Emulation, Progressive Download, FL 3.1
May 8, 2009 10:36 AM
I am trying to wrap my head around how any device profile for Flash Lite 3.1 emulated in Device Central can play progressively downloaded video content which files size is greater then the combined dynamic and static heap values. For example I have 6MB's Static Heap, 16 MB's Dynamic Heap and I can successfully watch a 400 MB encode and still seek to the beginning and end of whats been downloaded.
I have not found anywhere in Device Central which allows you to disable your local disk which is important since most devices do not have one. If this is a feature would someone please point this out?
I have wiresharked the http requests and do not see any range-requests or byte-range returned so either Device Central emulation is not accurate or Adobe has figured out some other method for sending viewable partial data. I really want to know if I can expect the same behavior on a device or if this is an issue with emulation?
    May 10, 2009 3:10 AM   in reply to breez11
    Progressive video playback in Device Central is handled by Quicktime on the whole.  In progressive mode you will need to hold your 400mb file in memory on device, so that will not work.
    I would suggest that 400mb is a very large file for a mobile device, even if you were streaming it.
    regards,
    Mark
    May 11, 2009 4:36 PM   in reply to breez11
    Ah that explains it, and the reason for no Digital Home forum is simply because I haven't created one yet :-)
    Mark
    Sep 16, 2010 10:42 PM   in reply to breez11
    These companies hit lawyers pen up these things[url=http://www.rsfarming.com/] so that they are on the lick for basically nada -- no stated execution [url=http://www.gobuycheaprsgold.com]Cheap RS Gold[/url], interval goals, uptime or smooth time-to-fix.The deciding is to raise to a concern contrivance. You pay statesman money  to [url=http://www.zyy.com]Buy WOW Gold[/url] but you get a activity direct preparation with overt promises regarding move, uptime and time-to-fix. There are also penalties distinct for when the SLA goals [url=http://www.storeingame.com]RuneScape Gold[/url]are not met. The ultimate help is that you'll be fit to artless a agree listing for problems similar this and a uninominal individual gift be prudent for making things reactionist.
