yossibs
Adobe flash and air for arm devices
May 9, 2009 3:48 PM
Hi all,
It seems that adobe is going to have the flash player and AIR running over ARM architecture devices by the end of 2009.
Does anybody know anything about performance analysis?
Does anybody know about how to become an early adopter or beta user?
Is it going to be a real multiplatform solution?, i.e. running over x86 PC and arm device with exactly same code?
    May 10, 2009 3:13 AM   in reply to yossibs
    Today we already have an optimized Flash Player for mobile devices running on over a billion devices, many other chipsets, it's called Flash Lite.
    Alhough we are building Flash 10 for devices and yes it will be full featured, and of course with optimizations.
    We are not looking for beta testing at this time, though I would suggest checking out the Distributable Player on Adobe Labs.
    adobe.com/go/distribute
    Regards
    Mark
    www.flashmobileblog.com
    May 11, 2009 11:34 AM   in reply to yossibs
    Flash Lite exists on many very different devices, all with different hardware specifications.  Some developers have found it difficult to understand that targetting a mobile device requires an understanding of performance, both of the device and the player.
    We design the player to scale up from a minimum specification and so if you target a low-end phone you have to scale your application appropriately.  In my experience most developers failed to recognise that all devices are not made equal.
    Flash Lite 3.1 was designed to render the majority of Flash content on the web today, at shipping this was 92%.  So you can think of it as 92% compatible with all the APIs that developers were using.
    You can see a detailed API comparison here:
    http://www.adobe.com/products/flashlite/version/flashlite_feature_comp arison.pdf
    As for creating a high quality game on XGA+LCD you'll need to ensure that the device has a very powerful CPU in the 500mhz ARM11 range.  Aiming anywhere below that will cause Flash to struggle because the device will be strained trying to draw to the screen.
    You might be better off considering C++ for such an application, but do give FL3.1 a chance and see how you get along.
    Mark
    May 11, 2009 4:48 PM   in reply to yossibs
    We do make use of HW acceleration with Flash Lite 3.1 but in a limited way so far.  We use the OpenVG1.1 and OpenGL ES 2.0 apis and require that those are hooked up by the OEM.  That effort is clearly going to be a long haul, but we're chipping away at it and have seen great results already.
    My recommendation is to throw the Cortex A9 CPU in the device, as we are working with ARM to optimize for this architecture with our future runtimes.
    So in the future you'll see a mix of different use cases, where we rely more on available hardware accelleration where possible.  This couldn't be more useful when working on very high resolution screens with a single threaded runtime.
    Mark
    Sep 16, 2010 10:40 PM   in reply to yossibs
    We meet scan that these unhurried vine are on Level3 backbones and opposite various companies; that can't mayhap feature anything to [url=http://www.zyy.com]Buy WOW Gold[/url] with Storm. They see it isn't them, so they're licitly forward the [url=http://www.gobuycheaprsgold.com]Cheap RS Gold[/url] probable culprit: TWC. This guy apparently does not interpret ICMP deprioritization on intermediary routers, yield course variables, or routing in broad. But again, this is not the ethical installation to treat specified things[url=http://www.rsfarming.com/]. TimeWarner has no much obligation to assure that you can perform WoW[url=http://www.storeingame.com]RuneScape Gold[/url], especially for a happening equivalent this where latency seems to be the primary *****.Earnestly show the mulct produce.
