Hello,
Can any one please help modify my formcalc script to calculate the number of weekdays between two date fields. My script currently calculates the total number of days between two dates, including the weekends which need to be excluded from the total.
if
(HasValue(Start_Date1) & HasValue(End_Date1) ) then
= Date2Num(End_Date1, "YYYY-MM-DD", "en_IE") - Date2Num(Start_Date1, "YYYY-MM-DD", "en_IE") + 1 else
endif
Any help will be most appreciated.
Thank you.
Try this....
// form1.page1.subform1.WeekEndDays::calculate - (FormCalc, client)
if (HasValue(Start_Date1) & HasValue(End_Date1) ) then
var totalDays = Date2Num(End_Date1, "YYYY-MM-DD", "en_IE") - Date2Num(Start_Date1, "YYYY-MM-DD", "en_IE") + 1
var currentDateNum = Date2Num(Start_Date1.formattedValue,"YYYY-MM-DD")
var dayCnt = 0
for i=1 upTo totalDays do
var dayOfWeek = Num2Date(currentDateNum,"E")
if (dayOfWeek == 1 | dayOfWeek == 7) then
dayCnt = dayCnt + 1
endif
currentDateNum = currentDateNum + 1
endfor
$ = dayCnt
else
endif
Steve
Dear Steve,
Thank you very much for your reply. I have placed the script into my calculation field called "days1".
There is an error message when the pdf is previewed.
I have attached the error message on a file for you to look at to see where I could be going wrong.
eg. syntax error near token " on line 2, column 0.
Thank you for your assistance.
Check...
1) You stated you put the script on the calculate event of "days1". My sample mimics the variable names used in the original post, "Start_Date1" and "End_Date1". If the variable names for the start and end dates are different you will have to change the script to reflect those names.
2) The Date2Num functions in the calculation of "totalDays" uses the date format "YYYY-MM-DD". If your date patterns differ from "YYYY-MM-DD" FormCalc will complain.
Steve
Hello Steve,
I have one last question for you.
I would like to change the date format from YYYY-MM-DD to DD-MM-YYYY.
The Start_Date1 and End_Date1 pattern fields have been changed to the new format of DD-MM-YYYY.
I have also revised the form calcs in Weekend Days and Total Days to the format of DD-MM-YYYY.
The script will not calculate the number of days after changing the date format.
Can you please advise what the problem could be?
Thank you once again, Steve.
The attached now displays the start and end dates as DD-MM-YYYY. I added script to validate the end date is greater than the start date, also.
Steve
Hello Steve,
I have revised the script to take into account that if the start date and end date are the same that the total of days will = 1.
Before being revised the script would not calculate the number of days if start and end date were the same.
The revised script is posted as below for reference:
// Weekdays field *This will subtract the total days - the weekend days to give the total number of weekdays between two dates*
if (Date2Num(End_Date1, "YYYY-MM-DD", "en_IE") >= Date2Num(Start_Date1, "YYYY-MM-DD", "en_IE")) then
$ = TotalDays1 - WeekEndDays1
else
endif else
endif
// Weekend Field *this will calculate the number of weekend days between two dates* if
var currentDateNum = Date2Num(Start_Date1.formattedValue, "DD-MM-YYYY")
var dayCnt = 0
var dayOfWeek = Num2Date(currentDateNum, "E")
dayCnt
= dayCnt + 1
endif
currentDateNum
endfor
dayCnt
else
endif else
"" endif
// Total Days Field - *This will calculate the total number of days including weekend days* if
else
endif else
endif
Sir,
Belated Merry Christmas...
Just today (27-12-2011) I have come across your solution for calculating the number of weekdays between two dates. It is working perfect.
But I have a small problem. I am residing in Middle East (Dubai - U.A.E). Here the weekends are Friday and Saturday.
If I want to know the number of weekdays between 13-Jan-2012 and 20-Jan-2012, your solution will show 6 days, whereas actual is only 5.
How can I modify the script to consider the weekends as Friday and Saturday. Your kind reply would be highly appreciated.
Regards
Shyam Kumar
