update for windows (XP) and cannot run the set up. It says  Adobe setup has encountered a problem and needs to close every time i try.
Can't find out what the problem is. Anyone facing the same problem?
Adobe Employee ,
  1. C:\Program Files\Common Files\Adobe\ Installers\ . In this folder you will find Adobe Fireworks log (*.log.gz) with the date stamp in the file name. Send us the one corresponding to which date you have applied the patch.
  2. Also goto Run and type "%temp%". Under that folder send us the "pbs.log" file.
Guest
  1. C:\Program Files\Common Files\Adobe\ Installers\ .   I couldn't find a file with the specific date at this folder. (i have installed fireworks in another disk partition than C: , if that counts.)
  2. I  found the pbs file which i send to you.
I also attach a screenshot of the error message. (i'm not using english xp, sorry  )
i'll try to find a solution too, if i can
thanks
Guest
Some problems with attaching files, should i send them to your e-mail?
Adobe Employee ,
Please send them directly to my mail ID. I am unable to see them.
You can also put the files on file hosting server and send me the link to download them.
Guest
Guru ,
Zygopoulos Panos wrote:
Hi
Just saw your other post about the MScong file - wondering whether that has anything to do with the non-starting of the program - worth a look anyway  🙂
Guest
Hi
I tried to do that right after i saw your post, but unfortunately, even with the CS4ServiceManager running, it didn't work.
Guide ,
Successful install on my Mac Book Pro!
Jim Babbage
Guru ,
Same, successful install on Vista and then I updated Air 1.5  🙂  - which I didn't know about previously.
Tomorrow time to test whether CS4 can last more than a few hours before coming to a screeching halt.   🙂
Thanks for the update Sarthak!
Successful install on my iMac 24"
Testing it... and will return!
/Henriko
May 07, 2009 May 07, 2009
The update keeps failing on me. I've tried updating using Adobe Updater and the standalone updater with no success.  I get the error message: "Adobe Fireworks Cs4 10.0.3 - Failed to Install."
I'm have the student version of CS4 Web Premium on a Macbook C2 Duo with Leopard 10.5.6.
Any suggestions?
Adobe Employee ,
May 08, 2009 May 08, 2009
In case you are facing update installation issue through the automatic update or downloading and installing it, please send us the following logs placed at locations on different platforms specified below.
WIN XP
1. C:\Program Files\Common Files\Adobe\ Installers\ . In this folder you will find Adobe Fireworks log (.log.gz) or the Adobe Suite name (.log.gz) with the date stamp in the file name. Send us the one corresponding to which date you have applied the patch.
2. Goto Run and type "%temp%". Files named "pbs.log" and “aum.log”.
WIN VISTA
1. C:\Program Files(x86)\Common Files\Adobe\ Installers\. In this folder you will find Adobe Fireworks log (.log.gz) or the Adobe Suite name (.log.gz) with the date stamp in the file name. Send us the one corresponding to which date you have applied the patch.
MAC
1. /Library/Logs/Adobe/Installers. In this folder you will find Adobe Fireworks log (.log.gz) or the Adobe Suite name (.log.gz) with the date stamp in the file name. Send us the one corresponding to which date you have applied the patch.
2. “aum.log” and “pbs.log” which will be placed at /tmp .You can navigate to this location from Terminal.
There was no aum.log file in my /tmp directory. I've attached the other two
files.
2009/5/8 Sarthak Singhal <forums@adobe.com>
WIN XP
you will find Adobe Fireworks log (*.log.gz) or the Adobe Suite name
WIN VISTA
folder you will find Adobe Fireworks log (*.log.gz) or the Adobe Suite name
MAC
applied the patch.
Adobe Employee ,
Dont see the logs. Can you recheck?
Sorry, I thought attaching them to my email reply would work. I'm having trouble attaching them to this post so I'll upload them to Dropbox. Will post the link in a few minutes.
May 09, 2009 May 09, 2009
I had the same problem on my MacBook Pro - eventually I found that turning off Little Snitch's network filter prior to running the updater allowed it to complete successfully (maybe it phones home?)
hth
Adobe Employee ,
May 11, 2009 May 11, 2009
Log says
Trying to find actual installation ...
File does not exist at: /Applications/Adobe/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Resources/AMT/application.xml
Install root from AFL : /Applications/Adobe Fireworks CS4
Application could not be located. Assuming drag to trash.
It appears user has changed application location after its installation. Suggest to uninstall and install to set this right.
Fireworks is installed in the default location. The path below leads to
application.xml.
2009/5/11 Sanjay B <forums@adobe.com>
Log says
Adobe Employee ,
Let me refer this to installer team and get back.
Adobe Employee ,
Installer team has noticed from the log that installer version used is 99. Where as all Fw Cs4 and patches are built with installer version 131.
I belive either you have used wrong installer or have sent wrong log files.
1. First delete logs
2. Install pacth preferably through help update.
3. Now send logs.
