Problm with Flash Lite
Dec 31, 2008 4:33 AM
Dear Friends,
I have a flash movie of 2400 frames.which is having 50fps.its contains few animations.Creatd in flash tru device central 2.1.And i copies to my Nokia E90.Its playing but it after 12 secs its stops itself.i tryd my best but result is same.this was my first attempt using Flash lite 2.1.Plaz help me to solve this problm.
FictiveHawk
    Jan 12, 2009 8:04 AM   in reply to fictivehawk
    It sounds like you are running out of memory, or have a memory leak.
    You should try adding a textbox to your root and writing debug information into that. Check the memory usage and determine whether or if your application is still running.
    Mark
    www.flashmobileblog.com
    Jan 20, 2009 1:17 AM   in reply to mucatron
    yes, it could be a memory problem. I have a friend with some problem, and he thinks the same, but never solved the problem until now.
    May 12, 2009 12:05 AM   in reply to fictivehawk
    Hi all,
    well fictivehawk, will be nice if you can share a link of your flash file. I just wonder how you create the images, graphics and animation. You can minimize the usage of memory if used proper technique while develope the app...i guess, rite?  ;D
