Home/Support/
Forums
5103 Views 10 Replies Latest reply: Jun 7, 2009 10:01 AM by beaucamera RSS
micric14 Calculating status... 3 posts since
Apr 20, 2009
Apr 20, 2009 2:04 PM
AVCHD lite
I'm considering buying a new Panasonic still camera which also records & saves video in "AVCHD lite" format and records audio using the "Dolby digital stereo creator". I'm probably being naive to ask but does Premiere Elements 7 accept these formats ? If not, does anyone know of a cheap & cheerful workaround until it does?
  • Bill Hunt All-Star 44,702 posts since
    Oct 10, 2002
    1. Apr 20, 2009 2:42 PM (in response to micric14)
    Re: AVCHD lite
    PE7 does work with AVCHD files. The one thing to consider is the power of your computer, as it takes a lot of horsepower to process these files. Your enjoyment will be directly proportional to the processing power and to your hard disk setup.
    You might want to do a Search on this forum for AVCHD and also look on the fora in Muvipix. There are many articles on editing these files.
    Hunt
  • Paul_LS Participant 1,356 posts since
    Aug 20, 2005
    2. Apr 20, 2009 3:17 PM (in response to micric14)
    Re: AVCHD lite
    As Hunt says, PE7 supports AVCHD, however AVCHD Lite is somewhat different than AVCHD in that it is a 720p resolution. The lower resolution allows longer files to be captured and therefore it is finding it's way into stills cameras and in some cases replacing the MJPEG codec. The only issue is that PE7 does not have a 720p project preset for AVCHD only 1080i. Therefore your best bet would be to use it in a HDV 720p project.
  • dominique92100123 Calculating status... 7 posts since
    May 10, 2009
    4. May 10, 2009 2:52 PM (in response to micric14)
    Re: AVCHD lite
    I cannot even read AVCHD Lite from LUMIX TZ7 in Adobe Premiere Elements 4.....
    So Not Supported, yet ???
    Aug 20, 2005
    5. May 10, 2009 3:17 PM (in response to dominique92100123)
    Re: AVCHD lite
    AVCHD was only supported starting with PE7.
  • dominique92100123 User 7 posts since
    May 10, 2009
    6. May 10, 2009 3:21 PM (in response to Paul_LS)
    Re: AVCHD lite
    AVCHD is supported by Premiere Elements with VAIO extensions, but only for 1080i footage.
    I am talking about AVCHD Lite
    May 10, 2009
    8. May 13, 2009 7:14 AM (in response to micric14)
    Re: AVCHD lite
    Good News,
    Despite what Sony support says !!?!!!
    Try the last version of Sony Vegas 9, it works wonderfully with Panasonic 720/50p  (Panasonic codec seems to come from Sony...)
    You can even render the file in 720/25p or even 720/50p (by typing 50 in the combo box)
    Use File   Advanced  New personalized Template, Format:AVC, Size 1280x720
    Binary Kbits Base Line
    Profil CAVLS
    Imlmage 25 or 50(type it)
    Encoding 20000
    Audio 192000
    And you get an mp4 file with the same characteristics that your original and the same quality
    It is not packed in an MPEG-2 envelope but who cares
    You can even pack it after in an MPEG2-PS with VLS and get a completely comform m2ts.
    Best Regards
    Dominique
    May 10, 2009
    9. May 13, 2009 7:55 AM (in response to micric14)
    Re: AVCHD lite
    Good News,
    Profil CAVLS
    Encoding 20000
    Audio 192000
    Best Regards
    Dominique
  • beaucamera User 18 posts since
    Jun 3, 2009
    10. Jun 7, 2009 10:01 AM (in response to dominique92100123)
    Re: AVCHD lite
    Dominique, thanks you,  I don't find some of the rendering options you suggest for Sony Vega Studio Pro 9.
    I'm a real newbie when it comes to video editing.
    Could you be more specific and detail all the rendering and project settings?
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
