Sarthak Singhal
Fireworks CS4 updater 10.0.3 is LIVE
May 5, 2009 11:49 PM
The Fireworks CS4 application has released the much awaited patch to fix some of the big issues related to text and stability. The update can be downloaded from http://www.adobe.com/support/fireworks/downloads_updaters.html . The automatic update for the application from Adobe Update Manager (AUM) is coming shortly.
After applying the update, please ensure that the version screen now shows as shown below.
Fireworks CS4 update About us
We await your response to this update release.
..Sarthak
http://blogs.adobe.com/sarthak
    Community Member
    May 6, 2009 12:56 AM
    Thanks for the great news, Sarthak!
    Community Professional
    May 6, 2009 6:15 AM
    Just got the announcement via twitter and was coming to post the message and saw it was already here - thanks !!
    PS:  Hopefully this also addresses the issue of CS4 being such a resource hog!  had to switch back to CS3 for this very reason.. we'll soon see, going to update shortly  :-)
    Community Member
    May 6, 2009 6:24 AM
    Hi
    I downloaded the update for windows (XP) and cannot run the set up. It says  Adobe setup has encountered a problem and needs to close every time i try.
    Can't find out what the problem is. Anyone facing the same problem?
    May 6, 2009 7:04 AM
    Successful install on my Mac Book Pro!
    Jim Babbage
    Community Member
    May 6, 2009 7:31 AM
    1. C:\Program Files\Common Files\Adobe\ Installers\ .   I couldn't find a file with the specific date at this folder. (i have installed fireworks in another disk partition than C: , if that counts.)
    2. I  found the pbs file which i send to you.
    I also attach a screenshot of the error message. (i'm not using english xp, sorry  )
    i'll try to find a solution too, if i can
    thanks
    Community Member
    May 6, 2009 7:46 AM
    Some problems with attaching files, should i send them to your e-mail?
    Community Member
    May 6, 2009 8:28 AM
    May 6, 2009 9:17 AM
    Same, successful install on Vista and then I updated Air 1.5  :-)  - which I didn't know about previously.
    Tomorrow time to test whether CS4 can last more than a few hours before coming to a screeching halt.   :-)
    May 6, 2009 10:42 AM
    Zygopoulos Panos wrote:
    Hi
    Just saw your other post about the MScong file - wondering whether that has anything to do with the non-starting of the program - worth a look anyway  :-)
    Community Member
    May 6, 2009 12:14 PM
    Thanks for the update Sarthak!
    Successful install on my iMac 24"
    Testing it... and will return!
    /Henriko
    Community Member
    May 6, 2009 4:39 PM
    Hi
    I tried to do that right after i saw your post, but unfortunately, even with the CS4ServiceManager running, it didn't work.
    Community Member
    May 7, 2009 11:39 AM
    The update keeps failing on me. I've tried updating using Adobe Updater and the standalone updater with no success.  I get the error message: "Adobe Fireworks Cs4 10.0.3 - Failed to Install."
    I'm have the student version of CS4 Web Premium on a Macbook C2 Duo with Leopard 10.5.6.
    Any suggestions?
    Community Member
    May 8, 2009 6:30 AM
    There was no aum.log file in my /tmp directory. I've attached the other two
    files.
    2009/5/8 Sarthak Singhal <forums@adobe.com>
    In case you are facing update installation issue through the automatic
    update or downloading and installing it, please send us the following logs
    placed at locations on different platforms specified below.
    WIN XP
    1.     C:\Program Files\Common Files\Adobe\ Installers\ . In this folder
    you will find Adobe Fireworks log (*.log.gz) or the Adobe Suite name
    (*.log.gz) with the date stamp in the file name. Send us the one
    corresponding to which date you have applied the patch.
    2.     Goto Run and type "%temp%". Files named "pbs.log" and “aum.log”.
    WIN VISTA
    1.     C:\Program Files(x86)\Common Files\Adobe\ Installers\. In this
    folder you will find Adobe Fireworks log (*.log.gz) or the Adobe Suite name
    MAC
    1.     /Library/Logs/Adobe/Installers. In this folder you will find Adobe
    Fireworks log (.log.gz) or the Adobe Suite name (.log.gz) with the date
    stamp in the file name. Send us the one corresponding to which date you have
    applied the patch.
    2.     “aum.log” and “pbs.log” which will be placed at /tmp .You can
    navigate to this location from Terminal.
    Community Member
    May 8, 2009 8:46 AM
    Sorry, I thought attaching them to my email reply would work. I'm having trouble attaching them to this post so I'll upload them to Dropbox. Will post the link in a few minutes.
    Community Member
    May 8, 2009 8:55 AM
    Community Member
    May 8, 2009 4:13 PM
    While I haven't had a lot of time to spend with it today, so far so good. Definitely seems faster and more stable. And no new text glitches.
    Thank God! I was beginning to wonder if this patch was vaporware.
