Using CS3. Can't open customer supplied file because I don't have worldeady.indesign. plugin and conditionaltext.idesign plugin.
Can I download these plugins?
It's a CS4 file... It needs to be exported as INX to be opened in CS3
Harbs
Your customer is supplying you with a CS4 file. You need to upgrade to assure full compatibility.
Bob
I have the same problem. I've created an .inx-file for my costumer. I work in CS4 and he has CS3. Even though I've exported it as an .inx-file he still gets error messages saying that some plugins are missing ("worldready.indesignplugin" and "conditional text.indesignplugin"). This leaves me perplexed because I know for sure that I have exported the file to an .inx and that my costumer SHOULD be able to open it without encountering these error messages. What could have gone wrong? What can I do to help him?
Kind regards,
Kim
Did you send him the .inx? It sounds like you are still sending .indd.
Yes, I'm completely sure, I exported and sent him the file twice just to be certain and none worked. He still gets the same error messages. Is there any other way to export an .inx-file other than to go through Archive->Export? (I have a swedish version of InDesign so I hope this is what the menues are called in english).
Another thing good to know (maybe) is that I work in a Mac environment and he uses a PC. But as I've understood from reading other forum posts, this should not be a problem.
Thanks for your help in advance!
Kind regards,
Kim.
In English it would be File > Export... (Cmd + E) and choose Interchange Format.
Make sure you zip the file before sending, and he must be patched to 5.0.4 build 682.
Thanks a million, I will be sure to check if he is patched to 5.0.4 build 682. Is this the lik to send him?
http://store1.adobe.com/support/downloads/detail.jsp?ftpID=4030
If not, how does he update in the simplest way? Is there an "update" choise in the Help menue or anything like that?
Eternally grateful,
Kim
That link should work, or the updater in the help menu.
You didn't actually use any features of the worlready composer or any conditional text, did you? I'm not sure what would happen in such a case.
I'll send him the link and hope that does it.
I don't think I've used any fancy features, there are some text, but it's just written in ordinary text blocks and not treated in any special way.
Thanks once again,
Kim
