The Fireworks CS4 application has released the much awaited patch to fix some of the big issues related to text and stability. The update can be downloaded from http://www.adobe.com/support/fireworks/downloads_updaters.html . The automatic update for the application from Adobe Update Manager (AUM) is coming shortly.
After applying the update, please ensure that the version screen now shows as shown below.
We await your response to this update release.
..Sarthak
Thanks for the great news, Sarthak!
Just got the announcement via twitter and was coming to post the message and saw it was already here - thanks !!
PS: Hopefully this also addresses the issue of CS4 being such a resource hog! had to switch back to CS3 for this very reason.. we'll soon see, going to update shortly 🙂
Hi
I downloaded the update for windows (XP) and cannot run the set up. It says Adobe setup has encountered a problem and needs to close every time i try.
Can't find out what the problem is. Anyone facing the same problem?
I also attach a screenshot of the error message. (i'm not using english xp, sorry )
i'll try to find a solution too, if i can
thanks
Some problems with attaching files, should i send them to your e-mail?
Please send them directly to my mail ID. I am unable to see them.
You can also put the files on file hosting server and send me the link to download them.
Of course.
you can download them from here http://www.datafilehost.com/download-97b4f115.html
Zygopoulos Panos wrote:
Hi
Just saw your other post about the MScong file - wondering whether that has anything to do with the non-starting of the program - worth a look anyway 🙂
Hi
I downloaded the update for windows (XP) and cannot run the set up. It says Adobe setup has encountered a problem and needs to close every time i try.Just saw your other post about the MScong file - wondering whether that has anything to do with the non-starting of the program - worth a look anyway 🙂
I tried to do that right after i saw your post, but unfortunately, even with the CS4ServiceManager running, it didn't work.
Successful install on my Mac Book Pro!
Jim Babbage
Same, successful install on Vista and then I updated Air 1.5 🙂 - which I didn't know about previously.
Tomorrow time to test whether CS4 can last more than a few hours before coming to a screeching halt. 🙂
Thanks for the update Sarthak!
Successful install on my iMac 24"
Testing it... and will return!
/Henriko
The update keeps failing on me. I've tried updating using Adobe Updater and the standalone updater with no success. I get the error message: "Adobe Fireworks Cs4 10.0.3 - Failed to Install."
I'm have the student version of CS4 Web Premium on a Macbook C2 Duo with Leopard 10.5.6.
Any suggestions?
In case you are facing update installation issue through the automatic update or downloading and installing it, please send us the following logs placed at locations on different platforms specified below.
WIN XP
1. C:\Program Files\Common Files\Adobe\ Installers\ . In this folder you will find Adobe Fireworks log (.log.gz) or the Adobe Suite name (.log.gz) with the date stamp in the file name. Send us the one corresponding to which date you have applied the patch.
2. Goto Run and type "%temp%". Files named "pbs.log" and “aum.log”.
WIN VISTA
1. C:\Program Files(x86)\Common Files\Adobe\ Installers\. In this folder you will find Adobe Fireworks log (.log.gz) or the Adobe Suite name (.log.gz) with the date stamp in the file name. Send us the one corresponding to which date you have applied the patch.
MAC
1. /Library/Logs/Adobe/Installers. In this folder you will find Adobe Fireworks log (.log.gz) or the Adobe Suite name (.log.gz) with the date stamp in the file name. Send us the one corresponding to which date you have applied the patch.
2. “aum.log” and “pbs.log” which will be placed at /tmp .You can navigate to this location from Terminal.
There was no aum.log file in my /tmp directory. I've attached the other two
files.
2009/5/8 Sarthak Singhal <forums@adobe.com>
WIN XP
you will find Adobe Fireworks log (*.log.gz) or the Adobe Suite name
(*.log.gz) with the date stamp in the file name. Send us the one
WIN VISTA
folder you will find Adobe Fireworks log (*.log.gz) or the Adobe Suite name
MAC
applied the patch.
Dont see the logs. Can you recheck?
Sorry, I thought attaching them to my email reply would work. I'm having trouble attaching them to this post so I'll upload them to Dropbox. Will post the link in a few minutes.
I had the same problem on my MacBook Pro - eventually I found that turning off Little Snitch's network filter prior to running the updater allowed it to complete successfully (maybe it phones home?)
hth
Log says
Trying to find actual installation ...
File does not exist at: /Applications/Adobe/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Resources/AMT/application.xml
Install root from AFL : /Applications/Adobe Fireworks CS4
Application could not be located. Assuming drag to trash.
It appears user has changed application location after its installation. Suggest to uninstall and install to set this right.
Fireworks is installed in the default location. The path below leads to
application.xml.
2009/5/11 Sanjay B <forums@adobe.com>
Log says
Let me refer this to installer team and get back.
Installer team has noticed from the log that installer version used is 99. Where as all Fw Cs4 and patches are built with installer version 131.
I belive either you have used wrong installer or have sent wrong log files.
1. First delete logs
2. Install pacth preferably through help update.
3. Now send logs.