    Community Member
    May 9, 2009 2:49 AM
    I have a 30inch dell monitor on my OSX leopard Mac Pro.
    since upgrading the 'use application frame is all out of whack - the image window maximises and won't resize, and some of the frame is off screen and I can't get it back.
    it's also fubar'd if I open FW in a space and then try and use application frame the image stays in one space, but the frame and tool pallettes go back to the default top left space - useless.
    the point I'm trying to make is that not using the application frame on a 30 inch screen is quite hard - tools are miles apart!
    it was all working...
    any one else experience this?
    Community Member
    May 9, 2009 3:05 AM
    with application frame:
    http://www.flickr.com/photos/boldfish/3515199374/
    without:
    http://www.flickr.com/photos/boldfish/3514389187/
    tried deleting plist no help.
    NB without an image it seems okay, but open or create a new image and it goes awry...
    help?
    Community Member
    May 9, 2009 3:09 AM
    and here's what happens when I open an image (rather than create new)
    http://www.flickr.com/photos/boldfish/3514398189/
    especially useless.
    grrr.
    Community Member
    May 9, 2009 3:16 AM
    after messing about a bit with preview, 4 up etc I managed to get a view that allowed me to grab the bottom right corner and resize the frame.  it all snapped into place appropriately and it seems to be holding up after a restart and re-open recent.
    I'll let you know if it breaks again....
    Community Member
    May 9, 2009 3:53 AM
    I had the same problem on my MacBook Pro - eventually I found that turning off Little Snitch's network filter prior to running the updater allowed it to complete successfully (maybe it phones home?)
    hth
    Community Member
    May 9, 2009 7:23 AM
    further testing reveals that it is still broken when opening files in application frame mode.
    the file area goes full screen and the frame something less than that and the only guaranteed fix I have found is to drag out one of the pallettes from the frame, which then seems to turn on the resize corner, resize the frame (so everything jumps back into place) and then drag the pallette back in.
    most unsatisfactory.
    testing continues.
    Community Member
    May 11, 2009 4:52 AM
    Log says
    Trying to find actual installation ...
    File does not exist at: /Applications/Adobe/Adobe Fireworks CS4/Adobe Fireworks CS4.app/Contents/Resources/AMT/application.xml
    Install root from AFL : /Applications/Adobe Fireworks CS4
    Application could not be located. Assuming drag to trash.
    It appears user has changed application location after its installation. Suggest to uninstall and install to set this right.
    Community Member
    May 11, 2009 5:12 AM
    Fireworks is installed in the default location. The path below leads to
    application.xml.
    2009/5/11 Sanjay B <forums@adobe.com>
    Log says
    Community Member
    May 11, 2009 5:23 AM
    Let me refer this to installer team and get back.
    Community Member
    May 11, 2009 10:44 PM
    Installer team has noticed from the log that installer version used is 99. Where as all Fw Cs4 and patches are built with installer version 131.
    I belive either you have used wrong installer or have sent wrong log files.
    1. First delete logs
    2. Install pacth preferably through help update.
    3. Now send logs.
    Community Member
    May 12, 2009 6:02 AM
    Community Member
    May 12, 2009 6:47 AM
    No. These are not correct either. Name itself indicates that logs are for Creative Suite Web Premium.
    To avoid any confusion suggest to move all files from log location. Keep the folders intact.
    Reproduce the scenario, you should have only log files with Fw CS4 in its name.
    Sanjay
    Community Member
    May 12, 2009 7:10 AM
    Deleting the old logs seems to have fixed the problem. Fireworks has updated to 10.0.3 now. Thanks for your help.
    Community Member
    May 18, 2009 11:02 AM
    Well unfortunately this is just another disappointing saga. Now Fireworks just decides to give up and quit right when im in the middle of using it. It's completely random and I soooooo regret installing that upgrade! I've lost over an hour of my time today due to Fireworks either just suddenly quiting or producing errors and not enabling me to save work.
    I'll be installing an older version soon I think.
    There's still loads of stuff that I'm just not happy with in this release. It's supposed to save time, not create more time wasting.
    I'm just hoping there'll be an extra update soon.
    My initial happiness with CS 4 was shortly lived ... with Fireworks anyway.
    J.
    Community Member
    Jul 2, 2009 3:06 PM
    Hi Sarthak
    I've been unable to run the Fireworks CS4 10.0.3 update since it was released. I have tried through the standard Adobe updater and by downloading the individual patch several times but with the same "Adobe Fireworks Cs4 10.0.3 - Failed to Install." message.
    I have uploaded a ZIP file containing the .gz files to; http://www.andrewscrivener.co.uk/fw_CS4_errors.zip
    I also don't seem to have the “aum.log” and “pbs.log” files in the /tmp/ directory?
    Hopefully they'll be a fix to this as I haven't been able to use Fireworks CS4 since I purchased it on the launch day last year.
    Many Thanks
    Community Member
    Jul 3, 2009 12:02 AM
    Andrew, The logs indicate you installed WebPremium. Did you install FW from a GM version of Webpremium suite? This was little confusing as your mail said "Since I purchased Fireworks...".
    Initial investigation points some permission issues while applying patch. I would recommend un-installing Fw and re-installing it before applying patch.
    Also move all the existing installer log files (from Library/Logs/Adobe/Installers) to differnt location. And send only the newly created nstaller log. When we have many logs (as in your zip), we could be looking at wrong file.
    Community Member
    Jul 5, 2009 4:39 AM
    Hi Sanjay
    I've removed the log files as requested. Uninstalled Fireworks CS4 and reinstalled. The 10.0.3 combo updater still fails when I try to install it, I've attached the current log file.
    I'm not sure what you mean by a "GM version of Webpremium suite", do you mean Gold Master? I originally had a full version of CS2 and the individual Macromedia applications (Fireworks 8, Dreamweaver 8 and Flash 8), I then upgraded this on launch to the WebPremium CS3 and then again on launch to WebPremium CS4.
    At the moment I have both CS3 and CS4 installed on my iMac and Macbook Pro (as CS4 is not currently useable) and neither Macs will successfully upgrade the Fireworks patch to 10.0.3.
    Andrew Scrivener
    Community Member
    Jul 5, 2009 10:53 PM
    The log file attachment link is not accessible. It says 'Queued". Possibly the location is full. Suggest to post it some other location and provide me link. Altarnatively delete the older zip file and try.
    Yes I was referring Gold Master. I was just trying to understand if you had pre-release CS4 suite installed, and if that left behind some files etc.
    Sanjay
    Community Member
    Jul 6, 2009 2:35 PM
    Hi Sanjay
    I've attached the log again and if there's any problems also uploaded it for you to download at;
    http://www.andrewscrivener.co.uk/fireworksLog.zip
    To answer your other question I did originally try the Fireworks CS4 beta but that was on my previous Macbook and I removed it with the CS4 beta removal tool, the only possible way there could be any stray files is if they weren't removed correctly and have since synched to my new Macbook via MobileMe.
    Andrew
    Community Member
    Jul 13, 2009 4:07 AM
    Andrew
    I have sent mail to you seprately to setup a meeting.
    Sanjay
    Community Member
    Aug 10, 2009 10:17 AM
    I'm running into a different, but related issue. When checking for updates within FW, the updater checked all Adobe apps, offered the various downloads, including 10.0.3 for FW, and ran the updater without incident. However, when viewing the version number on the splash screen, or checking Help > About Fireworks, I'm seeing the version as 10.0.0.495. I've run through this process three or four times now with the same results.
    I also just tried downloading the standalone updater for FW 10.0.3 and when I attempt to run it, it tells me that 10.0.3 is already installed.
    Any help?
    Community Member
    Aug 11, 2009 6:01 AM
    Please verify by hovering your mouse on Fireworks.exe application for its version.
    Since you do not get any error message I do not see much use of log files.
    I suggest uninstall Fw cs4 and then re-install Fw CS4.
    Sanjay
    Community Member
    Aug 11, 2009 8:39 AM
    Sanjay, thanks for the suggestion. Hovering over the .exe displays
    10.0.0.495 ... same as the 'About Fireworks' view. I believe the issue I'm
    having is not specific to FW, but to all the Adobe products as every time I
    check for updates, the updater is finding the same three updates ... one for
    FW, one for Reader, and one for Illustrator.
    So I'm thinking a complete uninstall and reinstall ... ugh.
    Thanks again,
    Rick
    Community Member
    Sep 4, 2009 11:53 AM
    Sarthak,
    Could you send me an email or place to upload the files you need. I have CS4 Master Suite and I ran the updater every app updated but the Fireworks 10.0.3 I even made a new user account for a different issue and it's still won't update, I also used thew standalone installer.
    David
    Community Member
    Sep 6, 2009 11:33 PM
    Hi David
    Note the location of installer logs in this thread.
    1. Please move all existing installer logs to make the place clean. (Leave any other folders at that location intact)
    2. Run the standalone updater
    3. Send the newly created installer log
    Also keep in mind last time you had to post the logs at your website instead pf attaching here because of size limitations.
    Community Member
    Sep 26, 2009 10:13 PM
    I have recently upgraded both my computer and Adobe software suite.  I have 6 GB of ram and a very fast processor.  Issue I am having is the slow speed of Fireworks CS4 opening and saving files.  Is there some form of Vista Business 64 bit optimization I need to do?  Does having both CS3 and CS4 installed on the same system cause an issue?
    I am desperate to get this solved.  I have invested heavily in using the increased speed of CS4 64 bit, and have in no way realized those time savings because of the issues above.
    Please help me.
1 2 Previous Next
Actions
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
